Regarding installation of front ops 8k kit in polo 6R
Vinayak185
Drives: 6R Polo GT 1.6 TDI
Post by Vinayak185 »
Hello All,
I am installing 8k ops kit on my polo 6R. The car was equipped with 4k sensors with buzzer and simple module. I got the 4k to 8k kit with module having part number 7E0 919 475S. I had connected everything but having issues and stuck now as OPS isnt working properly. so need help to figure out whats the actual problem.
After installation the rear camera not working and ops display isnot coming..
Here's the autoscan..
Thursday,16,March,2023,22:31:41:00233
VCDS Version: 20.4.1.0 (x64)
www.Ross-Tech.com
VIN: WVWC14608ET06 License Plate:
Mileage: 110240km-68499mi Repair Order:
Chassis Type: 60-VW25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 44 56
VIN: WVWC14608ET069582 Mileage: 110240km-68499miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CLNA) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 NT HW: 03L 907 425 B
Component: 1,6l R4 CR td H33 9971
Revision: --H33--- Serial number: 00000000000000
Coding: 00110016032500080000
Shop #: WSC 36792 002 104857
ASAM Dataset: EV_ECM16TDI02103L906023NT 003012
ROD: EV_ECM16TDI02103L906023CR_003.rod
VCID: 050BCCD68421CFAE38-8050
Readiness: 0000 1000
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ
Component: ABS9.0 front H01 0001
Serial number: --------------
Coding: 60DD2763412918C90619E471825318020000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_Brake1ABS90BOSCH 003017
ROD: EV_Brake1ABS90BOSCH_VW25.rod
VCID: 030FD2CE8A15F19E16-8056
Part No SW: 6R0 907 044 P HW: 6R0 907 044 P
Component: Climatronic H12 0614
Revision: V0000000
VCID: 40851DC2D3832A864B-8014
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H78 0725
Revision: B9078001 Serial number: 9000 238150833
Coding: 3AB82FB848A10000013806D03CCB9E90F08067FF60002001200400030000
Shop #: WSC 12345 123 12345
VCID: 2F674E7E7E1DA5FEA2-807A
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 260215 03 37 0059
Coding: 0228DD
Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB
Component: ------------- 006 5550
Serial number: 13202576131205051351
Coding: 010000
Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB
Serial number: 13202579131210074912
Coding: 010000
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 2771621065102472AB2B
Coding: 240000
Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L
Serial number: 13202580131212230948
Coding: 020000
Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L
Serial number: 13202581131127234117
Coding: 020000
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 S HW: 56D 919 475
Component: PARKHILFE 8K H02 0210
Revision: -------- Serial number: 79111507500150
Coding: 300001
ASAM Dataset: EV_VW75XParkAssis8K 001011
VCID: 428117CAD58F38965D-8016
Part No SW: 6R0 959 655 J HW: 6R0 959 655 J
Revision: -------- Serial number: 003GW00PX2AZ
Coding: 003036
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 499300E6E8B9EBCE9C-801C
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H04 0805
Coding: 140C00
Shop #: WSC 11802 938 12345
VCID: 479706DEFEAD1DBE8A-8012
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H78 0725
Revision: B9078001
Coding: 002300
VCID: 70E58D02A3A3FA06FB-8024
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 70
Mileage: 110249 km
Time Indication: 0
Date: 2017.08.06
Time: 22:21:48
Component: IMMO H04 0805
VCID: 6AD19F6A8D7F00D6B5-803E
Address 44: Steering Assist (J792) Labels:* 6Rx-909-144-V1.clb
Part No SW: 6RF 909 144 K HW: 6RF 909 144 J
Component: EPS_ECU H44 0401
Coding: 0000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SteerAssisUDSNSK 005005
ROD: EV_SteerAssisUDSNSK.rod
VCID: 54AD21923FFBA626FF-8000
Part No SW: 6RD 035 187 A HW: 6RD 035 187 A
Component: MIB2-S-R-CN 025 0210
Revision: -----001 Serial number: 09475GD0078320
Coding: 0000044004000A
Shop #: WSC 00081 790 00133
VCID: 458B0CD6CCA10FAE78-8010
2 Faults Found:
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 70
Mileage: 110249 km
Time Indication: 0
Date: 2017.08.06
Time: 22:19:37
01327 - Control Module for Parking Aid (J446)
Fault Priority: 6
Fault Frequency: 1
Reset counter: 70
Mileage: 110249 km
Time Indication: 0
Date: 2017.08.06
Time: 22:19:28
End-------------------------(Elapsed Time: 02:29)--------------------------
Re: Regarding installation of front ops 8k kit in polo 6R
looks like your radio is not compatible with your 7E0 OPS unit
patil
Post by patil »
iichel wrote: Fri Mar 17, 2023 8:18 pm looks like your radio is not compatible with your 7E0 OPS unit
iichel, his radio is perfectly compatible with 7E0 8K OPS module. I had same radio with 7E0 8K OPS module before, which worked perfectly.
The problem lies somewhere else.
patil
Post by patil »
Hi Vinayak185
Thank you for PM and link to my 6R thread. I will reply you here.
The 8K OPS issue in my 6R was due to incorrect CAN connection ( I had connected dash panel CAN lines to OPS module, which I later corrected by connecting to powertrain CAN lines).
Looking at your autoscan posted above, I think you did correct wiring,
but..
I believe here is the problem.
Coding: 300001
I think you got incorrect 8k OPS module. The SW/HW combination belongs to some other platform and not VW PQ25.
Eg;..This 8k module works on 6R perfectly.
SW 7E0 919 475 J HW: 7N0 919 475
Edit:
Looks like you also did the same mistake like I did. Check your CAN connection to OPS module. Must be connected to Powertrain CAN bus( old isolated CAN lines t32/28,29 of instrument cluster)
one more suggestion:
another:😋
recheck the Adaptation channels of the new module if necessary.
Vinayak185
Hello, yes the problem was with wrong can connection and it has been solved. Thanks to ciclo sir and patil.
Everything is working perfectly now. I cant change the ops display. It is showing sedan. Pls help .
was your 4K OPS connected to a different can network?
Vinayak185
No there was no can wiring provided for 4k from factory. There was only audio feedback with simple module
