DPF Light, Eng Managment Ligh, and Flashing Glow Plug Light
Discuss Engine, Gearbox and Exhaust
Harryb0807
Drives: 6R 1.2 TDI Bluemotion
Post by Harryb0807 »
Currently got a 6R 1.2 TDI BlueMotion with the following Lights on dash:
  • Flashing Glow Plug Light
  • Engine Management Light
  • DPF Light
I have had it plugged in with 2 error codes, one being a P0238: "Manifold Pressure - Boost Sensor (G31) - Sig Too High" and the other relating to the DPF.
Currently looking at the DPF Differential sensor being faulty or trying a DPF Cleaning Service, are there any other suggestions before I go ahead with these?
Re: DPF Light, Eng Managment Ligh, and Flashing Glow Plug Light
What exactly is the other error regarding the DPF?
Harryb0807
I haven’t got the exact error code on me at the moment but it was relating to the accumulation of soot I believe.
Also took this picture from the plug in if it’s helps Image
Negative soot masses do not sound plausible to me
Harryb0807
Yeah I thought so to, I think I am going to replace the differential sensor first and go from there.
Does anyone know where I can get the part number for this?
It's written on the old sensor
