(SOLD) Polo 6R auto light & rain/light sensor kit + retrofit harness, 140 € (SOLD)
SanketM
Drives: VW Polo 1.0 TSI Highline Plus
Re: Polo 6R auto light & rain/light sensor kit + retrofit harness, 140 €
Post by SanketM »
I am interested, but is there anyway for me to make it compatible with the Indian Polo 6R?
Many Thanks,
Sanket
I don't see any reason why it shouldn't fit your indian 6R.
sparrow77
Drives: 2013 1.2TSI BlueMotion 5spd
Post by sparrow77 »
SanketM wrote: Thu Sep 22, 2022 9:04 pm Hi,
Many Thanks,
Sanket
Should be totally fine. Send me a PM if interested :)
SanketM
Post by SanketM »
sparrow77 wrote: Fri Sep 23, 2022 7:42 am
Many Thanks,
Sanket
As I am new to the forum, I don't have enough posts to have access to send PMs. Can we please discuss this over the e-mail? You can pass me your email or can send one to my id xxx
Thanks,
Sanket
SanketM
Post by SanketM »
iichel wrote: Thu Sep 22, 2022 9:28 pm I don't see any reason why it shouldn't fit your indian 6R.
Hi iichel,
Thanks for the assurance. (y)
Regards,
Sanket
sparrow77
Post by sparrow77 »
SanketM wrote: Fri Sep 23, 2022 8:22 am
Many Thanks,
Sanket
As I am new to the forum, I don't have enough posts to have access to send PMs. Can we please discuss this over the e-mail? You can pass me your email or can send one to my id - xxx
Thanks,
Sanket
No worries, I sent you an email.
I took the liberty of editing your posts to remove the email address. It's a great way to receive spam emails.
SanketM
Post by SanketM »
iichel wrote: Fri Sep 23, 2022 9:01 am I took the liberty of editing your posts to remove the email address. It's a great way to receive spam emails.
Thank you, it was very thoughtful of you :). I would be lying if I say that thought didn't cross my mind while sharing it.
SanketM
Post by SanketM »
Hi iichel and Ciclo,
I am about to purchase the automatic headlight harness and the auto headlight switch from Patrik. Just wanted some help from you'll to understand if it would fit my car or if I would need to do some alteration to it, I know iichel has already confirmed that it shouldn't be an issue, but I have some more details to share regarding my 6R's hardware which weren't known to me prior to my initial query.
It's an MY21 model, Dec 2020 Production date.
VIN: MEXM20609MT11XXXX
BCM
Headlight Switch
Headlight Switch -1.jpg (293.49 KiB) Viewed 13191 times
Headlight Switch -2.jpg (267.52 KiB) Viewed 13191 times
Relay Carrier (I couldn't get the right side dashboard panel to open, so i tried to make a video from the headlight switch's location)
[youtube]https://youtube.com/shorts/9c-cTFzbJLY[/youtube]
Also, I have got the RLS sensor and Auto dimming mirror installed from the factory. Unfortunately, I don't have a VCDS cable with me to provide the log. :(
Many Thanks,
Sanket
Wiring compatibility:
- For 6R models with BCM Max from factory.
Your car does not meet this requirement
SanketM
Post by SanketM »
Would that adaptation be something that can be done by me after purchasing the existing loom ?
Best Regards,
Sanket
You could consider retrofitting a BCM max with all the effort that comes with that (wiring, coding)
SanketM
Post by SanketM »
Thank you iichel for clearing that.
Actually, I wouldn't mind taking that route and installing the BCM Max. Would there be any guide or reference to do that?
Regards,
Sanket
Yes, just search the 6R/6C forum for BCM max retrofit. There are a decent number of people who did it. Usually with guidance from ciclo but I'm unsure if he still provides wirings or support for these retrofits. It's quite labour intensive.
SanketM
Post by SanketM »
Thanks iichel,
I'll go through the BCM Max installation threads on the forum. And also check with Ciclo if he could spare a few minutes to guide me with BCM max wiring creation.
Thanks & Regards,
Sanket
