DSG Paddle shifter removal
zainf7
Drives: Mk5 6R BlueGT
Post by zainf7 »
Hi all,
Has anyone attempted or done a paddle shift replacement?
Bought a set of blue paddle shifters for the BlueGT and I have no idea how to remove the current ones.
Does anyone know how? I can’t find the pin at the bottom to remove it from?
Thanks in advance.
patil
Re: DSG Paddle shifter removal
Post by patil »
Remove airbag, remove steering trim having controls, behind the trim you have screws to remove the paddles.
CarbonChaos
Post by CarbonChaos »
This video is for golf R MK7 but i believe this is the same and you dont need to remove any thing else,this is a guess as ive not done this personally.
https://youtu.be/UJqjwyb8kbk
zainf7
Post by zainf7 »
I just don’t want to disconnect battery, remove airbag and undo current paddles to find out they don’t fit. :(
Also, that video is for Golf R’s and GTI’s. Blue GT’s and older models which don’t have that type of steering wheel don’t have the pin he’s referring to. Well at least mine doesn’t.
zainf7
Post by zainf7 »
Mine looks like this
To be honest, the fastest way is to do as you describe and find out
zainf7
Post by zainf7 »
Checked on Reddit also and basically came to the conclusion it won’t fit.
The grooves in the paddles compared to the OEM paddles are different. :(
