Predictive ACC (pACC) with Tolerance option in menu
Limito
Drives: VW Passat
Post by Limito »
I have also completed an upgrade to predictive ACC on my VW Passat 2017 with infotainment system Discover Pro but I am missing the menu alternative Tolerance. I can see that you ciclo have it available in your car!
If you set the Tolerance to Low, you automatically get the function that if you manually set the speed to 53 km/h on a 50 km/h road, the car will automatically increase to 73 km/h as it approaches a 70 km/h road.
Do anybody know what settings needs to be done on a Discover Pro to get this menu option available?
2022-07-21 202242.png (2.04 MiB) Viewed 25052 times
Re: Predictive ACC (pACC) with Tolerance option in menu
Hi Limito
Maybe if you post the ID, Coding and Adaptations of your radar, Address 13: Auto Dist. Reg (J428), someone can tell you something about it.
Limito
Drives: VW Passat
Post by Limito »
I am not sure if I managed to do it the correct way and if all needed information is available?
OBDeleven vehicle history log
Date: 2022-07-22 08:45
    VIN - fordonets serienummer: WVWZZZ3CZHE0XXXXX
    Car: Volkswagen Passat GTE
    Year: 2017
    Body type: Variant
    Motor: CUKC
    Mileage: 72869 KM
Safety backup
    Control unit: 13 Adaptive Cruise Control
    System description: ACC BOSCH MQB
    Software number: 5Q0907572R
    Software version: 0771
    Hardware number: 3QF907572A
    Hardware version: H11
    ODX-namn: EV_ACCBOSCHVW416
    ODX-version: 003014
    Name of safety backup: Unit 13
    Long codning:
        551F7FEAD7FFCF2B999F81A481508600000000000099400002
    Adaptions:
        Roller test bench mode, functional:
                Not activated
        Deactivate production mode:
                Deactivating
        Production mode:
                Deactivating
        Heated lens:
                On
        Activating and deactivating all development messages:
            Development Message S100:
                Off
            Development Message S101:
                Off
            Development Message S102:
                Off
            Development Message ECU specific:
                Off
            XCP on FlexRay:
                Off
        Distance basic setting option:
                On
        Expanded restart function:
                On
        Presentation mode:
                not active
        Distance change via speed adjustment:
                On
        Prioritized target object display:
                On
        Sail function:
                Activate
        Constant delay after transfer request:
                Yes
        Selection of release codes for a SWaP function:
                ffffffff
        Predictive speed limit regulation:
                activated
        Active participant function activated:
                activated
        Transfer of release code for a SWaP function:
                00
    Avancerad identifiering:
        Number of programming attempts:
            Bootloader:
                0
            Application:
                2
        Maximum number of possible update programming:
            Bootloader:
                10000
            Application:
                10000
        ISO TP block size in bootloader:
                f
        Identification of connected components:
            ID number:
                13
            subsystem_name:
            Bus message/node address:
                57
        Workshop code and date of last update programming of SW module:
            Year:
                0
            Month:
                1
            Day:
                1
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                Correct result
            Year:
                20
            Month:
                8
            Day:
                11
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
            Programming status:
                Correct result
        Date of last coding:
            Year:
                21
            Month:
                8
            Day:
                20
        FAZIT-identification:
            Manufacture location index:
                RB8-658
            Day of manufacture:
                29.08.19
            Manufacturer- test stand number:
                0485
            Running manufacturer number:
                B016
        Diagnostic mode:
                VW - diagnostic mode
        VW/Audi part number:
                5Q0907572R
        SoftwareVersion:
                0771
        Hardware part number:
                3QF907572A
        System description:
                ACC BOSCH MQB
        Adaptation workshop code:
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
        Date of last adaptation:
            Year:
                20
            Month:
                8
            Day:
                11
        ASAM/ODX file identification:
                EV_ACCBOSCHVW416
        Parameter set part number:
                5F027SE370A
        Parameter set version:
                S700
        ASAM/ODX file version:
                003014
        HardwareVersion:
                H11
        Vehicle equipment code:
                000000000000000000000000
        Coding workshop code:
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                12289
        Parameterization workshop code:
            Device number:
                0
            Importer number:
                0
            Dealership number:
                0
        Parameterization date:
            Year:
                20
            Month:
                8
            Day:
                11
        System abbreviation:
                J428
        Versions of software module:
            Bootloader:
                0520
            Application:
                0771
        AUTOSAR Standard application software identification:
            Standard software module:
                E2E Library
            Software manufacturer ID:
                TTTech Automotive GmbH
            Primary version number:
                1
            Secondary version number:
                0
            Revision number:
                5
                Component protection on ISO TP
                Elektrobit Automotive GmbH (3SOFT GmbH)
                2
                0
            Revision number:
                1
                BAP
                ICT Software Engineering GmbH
                1
                9
            Revision number:
                0
                Software as Product (SWaP)
                6
                4
            Revision number:
                0
        Identification of data sets:
        Flash data security:
            Hash value:
                Not available
            Key enable mechanism:
                Not available
            Key:
                No
            Key type:
                Series
            Project ID:
                00000525
            Hash value:
                00
                2500000000
        Programmability status:
            Programmability:
                programmable
            Program consistency:
                Program present
        Data set names:
            Number of data set names:
                1
            Data set ID:
                7200
            Data set name:
                SE370RDW
    Mileage: 72869 km
    Date: 2022-07-22 08:39
What would happen if you activate Byte 8 Bit 1 on your radar?
It may be necessary to reboot 5F.
By the way in Adaptations, Heated lens ---> off.
Limito
Drives: VW Passat
Post by Limito »
Thank you for your support!
Now I have Byte 08: bit 0=1 and bit 1=0 and it means Zul Regelabweichung=Klein. Do you think this could be wrong? I think I have changed it in the past from Gross to Klein.
How do I reboot 5F unit? By rebooting the infotainment system?
Does the 13 unit not include heating?
Draw your conclusions, when I coded my radar the pACC menus appeared immediately on the screen as shown in the first post... with the 'Tolerance' submenu...
Reboot 5F:
Press the ON/OFF button for 10 sec.
Your DPro will reboot from the VW Logo or your boot screen (GTE?).
Our radars, behind the VW Logo on the upper grille, do not have a lens.
I assume that adaptation 'Heated Lens' is for the 'old' radars with a lens that were installed in the lower grille.
In my case, when I set the Tolerance to High, my wife's Golf reacts more friendly/comfortably to the speed of the road, that is, it does the same thing but brakes or accelerates more smoothly, that is my feeling. Then there are also the driving profiles (FPA - MODE button) that also intervene in the reactions of the vehicle systems...
Currently I only use the pACC for long trips and for test runs, sometimes all of these driver assistance systems are crazy or exhausting depending on your own driving style.
Hopefully full autonomous driving will be a reality soon.
Limito
Drives: VW Passat
Post by Limito »
If you set your Tolerance to Low on your car, don't you get the function that if you manually set the speed to e.g. 53 on a 50 road it remembers the difference and automatically increases to 73 on a 70 road?
The fact that you have Tolerance available, I think it is because you have MIB2.5 in your car with newer navigation firmware while I have MIB2. I thought maybe there was an easy way around it.
If I set the Tolerance to Low my wife's golf reacts too early to traffic signals and it does so abruptly and as I say too early.
The drivers of the vehicles following us (traffic conditions) must think that someone with very low abilities is driving our vehicle.
It's really annoying and dangerous, at least where I live. I don't even want to imagine it with the driving styles in Italy or other places where gaining 1cm or 1sg on other drivers is a real victory.🤣
I don't know if with Low Tolerance the system remembers that difference of 3 km/h that you explain when recognizing the new speed of the traffic signals.
Does VW explain it somewhere? I guess not, just like hundreds of other circumstances in their driver assistance systems.
Limito
Drives: VW Passat
Post by Limito »
If you change the Tolerance value in your menu for example from Low to High, can you see that the long coding for Byte 8 is then changed as well? Just to verify that Zul Regelabweichung refer to the same thing?
No, the coding does not change.
On the other hand, I have verified that by setting the Tolerance to 'low' in the menu (submenu) on the 5F screen for pACC, when the camera detects the next speed signal, it remembers the speed differential I set. That is, and for example, from 60+4 it goes to 84 or 44 or 124 Kmph, that is, the system behaves as you commented.
The same does not happen for Medium or High Tolerance, for example, from 64 it goes to 80 or 40 or 120 Kmph.
My settings in 5F Adaptations:
[LO]_traffic_sign_recognition_0x21: [VN]_activated
[LO]_traffic_sign_recognition_0x21_msg_bus: [VN]_CAN_Extended
[LO]_menu_display_Curve_Assist: [VN]_activated
[LO]_menu_display_Curve_Assist_clamp_15_off: [VN]_not_activated
[LO]_menu_display_Curve_Assist_over_threshold_high: [VN]_activated
[LO]_menu_display_Curve_Assist_standstill: [VN]_not_activated
[LO]_menu_display_Curve_Assist_after_disclaimer: [VN]_not_activated
Limito
Drives: VW Passat
Post by Limito »
I have exact the same settings except for:
[LO]_traffic_sign_recognition_0x21_msg_bus: where I have Databus extended instead. I could not find [VN]_CAN_Extended as an alternative. I do not know what it will affect?
However it seems that the Tolerance setting you have available in your menu of some reason is not available or visible in any VCDS settings. For me it seems to be very strange but maybe unfortunately the truth?
I don't know exactly what you mean, however these are the possible codings with the EXPerimental label for VCDS ORIginal.
Note: please do not take into account the coding because I no longer remember when I made these captures or the possible changes I made later, it's better to look at the last autoscan that I posted in my thread.
The EXPerimental VCDS labels for coding contain exactly the same information as the ODIS-E coding (VCP too).
I guess it all depends on the level of vehicle equipment (HW and SW), tools used and their updates, and personal skills/knowledge to handle them.
Maybe I will buy the OBDELEVEN with ULTIMATE pack when the 'smart'phone is a more pleasant and safer device, hmm... Never? :mrgreen: ... 🤣
In the meantime I settle with ODIS (ori), VCDS (fast) and VCP (pro) for my 'routines'.
Limito
Drives: VW Passat
Post by Limito »
Thanks for all information!
I have used ODIS and VCDS in the past (pirate versions because it is what you can afford :)) but is now using OBDELEVEN because it is so fast and simple to use. Plug in the device in your car and connect wireless by mobile in seconds. The app is so simple to use with excellent graphic, automatic logging of every change, unlimited number of cars, cheap etc.
What I was trying to explain was that there doesn't seem to be any VCDS settings how to enable the Tolerance to make it visible in the menu. It may or may not be there, depending perhaps on the version of the navigation firmware being used?
Exactly that, OBDELEVEN does it all for you, so your intellectual/creative abilities are reduced to "00", all neatly packaged.
You do exactly what others tell you to do or think, which is customary in all facets of life of the world we live in today.
Having tools that allow you creativity is sometimes necessary to achieve the desired goal (the smartphone is perhaps the worst of the creative tools 🤭).
Discovering what others did not do in all world is in my humble opinion the most pleasant satisfaction that exists, perhaps it is the most powerful drug of those already known. The excitement is extreme and pleasantly long-lasting... a gift from the Masters of the Universe 😁.
