creaking sound
atopman
Drives: polo 6r
creaking sound
Post by atopman »
Hi everyone,
just wondering if anyone has any ideas what makes the creaking sound at the front right when going over bumps, it sounds like rubber rubbing, like a creaking noise.
I looked at the suspension , and its seems good, looked at the top of the strut mounts, two photo here of the right strut top...the right one when compared to the left, doesnt look central ???
Could this have caused any issue if its off?
any comments or advice please
Le_Combattant
Re: creaking sound
Post by Le_Combattant »
Typicall VAG issue, the rubber on silent bloc when the weather is cold.
They are creaking. Nothing wrong, I have the same issue on my Polo
2226
Re: creaking sound
Post by 2226 »
I might be wrong, but those look a little higher than they should be. Strut mount collapse?
I know one of mine must have a busted bearing since it makes clacking noise when turning the wheel.
atopman
Drives: polo 6r
Re: creaking sound
Post by atopman »
Le_Combattant wrote: Tue Feb 14, 2023 1:18 pm Typicall VAG issue, the rubber on silent bloc when the weather is cold.
i did notice its worse when cold. The car is quite low mileage, and drives good, no clacking when turning wheel,
but i just remembered some time ago, it used to make a clack as well when going over a bump, or coming off the drive,
spartacus68
Re: creaking sound
Post by spartacus68 »
You can't tell anything from shock mount in engine bay, you'll need to pull wheel off for proper inspection.
Regardless of mileage, ARB links are a likely culprit coming off a bump. If replacing, then Meyle HD parts are excellent.
stevo8375
Drives: Polo Gti
Re: creaking sound
Post by stevo8375 »
I’ve got the same, only creaks/squeaks going on and off speed bumps. Just had new top mounts and it’s no different. Link bars are ok on mine. Don’t know what it is
Kr1s
Drives: 1.2 TDI 2010
Re: creaking sound
Post by Kr1s »
Exact same issue for me when its cold, creaks when going over speed bumps - seems to be a very common sighting. Luckily I've moved to a warm country so only have to worry about the creaks for 1-2 months aha.
Brian422
Drives: 2013 Polo 1.2 Match Edition
Re: creaking sound
Post by Brian422 »
I had a creaking noise coming rear suspension and suspected Beam Axle Pivot Bush; stupid segmented design allows water and dirt ingress.
Sprayed and flushed with Silicon Lubricant cured squeak.
Now I spray all rubber bushes every year.
stevo8375
Drives: Polo Gti
Re: creaking sound
Post by stevo8375 »
I did the same on the wishbone bushes and anti roll bar bushes with gt85…no difference hah
I was wondering if it was the bump stops on the shockers creaking. Or maybe it is just the top mounts…wierd as mine are brand new ones
Brian422
Re: creaking sound
Post by Brian422 »
Hi Stevo.
All I can say is that Halfords Silicone Lubricant worked for me.
I attached a length of tube to nozzle so that I could spray around corners.
P.S. Other sprays are available :wink:
stevo8375
Drives: Polo Gti
Re: creaking sound
Post by stevo8375 »
Hmm might worth a try!
Today it was 10 degrees so far from cold and I’m still getting creaking, doing my box in! Haha
