Washer reservoir leak
littlepolo
Post by littlepolo »
I have the dreaded leak and guess its the seal where the pump motor attaches to the reservoir. I can retain a part fill and everything works but when I fill 100% it leaks down.
Can the seal be swapped out through the front n/a wheel arch liner or is it a bumper off job?
Re: Washer reservoir leak
From long time ago memory, yes, it is possible through the wheel arch liner, never needed to do it, but I did remove the wheel arch liners.
littlepolo
Thanks RUM4MO. I do plan to take the front bumper off later to spray paint it and don't want to repeat the job of removing and replacing it. Will have a fish around under the wheel arch. I'm guessing that the motor to reservoir grommet needs replacing (will see if a good silicone compound might help!)
I'd think that fitting a new grommet should work better at a first time fix.
I did take the front bumper cover off my wife's 2002 Polo because I wanted to remove a headlight assembly and epoxy glue maybe the/a bulb frame support as I needed to get it into the correct orientation so that it was in the correct position while the epoxy hardened - no big issues getting the bumper off, which was handy!
littlepolo
It's not the grommet! New pump ordered to save time on repairing existing and risk of future failure.
littlepolo
There was a leak from the pump itself nearby the pipe union and one of the pipes also had a slight weep at the union. Replaced pump and bonded pipe to union with adhesive.
