I am likely to have a VW Golf MK7.5 Comfortline for some time
It's not sure but it is possible. My leasing car is not available any more. So it is likely to have for some time a GOLF MK7.5 (used).
As you can understand, I'm excited and I'm looking for what I can do to retrofit without many interventions on the car.
For start I am searching for the Wiring manual. If someone has it, it could be nice to share it with me.
The VIN is: WVWZZZAUZKW0xxxxxx so it is MY2019
@ciclo, i took a lot of ideas from your tread (your wife's GOLF).
P.S. the BCM info. Part No SW: 5Q0 937 084 DA HW: 5Q0 937 084 CD
Re: I am likely to have a VW Golf MK7.5 Comfortline for some time
Golf 7.5 Wiring diagrams : https://drive.google.com/file/d/1IRki8o ... sp=sharing
Please, request access if necessary, I will provide you the access to download the PDF.
Great, thank you Fernando. Request sentciclo wrote: ↑Wed Mar 08, 2023 1:01 am Golf 7.5 Wiring diagrams : https://drive.google.com/file/d/1IRki8o ... sp=sharing
Shared, I guess you can download it now..
Is true. I came into possession of a VW GOLF for a certain time (a few months). It's on a corporate lease, but I own it anyway.
First VCDS scanning.
I have some ideas for retrofits, for example exit lighting at the doors and footwell lights for the passengers.
Thursday,16,March,2023,18:48:45:16365
VCDS Version: 22.10.0.1 HEX-V2 CB: 0.4622.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WVWZZZAUZKWxxxxxx License Plate:
Mileage: 81865km-50868mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 13 15 17 19 42 44 52 5F
VIN: WVWZZZAUZKW057777 Mileage: 81865km-50868miles
Address 01: Engine (J623-DGTE) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 056 HN HW: 04L 907 445 G
Component: R4 1.6l TDI H01 6590
Revision: 22102001
Coding: 01114012434415092000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI03004L906056HN 004006
ROD: EV_ECM16TDI03004L906056HN.rod
VCID: 0059801D3A80FDDBEB2-8054
VINID: 9E69EAAAA465A9B9C01471C71C543999A0
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DD HW: 5Q0 614 517 AC
Component: ESC H25 0424
Revision: 00000000 Serial number: 52488000001401
Coding: 01FA62A124250973477E060760CA2580462490E26006A4731440F078C002430B00000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
VCID: 76B5E6C56844C36BC1E-8022
1 Fault Found:
8400 - Databus
U1123 00 [008] - Received Error Message
[FCAN: AB_Gurt_FA signal is invalid]
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 99
Mileage: 81044 km
Date: 2023.03.11
Time: 00:58:14
Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
Part No SW: 5G0 907 426 AQ HW: 5G0 907 426 AQ
Component: AC Manuell H03 1801
Revision: 00001K06
Coding: 00020104200110001000000000000002
ASAM Dataset: EV_ACManueBHBVW37X 004134
ROD: EV_ACManueBHBVW37X_004.rod
VCID: 7AADF2F55C5CA70BA56-802E
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Component: BCM MQBAB B H38 0273
Serial number: 00001829700176
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 181008 043 0551
Serial number: 181013022430
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 050 0105
Serial number: S4Y18M11D02H12M00S11
Coding: 00A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000021101804224232
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2B00600151FFC728949C810560400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D14C0D6E1821FB8FA-8010
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4NK87Q
Coding: 98CCC000000000005C0000CF000800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 094F9D3909BABC93BCC-805C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H37 0350
Serial number: 34169667E30101820893
Coding: 333135
Right seat belt tensioner:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H37 0350
Serial number: 34169668E30101821148
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 311 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000298B4853M
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 000 311 18
Component: SideSensor_Pf 001 0887
Serial number: 35800000000AB34D943U
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 403 110 18
Component: SideSensor_Dr 004 6149
Serial number: 35100011A2B7C814746/
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 480 403 110 18
Component: SideSensor_Pr 004 6149
Serial number: 3520001242B7B58475E5
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 480 400 211 18
Component: FrontSensor_D 004 6149
Serial number: 3550001262B81A86B520
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 741 D HW: 5G1 920 741 D
Component: KOMBI 202 3610
Coding: 07A42A002780000801886A011400000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009009
ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
VCID: 2809F8BDF270E59B832-807C
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 439 4344
Revision: -------- Serial number: 0008610108
Coding: 030100045F086800FA000048080F00010001070000000000000000000000
GVL: 01403C0000000000400C80000000480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3D2739E90DF25033C04-8068
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 AB HW: 5G0 959 442 AB Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0052
Serial number: 39180002147410068423
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 1648159404
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 F HW: 5Q0 959 393 F
Component: TSG FS001 0287
Serial number: YE007RJD27201
Coding: 003003208000048000001000
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHKLO_VW37.rod
VCID: 42DD4A15740C2FCBBD6-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000024938795
Coding: 110000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1082
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 74B1DCCD7E38D17BFFA-8020
Address 52: Door Elect, Pass. (J387) Labels:* Redir Fail!
Part No SW: 5Q0 959 392 F HW: 5Q0 959 392 F
Component: TSG BFS001 0287
Serial number: YE007RI40011B
Coding: 003001208000048000001000
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHKLO_VW37.rod
VCID: 41DF4519710A34D3A4C-8014
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000025122422
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 846 B HW: 3Q0 035 846 B
Component: MU-S-N-ER H41 0472
Serial number: VWZAZ2U1261086
Coding: 02731001FF0000005111000100080A001F0500C401200100CF
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 303910DDCAA0AD5B5B2-8064
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H52 8130
Serial number: VWZ6ZHV2943523
End----------(Elapsed Time: 01:03, VBatt start/end: 12.1V/12.1V)-----------
So, I'm ready to move on with the footwell lighting upgrade.
I am looking for the coding process.
This post is exactly what I'm looking for.
viewtopic.php?p=573840#p573840
I have a quick question for Fernando.
Should I run the first list of adjustments and then proceed with the second one (the one you wrote works perfectly for you) ?
PS. Continuing searching, i find that the second "way" is all i need. Anyway, any help or advice is welcome
I did it with the first adaptations that I posted and everything worked perfectly. (footwell + ambient lighting)
Then, quite by chance, I found the second way of 'adaptation' for the footwell lights, which includes the specific menu (sliding bar) in the menu of the infotainment system.
I didn't try this second way because I already had colored ambient lights installed, whose menu is much broader.
Please try the second way of adaptations and illustrate the slider (footwell lights) with a picture, in any case you can return to the first method if it doesn't work for you.
Project done. Success.
Wiring
Adaptation:
I proceeded to the second way from the beginning. I followed the steps exactly. Everything works fine.
The slider appeared at the infotainment and adjusts the intensity of the lighting.
(words in Greek language but you understand)
I copy it there just in case..
Next project: Door entry lights.
Wiring
Adaptation:
Adaption Channel: From: To:
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting not installed installed
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum 0 0.2
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum 0 70%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum 0 70%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum 0 70%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum 0 70%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum 0 70%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum 0 70%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum 0 127%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum 0 126%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum 0 127%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum 0 126%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum 0 70%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum 0 70%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum 0 70%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum 0 70%
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 0 89
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 0 2
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 not active 36 - LED Kleinleistung
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 not active Footwell light
i have a question about the flashdaten file and the versions between hardware and software.
If anyone knows the answer please share it with me.
My GOLF at Address 19: CAN Gateway (J533) has the follow information
So there is a Hardware version 3Q0 907 530 C but a software 3Q0 907 530 Q on version 4344
Searching for updates i found out
Which one should i use to update (if i should) ?
I can't understand the difference between the Hardware and the software version, or to be more specific i don't know which one should i check for choosing any update.
Thank you.
Thank you.
I think it would be good to use the VW version since the CAN gateway should also run a VW Golf dataset. I'm not sure that's available for this Skoda SW version.
Thanks for the picture of the slider for the footwell lights.
My advice is that you do not make SW updates until you are clear about what you are doing.
There are a lot of better SW updates for that GW (HW).
Draw your own conclusions with the following images.
"Read the component", ...530Q 5344 is the SW, ...530C 518 is the HW.
Load the local flash file and Start flashing.
... as you can see, 518 HW hasn't changed.
... if you search hard in D2 you can find that flash file.
Ah, neither the dataset nor the coding is lost when flashing the GW.
Understood
Thanks for the information.
I have never updated a BCM or other component with the ODIS-E procedure. From an academic point of view I am interested, but on the other hand I am afraid that something will happen and the car will stop. However, I fell head over heels with the module code I presented as an example. I see that you have advanced this particular topic a lot.
PS. I already found the file you suggested. I am thinking of making my first attempt at this process.
The first thing you have to do before any update is register all the adaptations and coding of all the modules with VCDS.
Autoscan for coding and RAW HEX for adaptations.
According to the autoscan posted above, the GW update with ODIS E should go well.
I ask myself a couple of questions about the ownership of the vehicle (current legalities) and what reason do you have to update the GW, but I don't want you to answer them publicly. Ask yourself the same questions and if everything is ok for you, proceed with the update.
That's a very good advice. At this moment, i want to procced with an updated, but i will not. The reason is that this car is not mine, it belongs to the Leasing Company, so I don't want to cause any problems for me and my company.ciclo wrote: ↑Wed Mar 29, 2023 5:47 pm The first thing you have to do before any update is register all the adaptations and coding of all the modules with VCDS.
I will proceed with minor upgrades, such as door entry lights and maybe front fog lights.
