Polo 6R MIB2 PQ retrofit and BCM
mortys
Drives: 2013 Polo GT
Post by mortys »
In the process of upgrading RCD-510 to a MIB2 PQ CM.
I just checked the gateway installation list and 5F is missing.
The BCM is a HW: 7H0 937 090 Component: BCM PQ25 Max4 H72 0708.
Does this mean we need to swap the BCM to get access to 5F, or can I force access just by entering 5F manually?
Any insight is highly appreciated
Re: Polo 6R MIB2 PQ retrofit and BCM
entering 5F manually should work
mortys
Post by mortys »
iichel wrote: Sun Jan 29, 2023 1:40 pm entering 5F manually should work
Thanks, so just remove 77 and leave 56 as is?
I'm not completely sure how it's done, i think you can set some bits and bytes on the 7E0 gateway regarding virtual phone, navigation and/or radio modules in byte 2 of the long coding.
But for 7H0, I'm not 100% sure.
mortys
Post by mortys »
I have now installed the MIB2 unit and everything works as it should. Removed 77 Telephone from installation list in CAN gateway, and the funny thing now is that I have a coding error in CAN gateway and vdcs still try to reach 77 when scanning.
Any ideas?
Edit: Checked 77 again in installation list and errors disappeared. Guess it's need to be there as it's integrated in MIB2 unit
