ABS Module coding (long code)
Shanemcd
Drives: 1.4
Re: ABS Module coding (long code)
Post by Shanemcd »
I changed the ABS module because it was buzzing and I had a traction light and abs light on the cluster… and yes exact same part numbers on old and new module
What diagnostic tool are you using? Is the new module not buzzing?
Shanemcd
Drives: 1.4
Post by Shanemcd »
I have tried Vcds launch Bosch 350 and snap on all appear with the same fault 22, and no new module doesn’t buzz
could you please post an autoscan with vcds?
Jerem6868
Drives: Seat ibiza 6j
Post by Jerem6868 »
Hello, I lost my long code and I need your help.
If you help me, thank you for the time you give me.
I will paid you if you find the code
VIN : VSSZZZ6JZ9R127344
No. VAG : 6R0 907 379
ABS 8.2 front H03
Engine : BMS (1.4 TDI)
Manuel and left hand
Rear brake disc
TPMS
3 doors (Hatchback)
Jerem6868
Post by Jerem6868 »
Hello, nobody to help me ?
i sent you a code via private message
Jerem6868
Post by Jerem6868 »
Thanks ichell,
Sorry, I can't reply to you privately, I'll reply to you here
I’Ve tried your code but it say error 22.
I had 00 at the end but it say error 31
Jerem6868
Post by Jerem6868 »
It’s for Seat Ibiza 6J 2009
ABS 8.2 front H03
Rear brake disc
TPMS
3 doors (Hatchback)
why is the coding lost? do you have vcds scan?
Jerem6868
Post by Jerem6868 »
I bought the car with the ABS light.
I couldn't communicate between the ABS and the VCDs, so I took out the module and saw that it wasn't the original one.
now i replaced the module and i need to code it
that's not a vcds scan. please make an autoscan. here is how to do it: https://www.ross-tech.com/vcds/tour/autoscan.php
Jerem6868
Post by Jerem6868 »
Samedi,06,Janvier,2024,11:06:12:00009
VCDS -- Logiciel d'émulation de VAG/VAS sous Windows 10 x64
Version VCDS: FRM 23.3.1.1
Version données: 20230421 DS346.2
www.rosstech.fr
VIN: VSSZZZ6JZ9R127344 Plaque d'immat.:
Type chassis: 6J-SE25 (6N0)
Scanner: 01 03 09 15 17 19 25 44 56
VIN: VSSZZZ6JZ9R127344 Kilométrage: 185710km
01-Moteur -- Etat: Défaut 0010
03-Freins ABS -- Etat: Défaut 0010
09-Centrale Elec. -- Etat: OK 0000
15-Airbags -- Etat: OK 0000
17-Instruments -- Etat: OK 0000
19-Gateway CAN -- Etat: Défaut 0010
25-Anti-démarrage -- Etat: OK 0000
44-Direction assistée -- Etat: OK 0000
56-Radio -- Etat: Non enregistré 0001
Adresse 01: Moteur Labels: 045-906-013-BMS.clb
No. pièce Log: 045 906 013 AB Mat: 045 906 013 AB
Pièce: R3 1,4L EDC G000SG 3527
Révision: --H04--- No. de série:
Codage: 0053031
No. Atelier: WSC 00011 888 06946
VCID: 4FADC63BDEDD25EB03-801A
VINID: 9A38EAAAA19AA898810870C4100F062E4D
3 Codes défaut trouvés:
050210 - Centrale électrique.
U0422 - 000 - Signal non plausible
Capture:
Etat du défaut: 01100000
Priorité du défaut: 2
Fréquence du défaut: 9
Compteur de RAZ: 255
Kilométrage: 185587 km
Heure: 0
Capture:
Tr/min: 882 /min
Vitesse: 0.0 km/h
Charge: 0.0 %
Tension: 14.14 V
Bits: 11001100
Bits: 10000000
(sans unité): 255.0
001139 - Capteur de press. 1 des gaz d´échappt (G450) c.c. au pôle +
P0473 - 000 - - Témoin allumé
Capture:
Etat du défaut: 11100000
Fréquence du défaut: 4
Heure: 0
Capture:
Tr/min: 882 /min
Vitesse: 0.0 km/h
Tension: 14.06 V
Température: 9.0°C
Température: 27.9°C
(sans unité): 0.00
(sans unité): 0.00
000257 - Débitmètre d´air massique (G70) Signal implausible
P0101 - 000 -
Capture:
Etat du défaut: 01110000
Fréquence du défaut: 1
Kilométrage: 185645 km
Heure: 0
Capture:
Tr/min: 1533 /min
Vitesse: 82.0 km/h
Température: 12.6°C
Press. Absolue: 1081.2 mbar
Débit massique: 4.27 g/s
(sans unité): 3.53
Température: 81.0°C
Tests passés: 1 1 0 0 0
Adresse 03: Freins ABS (J104) Labels: 6R0-907-37x-ABS82.clb
No. pièce Log: 6R0 907 379 Mat: 6R0 907 379
Pièce: ABS8.2 front H03 0004
Révision: --------
Codage: 000000000000000000000000000000000000
No. Atelier: WSC 04941 000 00000
VCID: 7BF542EBFEE5694B9F-802E
4 Codes défaut trouvés:
01042 - Calculateur non codé
000 - -
Capture:
Priorité du défaut: 0
Fréquence du défaut: 24
Compteur de RAZ: 42
Kilométrage: 185461 km
Heure: 0
Date: 2018.05.26
Temps: 12:08:47
Capture:
Valeur hex: 0x0005
Valeur hex: 0x0000
Valeur hex: 0x3213
Valeur hex: 0x14B7
Valeur hex: 0x00FF
Valeur hex: 0x007F
Valeur hex: 0x7F00
Valeur hex: 0x0000
00285 - Capteur de vitesse AV D (G45)
008 - Signal Implausible
Capture:
Etat du défaut: 11101000
Compteur de RAZ: 38
Heure: 0
Date: 2018.05.26
Temps: 14:44:56
Capture:
Valeur hex: 0x0440
Valeur hex: 0x0000
Valeur hex: 0x1231
Valeur hex: 0x07B3
Valeur hex: 0x08FF
Valeur hex: 0x0E80
Valeur hex: 0x7D00
Valeur hex: 0x000A
00290 - Capteur de vitesse AR G (G46)
008 - Signal Implausible - Intermittent
Capture:
Etat du défaut: 10101000
Fréquence du défaut: 10
Compteur de RAZ: 82
Heure: 0
Date: 2018.05.26
Temps: 14:44:56
Capture:
Valeur hex: 0x0440
Valeur hex: 0x0000
Valeur hex: 0x1231
Valeur hex: 0x08B3
Valeur hex: 0x08FF
Valeur hex: 0x0E80
Valeur hex: 0x7D00
Valeur hex: 0x000A
03306 - Codage non valable
000 - - - Intermittent
Capture:
Etat du défaut: 00100000
Compteur de RAZ: 80
Heure: 0
Date: 2018.05.27
Temps: 14:47:51
Capture:
Valeur hex: 0x0001
Valeur hex: 0x0000
Valeur hex: 0x3227
Valeur hex: 0x14B6
Valeur hex: 0x00FF
Valeur hex: 0x007F
Valeur hex: 0x7E00
Valeur hex: 0x0000
Adresse 09: Centrale Elec. (J519) Labels:. FRM\6R0-937-08x-09.clb
No. pièce Log: 6R0 937 086 Mat: 6R0 937 086
Pièce: PQ25 BCM H07 0012
Révision: BD007001 No. de série: 9423B023090429
Codage: 248829A88861010000200000360B1C800000420F600000002000
No. Atelier: WSC 64564 324 38760
VCID: 79F958E3F0D95B5B8D-802C
Sous-système 1 - No. pièce Log: 6R0 959 801 Mat: 6R0 959 801 Labels: 6R0-959-801.CLB
Pièce: J386__TSG_FT 001 0247
No. de série: --------------------
Codage: 020000
Sous-système 2 - No. pièce Log: 6R0 959 802 B Mat: 6R0 959 802 B Labels: 6R0-959-802.CLB
Pièce: J387__TSG_BT 001 0251
Codage: 020000
Aucun code défaut trouvé.
Adresse 15: Airbags (J234) Labels:| 5K0-959-655.clb
No. pièce Log: 6R0 959 655 C Mat: 6R0 959 655 C
Pièce: VW10AirbagA01 H08 0018
Révision: -------- No. de série: 003000000000 Données UDS:: s00301896J0 0009
Codage: 003031
No. Atelier: WSC 06401 785 00200
Jeu de données ASAM: EV_AirbaVW10BPAVW250 A01001
VCID: 428BFF0FD58FD8839C-8016
Capteur de collision du sac gonflable latéral: côté conducteur:
No. de série: 3492ERB40358LKKN6CH.
Capteur de collision pour sac gonflable latéral CP:
No. de série: 3502ERB40258MAVT7JQA
Adresse 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
No. pièce Log: 6J0 920 800 L Mat: 6J0 920 800 L
Pièce: KOMBI 017 0018
No. de série: 00000000000000
Codage: 110200
No. Atelier: WSC 06402 785 00200
Jeu de données ASAM: EV_Kombi_UDS_VDD_RM09 A04020
ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
VCID: 2F6DA6BB761D45EB63-807A
Adresse 19: Gateway CAN (J533) Labels: FRM\6N0-909-901.lbl
No. pièce Log: 6N0 909 901 Mat: 6R0 937 086
Pièce: GW-K-CAN TP20 0012
Codage: 422000
VCID: 70EF65C7A3A31A133A-8024
1 Code défaut trouvé:
01044 - Calculateur mal codé
000 - -
Capture:
Fréquence du défaut: 7
Kilométrage: 185335 km
Heure: 0
Date: 2018.05.22
Temps: 02:09:19
Adresse 25: Anti-démarrage (J334) Labels:. 5K0-920-xxx-25.clb
Pièce: IMMO 017 0018
No. de série:
Jeu de données ASAM: EV_Immo_UDS_VDD_RM09 A03002
Adresse 44: Direction assistée Labels: 6Q0-423-156.clb
No. pièce: 6R0 423 156 A
Pièce: LenkhilfeTRW V275
Codage: 10111
VCID: 2E53BBBFED174CE368-807A
Adresse 56: Radio Labels: Aucun
No. pièce Log: 3TD 035 156 Mat: 3TD 035 156
Pièce: RadioSK46MID 006 0010
Codage: 01000424041000
No. Atelier: WSC 00078 790 00000
VCID: 7F0DB6FBEEFD756BB3-802A
Fin-------------------------(Temps écoulé: 01:31)--------------------------
Try this coding: 100100DB006D00B2082500E200D100000000
Jerem6868
Post by Jerem6868 »
Error 31 to…
