Immobiliser blocking start
littlepolo
Post by littlepolo »
I had this problem a few times in recent months and decided to examine the instrument cluster for any dry joints. On removal and inspection of the cluster I could not see anything obvious but re-flowed the rightmost joints on the PCB data connector and some of the leftmost side too. Of course, the immobiliser had reset in the meantime. Will update if the problem recurs.
spacewalker
Drives: Just a VW
Re: Immobiliser blocking start
Post by spacewalker »
main questions is :
immo problem
or key not find problem
littlepolo
Yes. Spare key did not work either.
spacewalker
Drives: Just a VW
if spare key not working = you have that issue always
not just few times what you said - always
immo (ecu + cluster) is working ok
littlepolo
So it's an issue with the chip in they keys?
The Polo is a 2002 model.
spacewalker
Drives: Just a VW
littlepolo wrote: Thu Sep 22, 2022 12:32 pm So it's an issue with the chip in they keys?
chip/ coil / immo obnx / cluster
