Mk6 face lift key cover
MikeDO
Drives: GTI 2022 (white)
Post by MikeDO »
Anyone recommend a key cover that will fit the mk6 face lift?
I've had a look on Ebay and AMAZON and most of them don't look like are for the correct key!
Thanks in advance.
Dark_cze
Drives: AW GTI with MT
Re: Mk6 face lift key cover
Post by Dark_cze »
// Sorry just noticed you asked for facelift key. Iam not sure if it is same key as pre facelift key. My bad.
There is 2 types of this key. Iam gonna call it golf version and Polo version where Gold have key blade rotated by 90 degrees. I had one rubber cover for Golf key and the cover will fit both but the Polo key need extra width for key blade to open which Golf covers tends to miss (the extra space that is needed is visible on the attached photo). Well I cut it of with knife but that left a bit of jagged edge so sharp scissors would probably be better. In the end I managed to find metal case That fits well enough but I can't find it again (again attached the photo of it, it is quite badly beaten up after 4 years). Beware if you find it it is quite heavy since it is really made of metal.
Polo Key.jpg (271.52 KiB) Viewed 1299 times
Golf key.png (95.13 KiB) Viewed 1299 times
KayakerPaul
Drives: R line - if it arrives
Post by KayakerPaul »
These should fit Mike.
We went for blue off ebay, due to the key fob matching our T6.1's . Had to slightly trim the rubber for the key to pop out mind.
Screenshot_20220915-202726_Amazon Shopping.jpg (617.52 KiB) Viewed 1288 times
MikeDO
Post by MikeDO »
Thanks for the replies guys.
I've ordered up the silicon one.
AndyGTi
Post by AndyGTi »
I was meaning to come on and ask about the keys as I thought they had changed.
I had a Golf at start of year and rembembered the key came out at a sideways angle. Thanks @ dark_cze for explaining the differences.
So I bought the VW "GTI" silicon case as well as a another non branded sleeve off Amazon. As described by @dark_cze, I also noticed that the sleeve had a section which stopped the key opening for operation. I used some sharp scissors and this has done the trick and have cut away the section and now can use the key
Andy
Dark_cze
Post by Dark_cze »
AndyGTi wrote: Sat Sep 17, 2022 11:41 pm I was meaning to come on and ask about the keys as I thought they had changed.
Andy
Iam happy that it helped. :)
MikeDO
Post by MikeDO »
My silicon key cover turned up this morning.
Not that impressed.
It fits a bit floppy. Just the way that the pop out key works I suppose restricts how it can be made. I had sort of thought that the material that it was made of would be slightly more rigid. Though I suppose if it was, then you would not be able to press the buttons. Maybe I will just leave it "naked"?
