Polo 6R - Sanket's 1.0 TSI
SanketM
- Drives: VW Polo 1.0 TSI Highline Plus
Hi Guys,
Recently I purchased an Amarok MFA+ cluster. and after connecting to my Polo 6R the immobiliser got active and it cleared my ABS coding. After reinstalling my stock cluster, I was getting ABS and traction control lights, After adding a new coding via a Bluetooth OBD connector. I added a ABS coding and now just the Traction control light is being displayed and one error persists saying something like "ESP basic Settings" which gives me doubt about the ABS coding isn't the right one.
I don't have a VCDS cable with me else I would have attached the whole scan along with the post. From what I have been able to gather I have an ESP 9 ABS module.
Could anyone please help restore the original coding?
Re: Polo 6R - ABS Coding Wipped off.
Sounds like your coding is fine and you need an obd scanner to finish basic settings of the esp unit.
SanketM
Thank you iichel, For coming to my rescue. I'll try and an obd scanner and try to completed the required setting. Could you please help me understand what I should be doing to resolve the issue ?
Start the engine, access the module with your scanner, security access 40168 (from memory), press the brake hard and releasy, basic settings, ESP function test or basic settings for ESP. The exact wording differs from scanner to scanner so I'm unsure.
SanketM
Thank you so much,
I'll try this over the weekend. Hopefully it resolves the issue and I finally have the cruise control working
Many Thanks,
Sanket
Many Thanks,
Sanket
SanketM
Re: Polo 6R - Sanket's 1.0 TSI
Hello Guys,
With the help of Aditya, I recently upgraded my polo's BCM from 087S to BCM Max 090E. I had purchased BCM Max used from Poland, and while doing the upgrade I encountered key adaptation issue which so many other people have reported, adaptation Channel 1 wasn't available. I went through all the topics on this forum as well as posts on other forums, but couldn't get the issue fixed by myself.
Eventually I ended up at local locksmith who does duplicate spare keys. He worked on the car for 5 mins using his Xtool x100 pad and got my original key adapted.
If anyone who is in similar situation, please try out key adaptation with any of the key programmers before buying a new BCM Max probably that would work for you'll too.
Thanks to Aditya for all the support that he has been providing and special thanks Fernando who discovered the possibility of BCM MAX upgrade and made it accessible to all.
Regards,
Sanket
Regards,
Sanket
Hi, we sincerely appreciate your report.
Thank you so much.
Thank you so much.
Nice one, Sanket.
Enjoy
Enjoy
Well done!
SanketM
Thank you for your kind words guys
I have learnt a lot while going through this forum, Just trying to give back whatever little that I learn.
As of today, I am in a soup. I had purchased a BCM Max wiring locally and tried installing it myself over the last two weekends. I did finish the BCM Max installation yesterday and then went on to install auto headlight wiring which I had purchased from our fellow member sparrow77.
After completing the installation, when I connected the battery terminal. My Right side low beam came on when I connected the battery terminal.
But good news
1) The car is Starting
a relief for me considering it was my first time taking on something of this nature installation. Of course learnt numerous things while carring it out. Damaged a few butt connectors broke a MQS Terminal and repaired it due to unavailability if it around the place I stay. (I'll replace this asap)
2) As soon as I put headlight switch to Auto, the low beams came on. Tail light, turn signals, and front fogs work fine. (Didn't get to check then SCL)
Issue which I am currently present
1) The right side low-beam remains on after locking the car. I have to remove the battery terminal to stop it from draining battery(task successfully ac).
2) The rear fog light also comes on as soon as I put the headlight switch to the parking light.
3) Both HighBeams don't come on.
4) Driver side power window switch seems to be inverted If I pull up the button meanT for fronT passenger window it ends up executing that command on driverside window and vice versa. (powerwindow switches on other doors work perfectly well)
5) As soon as the headlight switch is moved to parking, the Instrument cluster and Discover media buttons light up fine so do the MFSW button backlights. But backlight for door buttons doesnt come on.
6) HighBeam comes on when the light Stalk is pulled to flash. It also appears in the cluster when its pulled. But when its push to turm the high beam on it doesnt come up doesnt come up in cluster too.
Note: Dimmer connector T6/3 has been attached but the dimmer switch is in transit and will reach me by mid of this month
I am attaching autoscans with BCM High and BCM max.
Auto-Scan with BCM High
Auto Scan with BCM MAX (I am in the process of fitting rear discs. I had to change my rear axle like how Patil Sir had to do, Unfortunately the wheel hubs which came with the rear axle werent compatible with ABS Setup hence rear abs sensor had to be taken out(This has caused fault codes to appear under Engine, Auto Trans and ABS controllers.))
I'll really be gratefull if any of our gurus pull me out of this soup.
Many thanks,
Sanket
But good news
Wednesday,29,November,2023,23:35:02:00009
VCDS Version: 23.3.0.0
Data version: 20230228 DS346.1
Chassis Type: 60-VW25 (6RU)
Scan: 01 02 03 04 08 09 15 17 19 25 37 44 56 5F 77
VIN: MEXM20609MT114948 Mileage: 35140km-21834miles
37-Navigation -- Status: Not registered 0001
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Not registered 0011
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-DSHA) Labels: None
Part No SW: 04C 906 026 CJ HW: 04C 907 309 AG
Component: R3 1.0l TFS H22 1621
Revision: WTH22--- CVN: FCB89011
Coding: 001A0012232410000000
Shop #: WSC 07726 005 1048576
ASAM Dataset: EV_ECM10TFS01104C906026CJ 002003
ROD: EV_ECM10TFS01104C906026CJ.rod
VCID: 6BD572AB8285F9CB06-803E
VINID: 755A1D08018025D901044244208FC59082
1 Fault Found:
17158 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 158 FB HW: 09G 927 158
Component: AISIN AG6 G3 202 3724
CVN: AC17BF15
Coding: 0000000000000000010000000000000000000000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_TCMAQ250031 003021
ROD: EV_TCMAQ250031_003_VW25.rod
VCID: 78FF5DE7C3D34253FB-802C
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Serial number: --------------
Coding: 62DD2463422403C4461D246D4259C0800808
Shop #: WSC 12345 123 12345
VCID: 000F35079B030A93C3-8054
Serial number: 09092013470170
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C63B1-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 4189F003D889C39B8C-8014
Part No SW: 6RU 937 087 S HW: 6RU 937 087 S
Component: BCM IM H+4 H43 0471
Revision: BZ043001 Serial number: 4201 312200077
Coding: 3AB02BFF08A10000013800006E2B069000C0600F608E0100220000000A00
Shop #: WSC 124697 483 00190
VCID: 72EB6FCFADAF2803C5-8026
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 030720 05 50 0106
Coding: 0368DD
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13202848200915172242
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849200915195602
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 2532005083600332AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13102728200824232744
Subsystem 6 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13202729200825011617
Address 15: Airbags (J234) Labels:. 6C0-959-655.clb
Part No SW: 6C0 959 655 Q HW: 6C0 959 655 Q
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003FZAEVZ14J Dataset Number: V03935319CK 0001
Coding: 880000000000000054000000008000000065
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_VW25.rod
VCID: 4189F003D089C39B8C-8014
No ASAM data for: "EV_AirbaVW12TS6VW25X" (VW25)
Part No SW: 6RF 920 861 F HW: 6RF 920 861 F
Component: KOMBI H01 5014
Coding: B10A000000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05735
VCID: 4E93DB3F11D72CE301-801A
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 6RU 909 901 HW: 6RU 937 087 S
Component: GW-K-CAN TP20 H43 0471
Revision: BZ043001
Coding: 002300
VCID: 193978631099BB5B24-804C
Component: IMMO H01 5014
Serial number:
VCID: 6ADB77AF8D7FE0C37D-803E
Address 37: Navigation
Cannot be reached
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Dataset Number: V03935277QZ 0001
Coding: 0001000000000000
ROD: EV_SteerAssisNSK_014_VW12.rod
Address 56: Radio
Cannot be reached
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 F HW: 5C0 035 680 F
Component: MU-S-N-ER H44 0480
Serial number: -------------- Dataset Number: V03935270BD 0001
Coding: 06330701BE00000011110001000808031F0100D400200100CF
Shop #: WSC 131071 1023 2097151
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 244759972FDBF6B387-8070
9 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 52
Voltage terminal 30: 12.5 V
Status_Software_Version_Management-module_name: S
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [009] - Missing Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 52
System_Software_Error-SW_Status_Consistency: 04 01 01
System_Software_Error-SW_Status_Device: o
U1101 00 [009] - Active
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 28004 km
Date: 2023.05.27
Time: 00:55:31
Voltage terminal 30: 12.3 V
0518 - Front Right Treble Speaker
B1064 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 0 km
Voltage terminal 30: 12.4 V
0523 - Front Left Treble Speaker
B1061 13 [008] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 0 km
2565 - GPS Antenna
B1054 13 [009] - Open Circuit
3077 - Telephone baseplate
B1051 13 [009] - Open Circuit
Voltage terminal 30: 10.9 V
7178 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 2
Mileage: 28004 km
Date: 2023.05.27
Time: 02:29:15
BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 77: Telephone
Cannot be reached
Sunday,04,February,2024,20:21:42:00009
\Mileage: 37490km-23295mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 37 44 5F 77
VIN: MEXM20609MT114948 Mileage: 37490km-23295miles
02-Auto Trans -- Status: Malfunction 0010
2 Faults Found:
U0416 00 [039] - -
Fault Priority: 6
Fault Frequency: 1
Mileage: 37493 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 51 °C
Intake air temperature: 39 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 11.800 V
Acceleration: 0.000 m/s²
Cruise Control System (CCS): status-Bits 0-7: 2
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Accelerator pedal travel: 0.00 %
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [039] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 37493 km
Date: 2024.02.04
Time: 00:00:17
Outside temperature: 215 °C
Absolute intake pressure: 100 kPa abs
Engine torque: 0.0 Nm
Fuel: tank fill level: 0.0 l
Oxygen sensor B1: sensor 1: specified value: 8.4106
Intake camshaft B1 active operating state-Bits 0-7: 0
Overrun cut-off-Bits 0-7: 0
Readiness: 1110 0001
CVN: AC17BF15
2 Faults Found:
22970 - Implausible Data Received from ABS Control Module
U0415 00 [043] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:12:50
Engine RPM: 0.0 /min
Transmission input speed: 0 /min
Transmission output speed: 0 /min
Engine torque: 0 Nm
ATF temperature: 54 °C
Accelerator pedal position: 0.0 %
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
Lock Up Clutch: Open
Electrical Oil Pump target revolution: 65534 /min
Electrical Oil Pump actual revolution: 65279 /min
Engine Speed signal Current: 65279 /min
Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
Electrical Oil Pump target current: 65278 mA
22971 - Implausible Data Received from ABS Control Module
U0415 00 [043] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:12:50
Engine torque: 0 Nm
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
5 Faults Found:
0021 - Brake Switch (F)
P0703 00 [008] - Electrical Malfunction
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 37493 km
Date: 2024.02.04
Time: 00:12:50
0374 - Rear Left Wheel Speed Sensor
C101C 01 [137] - Electrical Failure
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:12:50
0384 - Rear Right Wheel Speed Sensor
C101D 01 [137] - Electrical Failure
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:12:50
0394 - Rear Left Wheel Speed Sensor
C101C 01 [129] - Electrical Failure
MIL ON - Not Confirmed - Tested Since Memory Clear
0395 - Rear Right Wheel Speed Sensor
C101D 01 [129] - Electrical Failure
Coding: 01
Revision: V0000000
1 Fault Found:
00457 - Central Electronics Control Module / BCM (J519)
013 - Check DTC Memory
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:06:24
Part No SW: 7E0 937 090 E HW: 7E0 937 090 E
Revision: B9084001 Serial number: 2502 306190003
Coding: 3AB02BB848A3000001380FB07CEB9E901BC0614F60AC2000200000020800
VCID: 2D51BCB3741137FB58-8078
Coding: 0368DD
Coding: 240000
3 Faults Found:
00886 - Turn Signal Switch (E2)
008 - Implausible Signal
Fault Status: 01101000
Fault Priority: 2
Fault Frequency: 8
Reset counter: 71
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:06:59
01502 - Bulb for Rear Fog; Left (L46)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:06:59
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Priority: 3
Fault Frequency: 8
Reset counter: 71
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:07:24
1 Fault Found:
1111301 - ROD - Unknown Error Code
- 00 [009]
Fault Priority: 6
Fault Frequency: 6
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:07:23
Part No SW: 6R0 920 870 F HW: 6R0 920 870 F
Component: KOMBI H04 0729
Coding: 140A00
Shop #: WSC 00788 648 00255
VCID: 387F9DE7835382533B-806C
1 Fault Found:
13654544 - Databus
U1121 00 [008] - Missing Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 110
Mileage: 37493 km
Date: 2024.02.04
Time: 00:12:50
Part No SW: 7E0 909 901 HW: 7E0 937 090 E
Revision: B9084001
Coding: 002300
VCID: 68DF0DA79B73D2D36B-803C
Component: IMMO H04 0729
Serial number:
Cannot be reached
2 Faults Found:
0067 - Terminal 30
U140A 00 [008] - Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 110
Voltage terminal 15: 11.082 V
Voltage terminal 30: 11.706 V
Vehicle speed: 50 km/h
Status: Initialization
0182 - Power Supply Terminal 15
P3325 00 [008] - Implausible
Fault Priority: 4
Fault Frequency: 2
Reset counter: 110
Mileage: 37493 km
Date: 2024.02.04
Time: 00:12:50
Voltage terminal 15: 11.415 V
Voltage terminal 30: 12.110 V
Status: Wait
Coding: 0262000EBE0000005111000101080A001F0100D601200100CE
Shop #: WSC 12345 102 209715
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 EA HW: -----------
Component: MRM2 2024 --- 2110
8 Faults Found:
B201A 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:06:21
Voltage terminal 30: 13.7 V
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:21:21
Voltage terminal 30: 12.6 V
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:06:21
2571 - Navigation System
B126C F2 [008] - Navigation Database not Enabled
Fault Priority: 6
Fault Frequency: 14
Reset counter: 111
Mileage: 37493 km
Date: 2024.02.04
Time: 00:20:47
2565 - GPS Antenna
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:06:21
6720 - Rear View Camera
B1102 31 [009] - No Signal
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:00:56
Voltage terminal 30: 13.4 V
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:06:23
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 37493 km
Date: 2024.02.04
Time: 00:06:21
Cannot be reached
End-------------------------(Elapsed Time: 03:12)--------------------------
Sunday,04,February,2024,22:12:32:00009
www.Ross-Tech.com
VIN: MEXM20609MT114948 License Plate:
2 Faults Found:
40572 - Voltage Supply 1 for Control Module
U3501 00 [038] - Too Low
Fault Priority: 2
Fault Frequency: 1
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:12
Coolant temperature: 56 °C
Intake air temperature: 47 °C
Voltage terminal 30: 8.620 V
Outside temperature: 28 °C
Fuel: tank fill level: 17.0 l
Oxygen sensor B1: sensor 1: specified value: 1.0000
U1017 00 [039] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 37493 km
Date: 2024.02.04
Time: 00:03:17
Voltage terminal 30: 9.060 V
CVN: AC17BF15
2 Faults Found:
U0415 00 [043] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:03:17
Engine torque: 0 Nm
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
U0415 00 [043] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:03:17
Engine torque: 0 Nm
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:03
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:03
Coding: 01
Revision: V0000000
2 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:02:08
00532 - Supply Voltage B+
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:03:03
Coding: 0368DD
Coding: 240000
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:03:19
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 111
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:02:34
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 37493 km
Time Indication: 0
Date: 2024.02.04
Time: 00:02:06
Coding: 140A00
1 Fault Found:
13635840 - Supply voltage
U1011 00 [009] - Voltage too Low
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:03
Revision: B9084001
Coding: 002300
Serial number:
Cannot be reached
Data carrier:
7 Faults Found:
1537 - Supply voltage
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:03
Voltage terminal 30: 8.5 V
1539 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:08
B201A 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:03
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:03:53
Voltage terminal 30: 8.9 V
Fault Priority: 4
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:03
Fault Priority: 6
Fault Frequency: 1
Reset counter: 111
Mileage: 37493 km
Date: 2024.02.04
Time: 00:03:25
2565 - GPS Antenna
Fault Priority: 4
Fault Frequency: 1
Reset counter: 71
Mileage: 37493 km
Date: 2024.02.04
Time: 00:02:03
Cannot be reached
End-------------------------(Elapsed Time: 02:59)--------------------------
Many thanks,
Sanket
I've taken a quick look at your scans, but I'll take a closer look as soon as I can (BCM coding needs to be modified).
To advance in a task, check that adaptation channels 53 and 54 of your 'new BCM Max' have the value "0", if they are "1" change them to "0".
SanketM
Thank you Fernando for chipping in. I'll try these adaptation channels as the first thing in the morning.
As a starting point, I know that you have an Automatic light wiring that I manufactured, compatible for all POLO 6R in the world as long as the appropriate conditions are met.
Since I don't know anything about the BCM Max Adaptation wiring that you installed, please post a link to the installation guide for this Adaptation wiring, even if it is an installation guide that I made.
I know that VW introduced some improvements in the electrical installation of your Model Year 'M' 2021, so it will also facilitate our help/assistance if you post an image of the Original and/or Current fuse box. Also from the relay area.
I make a 'Provisional/Experimental' BCM coding for your 6R 'to know what is right or wrong'... this provisional coding will be modified later if necessary.
3AB02BB848A30000013806B07CEB9E901BC0614F60AC2101200000020000
Please test it and report, thanks.
There will be several permanent failures/faults/issues because it is 'essential' that you install the missing parts (dimmer, rear ABS sensor,...) and replace broken/bad contact terminals.
Take it easy, when possible for you!
The faults related to your DM (Rad/Nav/Tel) you already know need CP removal. I don't know if this is currently possible/allowed.
Window switches, under observation.
PS1: Since you are involved in several mods, do not abuse the battery while you cannot drive the car so that it can recharge, or use a battery charger to recharge it from time to time.
PS2: It would be a luxury for us to have an Autoscan with the factory/original BCM High coding, that is, without modifications/untouched, or the oldest one you have, this way we could fine-tune the current BCM Max coding.
PS3: It looks good, I think everything will be solved.
Sanket, Could you please elaborate on this part? Are the localized (Indian) wheel hub not compatible with the old axel?SanketM wrote: Sun Feb 04, 2024 5:12 pm
SanketM
Firstly My sincere apologies to Fernando and Mayur. Things going on in my professional life are having very bad impact on my personal life and I was struggling to find time for myself and the car. Thinking & planning about the retrofits to my little polo is the only thing that is keeping me sane during this time. Please accept my sincere apologies for not being able to respond sooner.
Link to the BCM MAX Adaptation wiring. https://drive.google.com/file/d/1IV7PIL ... drive_link
Stock FuseBox After BCM Max Adaptation Relays After AWL adaptation I had tried the BCM coding which you had mentioned doing and fixing one loose pin from the BCM connector the lowe beams where working fine. but High beam weren't working. And the right side low beam used to remain on.
With the help of Aditya, It was found that I made a schoolboy error or assumed the I/P & O/P pins for fuse 39 and 34 to follow the same direction as for fuse 44. (While installing bcm max wiring I had first installed the fuse 44 wiring). and that was causing the right headlight to be always on even after turning the car off. Once I got the terminals from Aditya for fuse box I fixed these mistakes which I had made and also fixed the T17/17 terminal. After this, The headlight features are working fine. Aditya also helped me with this new coding : 3AB02BB848A10000013806B07CEB9E901BC0614F60AC2101200000020000
Rear fog light issue also got resolved after swapping the dimmer wire with the butt connector wire. There was a mistake in the BCM Max Adaptation wire.
On the Auto headlight front, they have been working fine since fixing the loose BCM connector. CH.LH all are working perfectly fine.
Now some issue have remained: Light Switch Connector's ambient light for Parking light and Low Beam doesn't glow. The same also happens for the OVRM Switch, power window switch front driver side their ambient light dont glow and their functions have got inter changed. When I move the Switch to fold mirror it actually opens the mirror and moving it to R or L or 0 it closes the mirrors. Front Right and Left Power windows buttons from are working on opposite mirrors.
But Rear Power window switches work fine even from the drive side master power window switch
Another peculiar thing which I noticed was once I have cleared DTC only DTCs related to ABS and MIB2 remains. i.e Engine, Auto Trans, ABS Module and Information Electr. But as soon as I put on AC there are more errors which get added.
I am waiting for my dimmer to arrive and have also requested Aditya to help me out with dimmer if he has to test the set up. And if that fixes these remaining issues. Hopefully they do
Earliest Auto Scan which I could find before fitting the MIB2 I didn't have and VCDS cable with me. Currently Aditya has lent me his old cable.
Lastest Auto Scan
Always indebt to the help which I have received from everyone.
I had checked channels 53 and 54 they were both set to 0.ciclo wrote: Sun Feb 04, 2024 8:39 pm I've taken a quick look at your scans, but I'll take a closer look as soon as I can (BCM coding needs to be modified).
The quality of the components used in the AWL wiring harness is something else. I am lucky to have found the AWL harness which you had manufactured.ciclo wrote: Mon Feb 05, 2024 4:17 am As a starting point, I know that you have an Automatic light wiring that I manufactured, compatible for all POLO 6R in the world as long as the appropriate conditions are met.
Window switches, under observation.![]()
CVN: AC17BF15
Coding: 01
Revision: V0000000
Coding: 0368DD
Coding: 240000
Coding: B10A000000
Revision: BZ043001
Coding: 002300
1 Fault Found:
000 - -
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 35144 km
Time Indication: 0
Date: 2023.11.29
Time: 23:37:13
Serial number:
Cannot be reached
Address 56: Radio
Cannot be reached
6 Faults Found:
B201A 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 35144 km
Date: 2023.11.29
Time: 23:37:13
Voltage terminal 30: 11.8 V
Fault Priority: 4
Fault Frequency: 1
Reset counter: 71
Mileage: 35144 km
Date: 2023.11.29
Time: 23:37:13
Voltage terminal 30: 11.6 V
2565 - GPS Antenna
Fault Priority: 4
Fault Frequency: 1
Reset counter: 71
Mileage: 35144 km
Date: 2023.11.29
Time: 23:37:13
Fault Priority: 4
Fault Frequency: 1
Reset counter: 71
Mileage: 35144 km
Date: 2023.11.29
Time: 23:37:13
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 35144 km
Date: 2023.11.29
Time: 23:37:15
Fault Priority: 6
Fault Frequency: 1
Reset counter: 71
Mileage: 35144 km
Date: 2023.11.29
Time: 23:37:13
Cannot be reached
End-------------------------(Elapsed Time: 03:37)--------------------------
Mileage: 37910km-23556mi Repair Order:
VIN: MEXM20609MT114948 Mileage: 37910km-23556miles
2 Faults Found:
U0416 00 [039] - -
Fault Priority: 6
Fault Frequency: 1
Mileage: 37916 km
Date: 2024.02.18
Time: 18:09:56
Coolant temperature: 98 °C
Intake air temperature: 60 °C
Voltage terminal 30: 12.180 V
U1017 00 [039] - -
Fault Priority: 2
Fault Frequency: 1
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:48
Engine RPM: 977.50 /min
Normed load value: 12.5 %
Coolant temperature: 96 °C
Intake air temperature: 58 °C
Voltage terminal 30: 13.700 V
Outside temperature: 35 °C
Absolute intake pressure: 35 kPa abs
Engine torque: 14.2 Nm
Fuel: tank fill level: 10.0 l
Intake camshaft B1 active operating state-Bits 0-7: 1
CVN: AC17BF15
2 Faults Found:
U0415 00 [043] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:48
Engine RPM: 985.5 /min
Transmission input speed: 970 /min
Engine torque: 128 Nm
ATF temperature: 85 °C
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
U0415 00 [043] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:48
Clutch_C1: Open
Clutch_C2: Open
Clutch_C3: Open
Clutch_C4: Open
Clutch_B1: Open
Clutch_B2: Open
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:48
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:48
Coding: 01
Revision: V0000000
1 Fault Found:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 87
Mileage: 37916 km
Time Indication: 0
Date: 2024.02.18
Time: 18:12:00
Coding: 3AB02BB848A10000013806B07CEB9E901BC0614F60AC2101200000020000
Coding: 0368DD
Coding: 240000
1 Fault Found:
Fault Priority: 3
Fault Frequency: 13
Reset counter: 87
Mileage: 37916 km
Time Indication: 0
Date: 2024.02.18
Time: 18:12:00
1 Fault Found:
- 00 [009]
Fault Priority: 6
Fault Frequency: 13
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:12:00
Coding: 140A00
Revision: B9084001
Coding: 002300
Serial number:
Cannot be reached
Data carrier:
7 Faults Found:
B201A 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:47
Voltage terminal 30: 13.6 V
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:10:51
Voltage terminal 30: 13.5 V
Fault Priority: 4
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:47
Fault Priority: 6
Fault Frequency: 1
Reset counter: 127
Mileage: 37916 km
Date: 2024.02.18
Time: 18:10:17
2565 - GPS Antenna
Fault Priority: 4
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:47
U1111 00 [009] - -
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:50
Fault Priority: 6
Fault Frequency: 1
Reset counter: 87
Mileage: 37916 km
Date: 2024.02.18
Time: 18:03:47
Cannot be reached
End-------------------------(Elapsed Time: 02:58)--------------------------
Wheelhubs that came with newer Axle (introduced with Post 2014 Facelift Polo's) arent compatible with axle from older Polo's(Pre 2014 facelift). Both these wheelhubs are localised in India. You can get the FAG WheelHub suitable for older axle for around INR 3K (this has the same FAG part no which Patil Sir has used for his Rear Disc Upgrade). Now pre 2014 Facelift polos came with and without ABS and their wheelhub are different. The car from which my rear axle came didn't have abs hence I had to change the wheel hub so that I could fit my rear abs sensors. You can read up more on this rear disc conversion here viewtopic.php?p=594198#p594198, Patil sir has beautifully explained the whole process and the things which are required.MayurS wrote: Thu Feb 08, 2024 10:32 amSanket, Could you please elaborate on this part? Are the localized (Indian) wheel hub not compatible with the old axel?SanketM wrote: Sun Feb 04, 2024 5:12 pm
