So not exactly a rattle, difficult to describe but sort of the sound from lifting your finger off a sticky surface or 2 leather pieces rubbing together. This is what I'm hearing while driving. Its coming from somewhere on the front passenger side. This occurs when car shifts sideways as opposed to up and down on a bumpy road, and also its not constantly making the noise like a regular rattle would.
Things that I can rule out:
- handbrake rattle
- passenger visor
- glove box
- all knobs in the centre console
- loose items in storage areas
- sunroof
- seats (I have the semi leather/alcantara and cannot find anything rubbing on them, no luggage in the car, no passengers)
Do you guys know of any possible culprits? Definitely passenger side
Passenger side cabin rattle/noise
Re: Passenger side cabin rattle/noise
The source of unwanted noises in the interior of a car can often be very difficult to find, as they can sound as if they’re coming from a specific location but they’re actually coming from somewhere completely different.
If you’ve not already done so, I’d suggest taking a passenger out in your car with you to try and locate the noise source while you’re driving. They can be that extra pair of ears and they can also move around to different areas of the car interior and listen up close to areas where you think the noise might be coming from while you concentrate on driving. They can also potential apply pressure to various interior trim pieces around the cabin that might be the cause. Alternatively, if your car insurance allows other people to drive your car, you could get someone else to drive while you do the listening and apply pressure to the interior trim.
Good luck; I hope you find it - those unwanted noises can be really irritating, and spoil the car ownership experience.
- PO10ASH
- Drives: POLO GTI+
Oh don't, I've been searching a rattle for the last month that I thought was behind the dash, turns out it was the plastic between the windowscreen and mirror.
I would definately recommend getting a friend to drive your car (insured) and poking things, or get a friend to poke things while you drive.
Hi, Did you ever get to the bottom of this issue? As my GTI is making the same the noise.
ad_182_uk
- Drives: 19plate AW GTI+ / (9n3 GTI gone)
Probably not the same as the issue you are having but i had what i thought was either a speaker or metalic rattle from passanger side door card.
Took the doorcard off today and kid you not it appears the noise was a sticker round some wiring that was not fully stuck to itself. But some extra duty tape round it and no more noise.
Time will tell if it remains quiet.
beetle274
- Drives: 2021 R Line
Had the same problem with my Up GTi....turned out to be the sunroof....I lubricated the seals and surroundings (at least as much as I could reach!) with a product called 'Gummi Pflege Stift'...worked a treat!!
My new polo also has this same noise. I didn’t have then all of a sudden it’s appeared. I’ve whacked and picked all sorts I can’t work it out. It’s driving my insane.
Unwanted interior cabin noises can be notoriously difficult to track down - the often originate from a somewhere completely different to where you think the noise is coming from.Polo72 wrote: Sat Dec 03, 2022 11:20 am My new polo also has this same noise. I didn’t have then all of a sudden it’s appeared. I’ve whacked and picked all sorts I can’t work it out. It’s driving my insane.
Always best to take a passenger out in the car as they can be a second pair of ears. They can also poke and apply pressure to any pieces of trim you suspect might be the cause of the noise while you concentrate on the driving.
Definitely I think it’s going to take some finding. I wasn’t sure weather to ask the dealer to sort it but I kinda of think they won’t be interested as it’s not causing a use issue really
I’d be extremely reluctant to let a dealer attempt to find and fix an unwanted cabin noise. The prospect of dealership techs ripping out pieces of interior trim (and the potential damage they may case in the process) isn’t something I’d want to subject my car to.Polo72 wrote: Sat Dec 03, 2022 1:55 pm Definitely I think it’s going to take some finding. I wasn’t sure weather to ask the dealer to sort it but I kinda of think they won’t be interested as it’s not causing a use issue really
In addition to risk of them not curing the original cabin rattle / noise, there’s a good chance they’ll create new ones!
Yeah I kinda agree with you on that. It’s something id rather find my self of live with. I don’t rate much to dealer mechanics I’m not saying they are all bad because some will be very good but from past experiences I question some of them.
