VAG-Abound
- Drives: MY12 Match (plus tinkering...)
I was having problems working out which terminals, stalks, etc to use and whether I had the wiring correct. I could create a thread for every little question, but that would fragment things more so it seemed appropriate to add them somewhere that things were already being asked so people could discover problems they may not have thought about yet. If we don't include the answers it is just a thread of problems that may not help people in the future.
I drafted the last post in a separate document before pasting it to a post, so I won't call it wasted as I can use it elsewhere when needed.
Many thanks to everyone who helped get things working.
Post tidied.
Hello guys,
I have a problem with my cruise control retrofit.
First of all I added new wires according to the diagram below. I pluged the wire from interior into the 69 terminal ECU. Then I used VCDS to code the CCS in the engine tab (byte5) and BCM tab (byte 17).
Now, I'm getting the fault code of the engine module as below.
I checked measuring blocks 004 and it showed that the buttons on the CCS stalks work properly.
Are the wires from t41/2 and t41/3 necessary?
At the same time I was adding stalks with the TRIP button and it works perfectly.
My Polo is 2014 1.2 MPI 59HP CGPB VIN: WVWZZZ6RZEY125786
And here is an auto scan
Users can you help me?
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CGPB) Labels:. 03E-906-019-CGP.clb
Part No SW: 03E 906 019 AK HW: 03E 906 019 B
Component: SIMOS11.1 H03 5151
Revision: --H03--- Serial number:
Coding: 00110016002400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12MIP02103E906019AK 001003
ROD: N/A
VCID: 6DD17FB6BC91F82CC3-8038
1 Fault Found:
6118 - Cruise Control Switch (E45)
P0568 00 [037] - Implausible Signal
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 149214 km
Date: 2100.14.29
Time: 00:01:19
Engine speed: 927.00 /min
Normed load value: 25.9 %
Vehicle speed: 0 km/h
Coolant temperature: 17 °C
Intake air temperature: 16 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.414 V
ENVD_CRU_1: 1
Cruise Control System (CCS): status-STATE_CRU_SWI_1: 00101000
Cruise Control System: specified speed-Vehicle speed: specified: 0.00 km/h
Time since engine start: 0 s
Readiness: 0110 0101
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Serial number: --------------
Coding: 21DD2485212500C5841B2471845700400904
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ES9P0iBOSCH 003020
ROD: N/A
VCID: 0F2D053ED65D6A3C91-805A
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
Serial number: 27101304651630
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOWV25X 005001
ROD: N/A
VCID: 7EF348FAE1F773B46A-802A
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 6R0 820 045 M HW: 6R0 820 045 M
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 387F9EE28B538D84E0-806C
Part No SW: 6R0 937 087 F HW: 6R0 937 087
Component: BCM PQ25 H+4 H46 0221
Revision: BF046001 Serial number: 0345 168101833
Coding: 248829F888A10000002000003C2B94C800C0400F60080140200000000000
Shop #: WSC 64564 324 38760
VCID: 408FF602D383C54458-8014
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8611
Serial number: KU0KU010101300015049
Coding: 0000A0
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8611
Serial number: KU0KU015101300018434
Coding: 1000A0
Address 15: Airbags (J234) Labels:. 5K0-959-655.clb
Component: VW10Airbag022 H10 0020
Revision: -------- Serial number: 003GX01X55Y1
Coding: 003232
ASAM Dataset: EV_AirbaVW01BPAVW250 A01001
ROD: N/A
VCID: 4A9BD42AEDBF0F1486-801E
Subsystem 1 - Serial number: 3575HRB401050MO2BA0P
Subsystem 2 - Serial number: 3585HRB401050MO2E8TD
Subsystem 3 - Serial number: 3515RRB400250NQGF244
Subsystem 4 - Serial number: 3525RRB400Q50NQKQPN0
Address 17: Instruments (J285) Labels:. 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 L HW: 6R0 920 860 L
Component: KOMBI H02 0406
Serial number: 00000018611268
Coding: 140A00
ASAM Dataset: EV_DashBoradUDSJCIPQ25 A01723
ROD: N/A
VCID: 3D718FF6AC71A8AC33-8068
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 6R0 937 087
Component: GW-K-CAN TP20 0221
Coding: 002200
VCID: 70EF66C2A3A315C4E8-8024
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H02 0025
Serial number:
ASAM Dataset: EV_ImmobUDSJCPIQ25 A01003
ROD: N/A
VCID: 6ADB74AA8D7FEF14A6-803E
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11250
Shop #: WSC 00788
VCID: 306FA6C2F72355C4A8-8064
Part No SW: 5M0 035 156 D HW: 5M0 035 156 D
Component: Radio H54 0107
Revision: R0000000 Serial number: VWZAZ1N6397691
Coding: 0000020002
VCID: 2A5BB4AA45FF2F1466-807E
End-------------------------(Elapsed Time: 01:51)--------------------------
Check the white wire that is shown in the diagram below, mainly the T121/69 connection, it is the most common problem.
Please read reasons and/or causes on previous pages.
According to your Autoscan T41/2 and T41/3 are already present in your 6R.
Thank you for your replay.
I have read the whole topic looking for answer.
I have already checked the t121/69 connection a few times. I’m not sure if I used a proper connector for this place. This one below doesn’t fit properly. Can you tell me which one will be good?
I will check the whole white wire as you said.
There are three possible T81 connectors, take a picture of your connector. In some of them the indicated terminals have been replaced by other references.
However, the MQS terminal should work fine for all of them.
No, it's not an MQS vor the 1J0906385C ECU plug.
The terminals are these: https://nl.aliexpress.com/item/4000900028296.html
The OEM reference is 000979018
Which is no longer available according to ETKA.
Let's wait to see the connector to dictate sentence...
My connector is 1S0906385
Then, this would be the Terminal,
but wait for more suggestions.
- Platinum Member
Buy the connector from the scrapyard and extract the wire with terminal, solder your wire to it...
Guys, after few weeks, buying the 000 979 049e terminal and changing it still doesn’t work.
I checked ecu connector, bcm connector, e45 connector and it looks good. I even checked the direction of the diode. I put terminals into proper places.
I don’t know what to do
Did you measure voltage on all pins?
No, I didn't.
How much current can I apply to the terminals?
Can you tell me how to measure it?
What you could do is disconnect the connector you want to measure, in this case ECU.
Then switch on ignition, it will have many warning lights. The wire in question should have 12V when the CC switch on the stalk is set to ON.
That's probably the easiest way to check. Your error indicates that the ECU is not receiving the correct 12V signal when the switch is set. Either it is not receiving 12V (wiring problem) or the wire is in the wrong position.
