Confused with the FuseBox
GMik
Drives: MK5
Post by GMik »
I wonder if anyone would be able to help me. My wife's Polo MK5 (2017) has a faulty sensor parking. I read that you need a 5amp fuse and where it should go. The problem is when I open the fuse box; there appears to be 7.5amp in that place (left column, middle row, far right).
Also, the fuses are not in places that correspond to any diagram I have found online.
Does anyone have any ideas?
Re: Confused with the FuseBox
Sc30 7.5A according to the diagram on the forum.
GMik
Drives: MK5
Post by GMik »
Thank you,
would you be able to point out which one is on the picture I posted?
left side compartment, middle row, second from the right
GMik
Drives: MK5
Post by GMik »
Thank you
