- Thanos
- Drives: Polo 6R 1.2 TDI BM
Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
You know when you think he cant do anything more to his car, he still manages to do/change something.
It's crazy to think about how much time/effort/money this project has cost you.
Bravo sir.
Bravo sir.
Thank you so much
SanketM
- Drives: VW Polo 1.0 TSI Highline Plus
Hi Iichel,
Your thread is a source of great knowledge for me similar to Ciclo's and Patil's threads. I have spent numerous hours during the past few weeks going through the threads on the forum and that finally ended up with me taking a plunge and getting myself Polo 1.0 TSI Highline. I should be getting my hands on it in a few days hopefully. All thanks to you'll
While going through your thread I stumbled upon a discussion on Active Information Display. And accidentally this was something I had been researching for some time now.
https://www.aliexpress.com/item/1005004176201097.html
I know that Golf 6 is based on PQ35 platform. But thought of diving a little bit deeper and checking the Instrument cluster connector for both Golf 6 and Polo 6R.
https://imgur.com/a/BtW4n1S
Upon comparing the connector, both seem to be sharing the same 32-pin connector. So went to check the pin diagram for Golf 6 and Polo 6R. Below is what I found.
https://imgur.com/a/Q2Da4FM
There seem to be a lot of pins common between both of them also there are a few pins in 6R which aren't in use or left blank in Golf MK6. Also, can there be a difference in the CAN frames being passed around the network in PQ25 and PQ35 ? I don't have enough knowledge to come to a conclusion on the pin diagram and cross-compatibility of the IC board so I would like to request your help to decode it further so we all can have an Active Information Display in our 6Rs.
Eventually, we would need to adapt the plastic pieces of the AID; Front Frame, IC board housing and the back cover of the IC as per 6R's cluster size and its circuit board, but I think It can be 3D printed locally here for all if the seller doesn't agree to do it for us.
Sorry to butt-in and thanks for taking the time to read.
Regards,
Sanket
Some guys in China seem to have come up with an Active information display (Audi'ish style) for Golf 6.
Regards,
Sanket
Hi, i have a question to the QI charger.
5NA980611.
How do you connect it with the radio and coding this?
Best regards
5NA980611.
Best regards
There is a link in the first post to the 5NA wireless charger wiring scheme. I did not need to do any coding.
Some work in progress....
Seats are in!
Changes since last autoscan:
- 14 DCC module is in, but yet to be connected properly
- 36 memory seat is in and fully operational
To do:
- Check GND connection on the airbag deactivation switch
- Connect rear left speed sensor (it's unplugged), fixes a lot of errors
- Change alarm horn (battery dead)
- Install Porsche brakes front and rear
- Install DQ250 DSG6 gearbox
- Install CFGB 2.0 TDI engine
- Complete DCC install and fix DTC 00149 --> https://forums.ross-tech.com/index.php?threads/4011/
- Code 14 DCC module to 000180 --> https://vagcode.info/components/c0108b6 ... 942b9.html
- Code 55 AFS module for sensors via CAN and not via its own sensor, i.e. 0FC2020001000000 --> https://forums.ross-tech.com/index.php?threads/22384/
- Change rear left door lock (it's broken)
- Update BCM to 090E (no reason)
- Update BCM EEPROM to fix HBA problems --> https://imgur.com/a/4GXI6dK
- Change DM startup screen --> adaptation channel Startup_screen_sticker_HMI to 00 02
Seats are in!
Tuesday,06,September,2022,21:35:07:11868
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: License Plate:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 05 08 09 10 14 15 17 19 20 25 2B 36 37 3C 44 47
55 5F 61 65 69 77 B9
VIN:
02-Auto Trans -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
B9-Aux. Display -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 906 023 KE HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000 CVN: 3BB1FB41
Coding: 00254036032401080000
Shop #: WSC 00066 000 00237
ASAM Dataset: EV_ECM16TDI02103L906023KE 003009
ROD: GV_ECM16TDI021VW32X.rod
VCID: 73B3228D2B37CD53C2D-8026
VINID: 9E69EAAAA1A2A92A42085185103550A70A
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H02 0002
Serial number: --------------
Coding: 21DD2885412500C5841A146E825500521504
Shop #: WSC 30389 123 56831
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F7B4E7D27DF89B3465-805A
2 Faults Found:
0374 - Rear Left Wheel Speed Sensor
C101C 01 [137] - Electrical Failure
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Date: 2022.09.06
Time: 20:27:54
0394 - Rear Left Wheel Speed Sensor
C101C 01 [129] - Electrical Failure
MIL ON - Not Confirmed - Tested Since Memory Clear
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Component: VWKESSYPQ35GP 092 1202
Revision: 00092000 Serial number: 0346244897
Coding: 030C0C
Shop #: WSC 31889 047 31889
ASAM Dataset: EV_KESSYPQ35G A02717
ROD: EV_KESSY_PQ35GP.rod
VCID: 372BD69D7FCF61733E5-8062
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H12 0812
Revision: V0000000
VCID: 3829D5A172516E0B37F-806C
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 173171327
Coding: 3EB82BBFA8EB3400B33807E0FFCB9FF0E68067EFE08D78D031E400030800
VCID: 2B03FAEDB307D5934AD-807E
Component: RLHS 220816 0 42 0106
Coding: 0214DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU011111300010103
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU007111300016463
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 008 1611
Serial number: KU0KU027011200011418
Coding: 58BC32
Subsystem 8 - Part No SW: 6R0 959 812 B HW: 6R0 959 812 B
Component: J389__TSG_HR 002 0803
Serial number: KU0-KU004.06.0913330
Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:36
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39391528804191
Coding: 0031195151
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
U1121 00 [009] - Missing Message
[Steuerger‰t f¸r Lenks‰ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: km
Date: 2022.09.06
Time: 20:25:06
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0070
Revision: 00000000 Serial number: 31080904160002
Shop #: WSC 05314 000 00000
VCID: 270B06DDAFEFF1F3AE5-8072
8 Faults Found:
01087 - Basic Setting Not Performed
000 - - - MIL ON
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
01769 - Sensor for Vehicle Leveling; Front Right (G289)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
00149 - End of Line Programming not Completed
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
01042 - Control Module; Not Coded
000 - - - MIL ON
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
00139 - Left Front Body Acceleration Sensor (G341)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
00140 - Front Right Body Acceleration Sensor (G342)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
00141 - Rear Body Acceleration Sensor (G343)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
00776 - Level Control System Sensor; Left Front (G78)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Time Indication: 0
Date: 2017.01.27
Time: 20:22:30
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX0142TCE
Coding: 00314D
Shop #: WSC 01383 785 00200
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4ACD9F691C3DEC9B51B-801E
Serial number: 3575HRB40650BI7U48C8
Serial number: 3585HRB405J09RECEOUJ
Serial number: 3515RRB405T0BTBEF9G7
Serial number: 3525RRB405R0BTBEKPFQ
2 Faults Found:
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: km
Date: 2022.09.06
Time: 20:24:20
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: km
Date: 2022.09.06
Time: 20:24:20
Part No SW: 6R0 920 870 A HW: 6R0 920 870 A
Component: KOMBI H04 0709
Coding: 140F01
VCID: 3333E28D6BB78D5302D-8066
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 042204
VCID: 688945E162713E8B67F-803C
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0404000000000000010000
Shop #: WSC 12345 123 12345
VCID: 2E05F3F98095A0BB6D3-807A
Component: IMMO H04 0709
Coding: 000007
VCID: 6A8D3FE97CFD0C9B71B-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 B HW: 5K0 905 861 B
Component: ELV-PQ35 H20 0240
Revision: 00000000 Serial number: 11000256123005
Coding: 4900000000000000
Shop #: WSC 31889 470 31889
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2F3BEEFD879FA9B3665-807A
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 B HW: 3C8 959 760 B
Component: Sitzmemory H02 1001
Revision: 00H02000
Coding: 000039
Shop #: WSC 40022 666 40022
VCID: 3431E1916E398A6B1B7-8060
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 7E0 907 566 B HW: 4L0 907 566 A
Component: J0769 SWA MasterH13 0120
Revision: 00H13000 Serial number: 6PZ 009 014-07
Coding: 0010161
Shop #: WSC 02756 790 00000
VCID: 2F3BEEFD8B1FA9B3665-807A
Subsystem 1 - Part No: 7E0 907 568 B
Component: J0770 SWA Slave H09 0110
Subsystem 2 - Serial number: 6PZ 009 014-27
Subsystem 3 - Serial number: 5F31.03.1100H090003CH21982ˇ
Subsystem 4 - Serial number: H21982ˇ
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 AD HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3124
Serial number: CF3F0205
Coding: 001F00
ASAM Dataset: EV_SteerAssisUDSTRW 014026
ROD: EV_SteerAssisUDSTRW_014.rod
VCID: 79AF10A5095BB703881-802C
1 Fault Found:
1057792 - Databus
U1123 00 [009] - Received Error Message
[DEM_WHEEL_SPD_INVALID_FAULT]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: km
Date: 2022.09.06
Time: 20:22:32
Engine RPM: 0 /min
Vehicle speed: 0.00 km/h
System status: Waiting for start request
Terminal 15 status: Terminal 15 on
Voltage terminal 30: 12.99 V
Power steering current consumption: 0.50 A
max.value: 0.50 A
End stage temperature: 39 ∞C
Steering assistance: engine output: 0.00 %
Engine angle: 0 ∞
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: 0.03 Nm
Status: OK
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0000052
ASAM Dataset: EV_AudioVerst10KanalSTT4 001001
ROD: EV_AudioVerst10KanalSTT4.rod
VCID: 280905E1A271FE8BA7F-807C
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D4A000001000000
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A2DCFA94CDD7C1BC1B-806E
2 Faults Found:
5256725 - Rear Left Ride-Height Sensor
C1036 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Reset counter: 147
Mileage: km
Date: 2022.09.06
Time: 20:22:32
13705985 - Databus
U1123 00 [137] - Received Error Message
[Fehlerwert im Signal BR3_Rad_kmh_HL]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 147
Mileage: km
Date: 2022.09.06
Time: 20:22:32
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S-ND-ER H41 0478
Serial number: VWZAZ2W1425226
Coding: 02620001AA00000011111103C00D0A201F0100D401200100CE
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 25170CD5D563E3E39C9-8070
Data carrier:
Subsystem 1 - Part No SW: V03 825 254 AD HW: -----------
Component: ECE DL2 22/23 --- 1810
1 Fault Found:
15360256 - Component Protection
U1101 00 [009] - Active
[Anti-theft protection - component protection active (0xEA6100)]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 147
Mileage: km
Date: 2022.09.06
Time: 20:22:31
Voltage terminal 30: 12.4 V
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 C
Component: Batt.regelung H82 0752
Coding: 03037A5A
Subsystem 1 - Part No SW: 6C0 915 181 HW: 6C0 915 181
Component: J367-BDM H08 0223
Serial number: 61083A44504351928092
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000058319
ROD: EV_RDKBERU30_005.rod
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00008200133984
Coding: 4100000101000000
VCID: 3039ED819A21B64B7FF-8064
Address 77: Telephone
Cannot be reached
Address B9: Aux. Display (J285) Labels:* 5C5-919-527.clb
Part No SW: 1K8 919 527 HW: 1K8 919 527
Component: ZUSATZANZEIGE H08 0003
Coding: 05
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Auxi_Disp_Unit_UDS_VDD 001010
ROD: EV_Auxi_Disp_Unit_UDS_VDD.rod
VCID: 75B71C952543D363EC9-8020
1 Fault Found:
2097171 - Databus
U1123 00 [008] - Received Error Message
[control unit for brake: please read out error memory]
Fault Priority: 6
Fault Frequency: 2
Reset counter: 187
Mileage: km
Date: 2022.09.06
Time: 20:22:32
End----------(Elapsed Time: 02:25, VBatt start/end: 13.0V/13.0V)-----------
Sounds good.
Even I was wondering what became of your DCC project on the 6R.
Congratulations on those seats with memory.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
I was under impression it is not compatible. Somewhere it mentions with Stage 4 tune it can work with 750Nm https://tvsengineering.com/en/dsg-gearb ... theContentInstall DQ250 DSG6 gearbox
Really impressed (again) to list of modules installed.
- Platinum Member
Whats your goal with cfgb? 300 hp?
@ag69 its a popular transmission swap in many cars. Doesnt need a lot of to get it working. Many guys use them on brutal 1.8t swaps, evos, etc. you name it someone has done it.
No I'm not particularly interested in 300hp in a FWD car. I'm running about 200 now and that's more than enough.
The DQ250 is a popular upgrade from the DQ200 gearbox (DSG7 dry clutch) because it can handle much more power. To be more precise, torque.
A gearbox does not care about power output that much anyway, since power is only a product of the vector torque and angular velocity (rpm).
Torque is static and it's the cross product of force and a distance to the fulcrum.
Torque is what unwillingly slips your clutch, stresses your bearings and breaks gearboxes..
Now a diesel engine is much more reliable on torque due its nature of high compression and slow combustion speeds.
Especially a turbocharged diesel engine can typically reach about 1.5-2x the torque of a similar sized petrol engine, even though these differences become smaller with turbocharged petrol engines.
My planned setup will be about 500nm and 220-240hp and that's too much for the DQ200 gearbox.
Currently the setup with 1.6 TDI engine and DQ200 is about 420nm and 200hp and the gearbox is already suffering badly.
- Platinum Member
why not larger injectors ( why again engine swap for 240 hp) + hybrid ?
Honesty i was hoping ur goal was around 300 hp, to trash those 1.9 jtd forged engine cars ( AR 147)
check out don-octane.de
Because I think I don't need 300+ bhp in a Polo, and with bigger injectors and a bigger turbocharger driveability does not really improve due to i.e. turbo lag.
You could argue that the DSG gearbox will always take care of smooth power delivery but I really don't think I'll notice the differences between a nice smooth 240hp setup and a race oriented 300hp setup.
Remember, this car is supposed to be a daily driven, comfortable car. Not a dragracer. It's only FWD!
- Platinum Member
I agree, but I think when you get a lick of the extra power after some time you will want more.
We need that multi-map love
Yes of course it's always nice to have more power, but with these engines you need to have a lot of boost to reach high power, without smoke.
This has two disadvantages, first you need to remove the DPF which I don't really want to do because of emission regulations.
Secondly to get a lot of boost, you must put on a different turbocharger, either off the shelf or hybridized. And this really pushes the torque band higher up the rev range. Some setups only start pulling at around 3500 rpm (in a TDI, yes
), so you have a 2.0 SDI from 0 to 3000 rpm and a rocketship from 4000 upwards.
Were i now already have peak torque from 2750 rpm and peak power is not much higher.... that's a great driving car.
So there is no way to go back to a smooth power delivery with just multi-mapping on your ECU, there is always the characteristics of the turbocharger.
- Platinum Member
Well i've mentioned multimap where you could map your car with CFGB on some light tune ~200 hp, less fuel consumption, smaller load on DPF, and some powerful when you want the extra fun.
Hey better smoke than burnt valves ( but sometimes it looks hideous)
