Help for the installation of xenon headlights and automatic ignition of polo 5 phase 1 headlights
Post FORUM SPECIFIC questions here: Such as, "HELP, I can't keep logged in for more than one session" etc... Not general help questions such as "my car won't start". You get the idea?
kilou
Drives: Polo 6R Style
Post by kilou »
Hello everyone,
I have a 2011 1.6 TDI Polo 6R Style. I have already made many changes, the latest is the installation of automatic air conditioning, I thank Polo.Blue for his excellent blog. I need your help for my next transformation which is the installation of the xenon headlights with the automatic ignition of the headlights and the change of BCM. I have already run the wiring for the Auto leveling headlight system (AFS), I bought a BCM 7E0 937 090B, I ran the wiring on the headlight side.
I also saw while scanning the forum that some of you have installed Interior mirror, automatic anti-dazzle.
I am also interested and interested in your help and advice.
@iichel thanks in advance for your help.
Good day,
Re: Help for the installation of xenon headlights and automatic ignition of polo 5 phase 1 headlights
Can you please post a scan of the car, if you have one? i.e. with VCDS
You can use the search function for "BCM Max" retrofit for some inspiration, that is what you probably must do.
The best expert for this is ciclo, but I'm not sure he is doing support for that anymore. He's been busy and ill lately, his time is precious.
kilou
Post by kilou »
Hello iichel,
Great thank you, I'll post the scan tomorrow because I have to do the revision.
A big thank you to you!
Sorry for Ciclo, I understand and wish him a good recovery!
You sound like a smart man. Perhaps it's good to start reading some bcm max retrofits here. It's a good start.
kilou
Post by kilou »
Hello everyone,
Below is the requested scan iichel
Thanks in advance
Dimanche,07,Mai,2023,20:17:31:51404
VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
Version VCDS: FRM 22.10.0.1 HEX-V2 CB: 0.4630.4
Version données: 20221026 DS344.0
www.rosstech.fr
VIN: WVWZZZ6RZCY082116 Plaque d'immat.:
Type chassis: 6R-VW25 (6N0)
Scanner: 01 03 04 08 09 10 15 17 19 25 44
VIN: WVWZZZ6RZCY082116 Kilométrage: 212420km
01-Moteur -- Etat: OK 0000
03-Freins ABS -- Etat: OK 0000
04-Angle de direction -- Etat: OK 0000
08-Climatronic -- Etat: OK 0000
09-Centrale Elec. -- Etat: Défaut 0010
10-Assistance stationnt -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: OK 0000
25-Anti-démarrage -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
Adresse 01: Moteur (J623-CAYB) Labels:. 03L-906-023-CAY.clb
No. pièce Log: 03L 906 023 MA Mat: 03L 907 425 B
Pièce: R4 1.6l TDI H33 9978
Révision: --H33--- No. de série: CVN: 2CA28130
Codage: 00114016002400080000
No. Atelier: WSC 00788 648 00255
Jeu de données ASAM: EV_ECM16TDI02103L906023MA 003011
ROD: EV_ECM16TDI021_SE25.rod
VCID: 71BFDDCC0125964314C-8024
VINID: 9E69EAAAA1A2A93A40202041186BBB42DC
Aucun code défaut trouvé.
Tests passés: 0 0 0 0 1
Adresse 03: Freins ABS (J104) Labels:. 6R0-907-37x-ESP82.clb
No. pièce Log: 6R0 907 379 AK Mat: 6R0 907 379 AF
Pièce: ESP8.2i front H05 0001
Révision: --------
Codage: 210228E3417500B4842614E382D700421300
No. Atelier: WSC 38291 000 1048576
VCID: 074B93141F61B8F3AA8-8052
Adresse 08: Climatronic (J255) Labels: 6R0-907-044.clb
No. pièce Log: 6R0 907 044 H Mat: 6R0 907 044 H
Pièce: Climatronic H11 0711
Révision: V0000000
VCID: 382920E8225F070B132-806C
Adresse 09: Centrale Elec. (J519) Labels:. FRM\6R0-937-08x-09.clb
No. pièce Log: 6R0 937 087 K Mat: 6R0 937 087
Pièce: BCM PQ25 H+4 H46 0251
Révision: BF046001 No. de série: 0434 230110398
Codage: 3CB02BFF0AA6E400093808006C2BCED00080012F60850000200000000000
No. Atelier: WSC 24697 483 00190
VCID: 45D7591C65AD6AE3984-8010
Sous-système 1 - No. pièce: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Pièce: RLS 020211 05 54 0403
Codage: 0730AD
Sous-système 2 - No. pièce Log: 6R0 959 801 AB Mat: 6R0 959 801 AB Labels: 6R0-959-801.CLB
Pièce: J386__TSG_FT 008 1611
No. de série: KU0KU004091100010167
Codage: 18BC30
Sous-système 3 - No. pièce Log: 6R0 959 802 AD Mat: 6R0 959 802 AD Labels: 6R0-959-802.CLB
Pièce: J387__TSG_BT 008 1611
No. de série: KU0KU023081100015001
Codage: 08BC30
Sous-système 4 - No. pièce: 1K8 951 171 A
Pièce: DWA-Sensor 00 001 0103
Codage: 000000
Sous-système 5 - No. pièce Log: 6R0 959 591 B Mat: 6R0 959 591 B
Pièce: J245 PS25.255 H02 0007
No. de série: WOO1310091W
Codage: 081001
Sous-système 6 - No. pièce Log: 5K0 959 542 Mat: 5K0 959 542
Pièce: E221__MFL-TAS H05 0010
No. de série: 0047638
Codage: 830000
Sous-système 7 - No. pièce Log: 6R0 959 811 B Mat: 6R0 959 811 B
Pièce: Tuer-SG_HL X12 X801
No. de série: KU0-KU029.10.0800000
Codage: 48BC32
Sous-système 8 - No. pièce Log: 6R0 959 812 B Mat: 6R0 959 812 B
Pièce: Tuer-SG_HR X12 X801
Codage: 48BC32
1 Code défaut trouvé:
01044 - Calculateur mal codé
000 - -
Capture:
Etat du défaut: 01100000
Priorité du défaut: 2
Fréquence du défaut: 1
Compteur de RAZ: 255
Kilométrage: 212421 km
Heure: 0
Date: 2017.09.27
Temps: 00:44:43
Adresse 10: Assistance stationnt (J446) Labels:| 7E0-919-475.clb
No. pièce Log: 7E0 919 475 L Mat: 7N0 919 475
Pièce: PARKHILFE 8K H06 0106
Révision: -------- No. de série: 28231432500765
Codage: 300001
No. Atelier: WSC 12345 123 12345
Jeu de données ASAM: EV_VW75XParkAssis8K 001003
VCID: 3B233FE413E92C13FE0-806E
Adresse 15: Airbags (J234) Labels:| 5K0-959-655.clb
No. pièce Log: 6R0 959 655 K Mat: 6R0 959 655 K
Pièce: VW10Airbag01M H09 0020
Révision: -------- No. de série: 003GX00UX5XO
Codage: 00314D
Jeu de données ASAM: EV_AirbaVW10BPAVW250 A01001
VCID: 4ACD6A204C33859B756-801E
Capteur de collision du sac gonflable latéral: côté conducteur:
No. de série: 3575HRB40530OPMGB90M
Capteur de collision pour sac gonflable latéral CP:
No. de série: 3585HRB40510OPMG5OSF
Capteur de collision du sac gonflable latéral arrière: côté conducteur:
No. de série: 3515RRB404V0MFP6B9SJ
Capteur de collision pour sac gonflable latéral AR: CP:
No. de série: 3525RRB405N0N49O48V0
Adresse 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
No. pièce Log: 6JA 920 840 A Mat: 6JA 920 840 A
Pièce: KOMBI H15 0605
No. de série: 00000000000000
Codage: 140E01
No. Atelier: WSC 73430 031 00097
Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A04716
VCID: 392F25EC19D51E03ECC-806C
Adresse 19: Gateway CAN (J533) Labels: FRM\6N0-909-901.lbl
No. pièce Log: 6N0 909 901 Mat: 6R0 937 087
Pièce: GW-K-CAN TP20 H46 0251
Révision: BF046001
Codage: 002200
VCID: 70B9D8C80AAF9F4B1B2-8024
Adresse 25: Anti-démarrage (J334) Labels:| 5K0-920-xxx-25.clb
No. pièce Log: 5K0 953 234 Mat: 5K0 953 234
Pièce: IMMO H15 0605
No. de série:
Codage: 000000
No. Atelier: WSC 00000 000 00000
Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03709
VCID: 6A8DCAA02CF3659B556-803E
Adresse 44: Direction assistée Labels: 6Q0-423-156.clb
No. pièce: 6R0 423 156 B
Pièce: LenkhilfeTRW V277
Codage: 11230
VCID: 2F3B1BB4DE51C0B3428-807A
Fin----(Temps écoulé: 01:49, VBatt début/fin: 12.0V/12.0V. VIgn 12.0V)-----
kilou
Post by kilou »
:D
Yes, 087 to 090 is a full bcm max retrofit. Have a look at some of the topics and study a lot of wiring schemes to make it work.
kilou
Post by kilou »
Iichel what BCM do you currently have on your Polo?
That is a 7e0 937 090 b
kilou
Post by kilou »
ok, thank you for your feedback!
did you install Interior mirror, automatic anti-dazzle?
Yes, with high beam assist
kilou
Post by kilou »
Oh yeah great,
I really want to do the same.
I started looking to configure the BCM, it doesn't seem too complicated, on the other hand for the wiring, I don't know what else to choose, the drive no longer works to retrieve information from Ciclo. You don't have the drive information
kilou
Post by kilou »
Can you confirm that you have this BCM?
iichel wrote: Mon May 08, 2023 6:16 am That is a 7e0 937 090 b
Well, yes that is what I said.
Have a look at my Polo for more information and part numbers: viewtopic.php?t=65724
I wrote a lot of things down for you to find, so please use it.
And if you want to know more, and I recommend to read it, look here: viewtopic.php?t=58703
The ciclo polo is where most inventions are made, and the descriptions are very detailed.
nazarij36
Drives: Polo
Post by nazarij36 »
After reviewing an unusually polished essay from a struggling student, I searched academic forums for solutions to test uploaded work. That led me straight to an effective Canvas integration AI recommended by instructors across all world. Having a mechanism that genuinely functions to catch synthetic output without false alarms helped me maintain academic honesty across all my course sections.
