Polo 6R OEM Bi-Xenon Retrofit
Mukaan
Drives: Polo 6R 1.2 TSI
Post by Mukaan »
Hello,
I'm looking to upgrade my stock halogen headlight cluster to the OEM Bi-Xenon unit on my Polo 6R.
The Stock BCM is a 6RU 937 087 R
I'm fairly new to this scene and I'm reaching out for guidance and assistance on what I would be needing to procure and change.
Thanks in advance :)
P.S: I have attached a picture of my Stock BCM to this post.
Stock BCM - 6RU 937 087 R
Polo 1.2 TSI Stock BCM.jpeg (115.94 KiB) Viewed 2449 times
patil
Re: Polo 6R OEM Bi-Xenon Retrofit
Post by patil »
Hello Mukaan welcome!
Your stock BCM doesn't support OEM bixenons. You need to upgrade your BCM High to BCM Max. And also need to do wiring for BCM Max and adaptation before installing OEM bixenons/ led headlights.
Let me make you aware of the fact that, this oem bixenon retrofit is no ordinary feat if you intend to do it in a perfect way. You need to learn and understand many things, need to invest lot of time, lot more of money and dedication. It's a long journey for you if you are willing to endure and succeed. This forum has all the information you need for your retrofit. Definitely experts from the forum will lend you a helping hand whenever required.
Read the following excellent threads in its entirety so that you will get an idea to how to start with.
viewtopic.php?t=69121
viewtopic.php?p=519107#p519107
And also mine,more recent one.
viewtopic.php?p=588943#p588943
The only thing that stands between you and your oem bixenon retrofit is... you. :wink:
Good luck👍
Mukaan
Post by Mukaan »
Hi Patil,
Thanks for the warm welcome and apologies for the delayed response. I was not in good health.
I have sourced a pair of the Bi-Xenons and wish to use them while I source a compatible BCM to support the headlight units to their fullest extent (CH/LH, AFS, the whole shebang).
Could you please help me with the suitable "Emulation" wiring for the Bi-Xenon units?
I understand that my stock halogen setup would be a 10-pin connector, which I would have to adapt to a 14-pin connector, but I am not sure about the wiring (hence falling to the guidance of the veterans)
Could you please help me with this ask?
EDIT: I would also like to share that I have an auto headlight switch currently working with an external light sensor (Chinese unit). Figured any and all information might help.
Mukaan wrote: Tue Apr 04, 2023 1:17 pm Hi Patil,
since no one is giving any advice, check this topic out it might help you a bit
https://www.team-bhp.com/forum/test-dri ... ost5483130
Mukaan
Post by Mukaan »
Thanks for the inputs amer6R,
I have gone through this thread as well.
I am looking for the pinout diagram or wiring diagram to help convert the T10 connector to the T14 connector for use with a BCM High (087)
