Kratosmr
- Drives: Polo 1.2 TDI CFWA
Hi, It was manual from factory. After upgrading the BCM I added the Remote Key (Center Locking works perfectly with Remote Key, Boot Lock also).
patil
Check the adaptation addresses 03 &04 in BCM and see what is the stored value.
6R0 937 087 F is this the BCM you've upgraded to according to your scan ? If yes then this BCM won't support Cruise control as it doesn't have necessary pins.
Edit: Check for presence of 4 pins t73b 44 -47 in the BCM you've upgraded.
Kratosmr
Hi, That 4 Pins are there. I checked it while buying and only 6RU937087F don't support CC, but 6R0937087F has those pins. I have completed the wiring now. The CC buttons are working I checked using VCDS, And also I have changed the ECU byte 5 bit 5 and it accepted the coding. I will reassemble everything now and will report.
BCM picture: https://drive.google.com/file/d/1AhdB2a ... share_link
Kratosmr
Hi, CC is working perfectly. Thanks a lot Iichel and Patil for your kindly replies. Thanks a lot for this forum for all the valuable information from masters.
Well done, good job
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Good to read that CC is working.
patil
Excellent job...
Share the pictures and video of your work done.
Kratosmr
Hi, any suggestion on getting the ECU wire through firewall?
Till now I did the tests by running the cable over the door.
Current Wire Run: https://drive.google.com/file/d/1NZvt5v ... share_link
I tried accessing the rubber grommet below the water cowl. But the other side of the hole is full of fabric insulations and pu sheets, whether removing the glove box is the only way?
Edit: Made a hole in insulation which made the cable management possible.
Hallo
I have a issue with the cruise control on a Up 1.0 TSI. CHYA engine code . I tryed al lot but never find the solution.
I hope someone van give me the solution.
We did the whole wiring and checked and checked. When looking in VCDS we have all the signals when looking in mesauring blocks. 09 we see all and also in 17 for the MFD. This also works. But when looking in de engine the cruise signal it stays on 66. No change when using the handle.
We see alle buttons but we are missing something because we cant get it to work. No light in dash also.
We tryed both engine bcm connectors on pin 29. But without Any result. I tink we have the wrong pin but cant figure put wich we need.
Is there somebody who van tell me wich pin i need on engine module or some other help.
Wiring als follows ( model before 11-2013)
Stalk Pin 31 -> BCM Connector B(white) pin 46 (diode)
Stalk Pin 30 -> BCM connector B(white) pin 44
Stalk Pin 28 -> Fuse 12V SC5(contact +15)
Stalk Pin 27 -> BCM Connector B(white) pin 47
Stalk Pin 29 -> A130 SRS-kabellas
Stalk Pin 26 -> A130 SRS-kabellas
A130 SRS-kabellas -> Engine ECU T56A Pin 29
A130 SRS-kabellas -> BCM Connector B(white) pin 45
Stalk pin 31 -> BCM connector B(White) pin 46
wewuzKANGS
- Drives: mk5
hi!ciclo wrote: Sun Feb 15, 2015 8:58 pm Cruise control system 1.2 TSI
T94/45
VCDS
Engine Byte5
BCM Byte17
can you please share screen shots off all the long coding info of your ecu?
Antera wrote: Sun Feb 05, 2023 1:49 pm Hallo
Hi, Engine?, BCM? ...wewuzKANGS wrote: Tue Feb 14, 2023 10:46 pmhi!
What specifically do you want to know? What is your goal? ...
Can you share picture of your carKratosmr wrote: Sat Feb 04, 2023 2:44 pm Hi, CC is working perfectly. Thanks a lot Iichel and Patil for your kindly replies. Thanks a lot for this forum for all the valuable information from masters.
Kratosmr
Hi Danish, you mean the exterior pics?
Hello,
I am new in retrofitting on my polo 6R 2011, left hand drive but if can somebody help me with schematic and pins for retrofitting trip computer and crusie control that would be great.
Engine is 1.2 50 kw (70hp). Tenth letter is 'C'. So ciclo if you can help or anybody please do.
I bought the used levers and bcm 937087 and I will change the BCM soon.
Now just to buy vcds and get started.
I will make my own harness but could somebody recomend some links where to buy it from with speedy delivery?
Buci
Buci
