Cool!👏👏👏
Once you code the ECU it should work!
kristianvanek
Drives: polo 5
Post by kristianvanek »
Thanks for all the help guys.
Coded to the ecu and then it worked once in the carpark. Couldn't get it to work again but I just think it was cause I couldn't get the speed up. Got to a motorway and it worked fine.
Now I can get all of my interior put back together.
Depending on the country and the VW model (equipment), the operation of the CCS is from 20 or 30 km/h (change to Mph if necessary). See owner's manual.
Enjoy it! 👍
Cheers and we'll done. My first cruise control retrofit took me a full-day back in about 2015. Now I do this stuff for a living and can sometimes manage it within the hour. Enjoy your cruise control.
Ritxi
Drives: Polo 6R
Post by Ritxi »
Hello everyone, first of all thank you very much because without this forum I would have been unable to install the cruise control on my Volkswagen polo 6R 1.6 tdi 90cv. The truth has cost me a lot of work and although I have managed to get it to work if I do a scan with VAGCOM I get errors that I did not have before, they appeared after verifying the connection of the ECU cable that the first time I had not gotten it right at all, I also had a bit of a bend in the tab on the air filter connector, although I don't think that's the problem. I am worried if these failures cause any problem in the car, the car works perfectly and the dashboard does not show any error while driving, the air conditioning also works well. I need your help. Thank you.
I attached a photo of the tab that was bent but I think it works well
Ritxi
Drives: Polo 6R
Post by Ritxi »
Also say that I installed the kufatec kit and following its instructions connect to pin 44 of connector A of the BCM, then I followed your instructions and connected to fuse 11 repairing cable 44 of connector A as it came from series, in case the problem was there. Thanks.
I do not have access to the document. Please share the text as a message
Ritxi
Drives: Polo 6R
Post by Ritxi »
04-Steering Angle -- Status: Correct 0000
08-Air conditioning. -- Status: Fault 0010
09-Electr. -- Status: Success 0000
17-Instruments -- Status: Correct 0000
19-Gateway CAN -- Status: Fault 0010
44-Assisted steering -- Status: Success 0000
56-Radio -- Status: Trouble 0010
Address 08: Air conditioning. (J301) Tags: EST\6R0-820-045-9AP.clb
No. Part No. SW: 6R0 820 045 H HW: 6R0 820 045 H
Component: Climatic 25 0660
Version: 00 11 25
VCID: 336F420E923561D218-8066
1 Fault detected:
01336 - VAG group comfort data bus
014 - Faulty - Intermittent
Fault Status: 00101110
Fault Priority: 6
Failure Frequency: 1
Counter Resets: 210
Time Indication: 0
Address 19: CAN Gateway (J533) Labels:. ST\6N0-909-901-6R.clb
No. Part No. SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 002200
Workshop No.: WSC 124697 483 00190
VCID: 70E58D02A3A31ACA25-8024
1 Fault detected:
Fault Priority: 1
Fault Frequency: 238
Counter Resets: 210
Mileage: 153461km
Time Indication: 0
Date: 2017.01.21
Time: 00:00:05
Ritxi
Drives: Polo 6R
Post by Ritxi »
I'm sorry that I have been misrepresented. I've cleared the bugs and they're back.
Please, post a full VCDS autoscan without using the translator if you don't have the VCDS English version. It doesn't matter what version you have.
We also need to see the faults detected in the BCM, Radio, and other data.
Note:
- Do a new VCDS autoscan, but do not clear intermittent faults.
- If you can't post a full Autoscan here, use a file hosting server and post the link here.
- Keep in mind that the more faults detected, the better to be able to identify the problem.
Besides CCS, have you recently made any other modifications to your 6R? If not, double check all connectors and wires that you 'touched or repaired' due to attempts you made to install them.
Ritxi
Drives: Polo 6R
Post by Ritxi »
The radio speaker faults I had before I installed the cruise control and they only appear sometimes, the rest are all the same fault: 01336.
Even if I erase the errors, they reappear immediately.
The only repair I've done has been to reconnect wire 44 from BCM connector A and I'm pretty sure it's connected correctly.
It is the only recent modification I have made to the car.
OK, understood.
Yes, the diagnosis of faults in the Speakers are common in these Radios/Units, but they are not really faults.
The detected faults (01336), it is a problem related to the positive signal 58d, which is common to the Air conditioning and the Radio, and is responsible for the backlighting of the buttons of both units.
This signal 58d comes from the Dimmer (E102 Headlight range control regulator<), which in turn is powered by fuse SB11.
Check the connections/operations/corrections/repairs you made on the wire of SB11 fuse and T73a/44. (yellow/black wire?)
You can be totally sure that the faults will disappear when everything is correct with this wire.
Thank you very much for posting the link, if it is your wish, you can now remove the Autoscan from the server.
Ritxi
Drives: Polo 6R
Post by Ritxi »
Understood, thank you very much, so the problem is sure in my 73a/44 connection repair.
One question, if I connect T73a/44 directly to the SB11 fuse, would it still solve it? I would work more comfortably with this repair, the only problem is that the cable that comes from E102 would be left unconnected and I don't know if that would cause any failure.
Button lighting works fine:
Ritxi wrote: Thu Sep 01, 2022 10:07 am
Click :arrow: Stop inventing! :lol:
The contact terminal of the wire that reaches T73a/44 must be inserted in T73a/44 in a mandatory way.
It is an MQS contact terminal.
You can easily fix it:
000 979 009 E :arrow: https://www.google.com/search?q=000+979 ... 6&dpr=1.38
f1
This weekend in Zandvoort!!! I hope to see a totally Orange circuit!!!!
Although they don't need it, I wish Super MAX and the Red Bull team the best of luck.
I totally understand Super Lewis and the incident with Super Fernando, I understand both of them, I think they should have managed the cornering a little better for a better final result or first laps... :lol: Both are in the Olympus of the gods, it is a gift for our eyes to see your great achievements, it does not matter in which P the races end.
Super George Russell deserves a win, although I also want a win for Mclaren.
Forza Ferrari!💖
Many thanks to Super Vettel, also the best of luck wherever the wind takes you.
Good luck to all the F1 Super Heroes, teams, drivers, organizers, etc... I follow you all without exception, every detail, You are great!!!
I'm pretty sure it will be a sea of orange in support for McLaren and especially their leaving star driver Danny Ric.
And probably an easy win for the Red Bull team, followed by about half a minute by one or two mercedes cars. Ferrari will find a way to pull a defeat from the claws of victory :mrgreen:
