Help with PQ25 Max BCM and bi-xenons
Re: Help with PQ25 Max BCM and bi-xenons
It's very easy to make it yourself
mmarinov75
Drives: amarok
Post by mmarinov75 »
please help. i installed new original headlights + wiring harness kufatech. daytime running lights work when i start the engine and the light switch is in the zero position. low beam, high beam work + turn signal but no daytime running lights. no parking lights
i don't have automatic lights
module is 7H0 937 090
Hi.
First you say DRL works (light switch position 0) and then you say DRL doesn't work, parking light doesn't work.
Do you mean that the LED module's (LED strip) side/position/parking lights don't work in the other two light switch positions?
The DRL designation is only when the light switch is in position 0 (or AUTO if OFF, in case of having the AUTO position).
When the light switch is in the other two positions they are called side/position/parking lights.
In order to help you we must know:
- Origin of the installed BCM Max (new?, used?, donor car?).
- Link to the purchase of Kufatec wiring (installation instructions?).
- Exact date of manufacture of your Amarok. Important: indicate the exact month of manufacture so that we can know which model of fuse box is installed.
- A full Autoscan (no matter how many faults are currently detected). If possible, an Autoscan with the old BCM.
In these cases, the probable causes of the DRL and Parking lights malfunction may be:
- Improper electrical installation of the wires for these lights.
- Wrong BCM coding.
- Incorrect parameterization of these lights in the BCM. Necessary VCP to correct the operating values.
- etc...
Some information that could be of help, please read and take into account only what is related to your case.
viewtopic.php?p=530329#p530329
mmarinov75
Drives: amarok
Hello, thank you for your interest
10 pin headlight switch no auto light
Do you mean that the LED module's (LED strip) side/position/parking lights don't work in the other two light switch positions?----YES--YES==YES :(
- Origin of the installed BCM Max (new?, used?, donor car?).---BCM is on the car .not replaced
- Link to the purchase of Kufatec wiring (installation instructions?).---https://www.kufatec.com/de/volkswagen/vw-amarok/amarok-2h/adapter-xenon-scheinwerfer-fuer-vw-amarok-2h-47097
Vehicle Identification No.
WV1ZZZ2HZDH008965
Model
Amarok twin cab
AMA
Date of production
19.12.2012
Year
2013
Sales type
S1BC3A
Engine Code
CSHA
Transmission Code
NPZ
Axle drive
8A
Equipment
HV
Roof color
B4
Exterior color / Paint Code
B4 / B9A
[/list]
Wednesday,14,June,2023,09:46:50:62643
VCDS Version: 23.3.0.0
Data version: 20230315 DS346.1
www.Ross-Tech.com
VIN: WV1ZZZ2HZDH008965   License Plate:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 32 37 56 61 69
VIN: WV1ZZZ2HZDH008965   Mileage: 255080km-158499miles
32-Differential Locks -- Status: OK 0000
37-Navigation -- Status: Malfunction 1110
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CSHA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 012 AA    HW: 03L 907 309 AB
   Component: R4 2.0l BTD   H23 9977
   Revision: 73H23---    Serial number: 00000000000000 CVN: DB962EFB0000000000000000
   Coding: 012A4012233601080001
   Shop #: WSC 00081 202 00000
   ASAM Dataset: EV_ECM20BTD01103L906012AA 004010
   ROD: EV_ECM20BTD01103L906012AA_004.rod
   VCID: 635352CFE615F737CA-8036
   VINID: 9E606AAAA098A946000082461450DE3287
2 Faults Found:
12306 - Particulate Trap Bank 1
          P2002 00 [101] - Efficiency Below Threshold
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 254926 km
                    Date: 2023.06.11
                    Time: 16:15:48
                    Engine RPM: 2442.50 /min
                    Normed load value: 81.2 %
                    Vehicle speed: 109 km/h
                    Coolant temperature: 81 °C
                    Intake air temperature: 51 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 14.580 V
                    Exhaust gas jet volume in particle filter: 600.3 m³/h
                    Particle filter: difference pressure: 10 hPa
                    Particle filter: soot mass measured: -1.17 g
                    Particle filter: soot mass calculated: 19.78 g
                    Particle filter: differential pressure: dynamic offset: -13 hPa
                    Exhaust gas temperature sensor 3: 415.4 °C
                    Exhaust gas temperature sensor 4: 398.9 °C
12641 - Particulate Trap Bank 1
          P2002 00 [096] - Efficiency Below Threshold
          Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0110 0000
Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
   Part No SW: 2H0 927 158 B    HW: 0CM 325 025 A
   Component: 2H0 20RTDIRdW H16 3009
   Revision: --H16---    CVN: BB651686
   Coding: 000001
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_TCMAL450211 002011
   ROD: EV_TCMAL450211_002_VN81.rod
   VCID: 2C18A0A23A3A49B692-8078
Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
   Part No SW: 2H0 907 379 L    HW: 2H0 907 379 D
   Component: ESP MK25A XT  H44 0110
   Revision: 00H44001
   Coding: C07324B69A94039D24AB59A96F5590
   Shop #: WSC 02739 790 49152
   VCID: 392D8E4946FBFB117A-806C
Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
   Part No SW: 2H0 907 040 E    HW: 2H0 907 040 E
   Component: ClimatronicT5 H19 0406
   Revision: 00001003
   Coding: 0000000003
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_ClimatronicT5 A01003
   ROD: EV_ClimaAutoT5Basis.rod
   VCID: 2313D28FE6557777CA-8076
Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
   Part No SW: 7H0 937 090     HW: 7H0 937 090
   Component: BCM PQ25 Max4 H72 0708
   Revision: B9072001    Serial number: 0531 334120507
   Coding: 620002380C210000013806116CCB86C45A80672F60477160310000020803
   Shop #: WSC 02739 790 12345
   VCID: 6B5B22E70EFDC74F8A-803E
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3322
   Coding: 100000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3322
   Coding: 100000
   Subsystem 3 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Serial number: 0197281
   Coding: 830000
   Subsystem 4 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3322
   Subsystem 5 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3322
2 Faults Found:
00975 - Heated Rear Window (Z1)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 255082 km
                    Time Indication: 0
                    Date: 2017.11.04
                    Time: 09:41:51
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 196
                    Mileage: 255082 km
                    Time Indication: 0
                    Date: 2017.11.04
                    Time: 09:41:50
   Part No SW: 7E0 919 475 J    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0105
   Revision: --------    Serial number: 28261232402513
   Coding: 118103
   VCID: 392D8E494EFBFB117A-806C
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag00B H07 0013
   Revision: --------    Serial number: 003HN00ARUWD Dataset Number: 2H0003v____ 0156
   Coding: 000000000000000000000000000000003042
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3323B25F260597C74A-8066
   Serial number: 3495RRB40671O70U6087
   Serial number: 3505RRB40631O70UI8T-
   Serial number: 3555YRB404T1GCDMAP5G
   Crash sensor for front airbag: front passenger side:
   Serial number: 3565YRB40144UIV4NOL/
   Part No SW: 2H0 920 863 C    HW: 2H0 920 863 C
   Component: KOMBI         H03 0307
   Serial number: 00000014366287
   Coding: 150A00
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
   ROD: EV_DashBoardUDSJCIPQ25_A01.rod
   VCID: 291DAEB90E4B5B81FA-807C
1 Fault Found:
10485825 - Internal Control Module Memory Check Sum Error
          B2000 41 [137] - General Checksum Failure
          [Steuergerät defekt (EEPROM-Bereich Gesamtwegstrecke)]
                    Fault Priority: 2
                    Fault Frequency: 1
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H72 0708
   Revision: B9072001
   Coding: 742200
   VCID: 7064389622D62192B2-8024
1 Fault Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 191
                    Mileage: 254914 km
                    Time Indication: 0
                    Date: 2017.10.31
                    Time: 11:00:06
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H03 0015
   Serial number:
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
   ROD: EV_ImmobUDSJCIPQ25.rod
1- BCM coding. Byte28 is badly encoded, it must be 00HEX or Bit3 disabled.
2- You need to parameterize/program your original BCM with VCP or ODIS for the position lights to work on the led strip.
PWM Value with POS/TFL lights and activited Pos-lights
https://www.drive2.ru/l/489696641561919499
Maybe the value 28 is not enough for the led strip of the Amarok headlights.
Note:
It may be necessary to add two more wires from the BCM for the parking/side lights, and insulate the wires for the original side/parking lights.
I don't know how Kufatec wiring is made.
https://www.kufatec.com/de/volkswagen/v ... k-2h-47097
In this picture above you see two wires for BCM (probably for DRLs) but 4 are needed, 2 for DRLs and 2 for side/parking lights.
mmarinov75
Drives: amarok
hello, according to the wiring diagram of my car, it shows that there are cables from pin 4 of the headlight to the bcm.
T10/4 is for the DRLs, and you say the DRLs are working properly.
T10/10 is for the parking/side lights, which is what you say doesn't work.
The question is, is the T10/10 wire correctly connected to the BCM? (as shown in the diagrams I post previously)
There are two possibilities:
- Connected to T73a/40 and 41, which is incorrect for bi-xenon headlights. (usually for halogen headlights).
- Connected to T73b/5 and 6, which is correct for bi-xenon headlights.
Example for halogen headlights:
I wish you good luck with it. 🙏
mmarinov75
Drives: amarok
yes they are connected as shown in the diagram, when the DRL works on PIN 4 and 10 I get 12.5 volts, when I turn on the parking lights PIN 4-12.5 and PIN 10-3.8 volts
mmarinov75
Drives: amarok
does left right matter for 5 and 6 pin on bcm?
Again...
I guarantee that the solution to your problems is already written in my previous posts, please don't make me explain again what I've been explaining for a decade.🙏
https://drive.google.com/file/d/0B2nv91 ... l30Djz3D9Q
mmarinov75
Drives: amarok
many thanks
I purchased a vag can pro and changed the parameter for the parking lights from 20 to 28 and a miracle happened
Thanks a lot for the help CICLO
Brilliant! Thanks for the report, it may be useful for other users.👌
peter222
Drives: amarok 2012
Post by peter222 »
Good day . I would like to ask for help. I want to install xenon on Amarok 2.0 bi turbo 4.2012. light switch 1K0 941 431 BD, I have lights 2H1 941 015 T, 2H1 941 016 T, BCM old 6R7 937 087 M, new 7H0937090B BCMPQ25, VIN: WV1ZZZ2HZCA056596. THANKS FOR HELP
Středa,06,Září,2023,19:38:05:00009
VCDS -- Windows VAG/VAS Emulator Běží na Windows 7 x64
VCDS verze: SVO 20.4.2.1
Verze dat: 20200331 DS317.0
www.vag-com.cz
VIN: WV1ZZZ2HZCA056596 Výrobní štítek:
Kilometry: 145500km Číslo zakázky::
Model: 2H-VN81 (6N0)
Sken: 01 03 08 09 15 17 19 22 25 32 56 69
VIN: WV1ZZZ2HZCA056596 Kilometry: 145500km
01-Motor -- stav: OK 0000
03-ABS brzdy -- stav: OK 0000
04-Snímač úhlu řízení -- stav: OK 0000
08-Klima/topení -- stav: Nefunkční 0010
09-Centrální elektrika -- stav: OK 0000
15-Airbagy -- stav: OK 0000
17-Přístrojová deska -- stav: OK 0000
19-CAN Gateway -- stav: OK 0000
22-Pohon všech kol -- stav: OK 0000
25-Imobilizér -- stav: OK 0000
32-Uzávěr diferenciálu -- stav: OK 0000
56-Rádio -- stav: OK 0000
69-Funkce přívěsu -- stav: OK 0000
Adresa 01: Motor (J623-CDCA) Labely:. SVO\03L-906-022-CAA.clb
Řídící jednotka SW: 03L 906 019 FA HW: 03L 907 309 K
Díl: R4 2,0L EDC H43 9745
Revize: 26H43--- Seriové číslo: 00000000000000
Kódování: 01194012232600080000
Dílna #: WSC 01286 386 08256
ASAM Dataset: EV_ECM20BTD01103L906019FA 002005
ROD: EV_ECM20BTD01103L906019FA_002.rod
VCID: 6FED66BBB69D05FEFB-803A
Nenalezena žádná chyba.
Readiness: 0 0 0 0 0
Adresa 03: ABS brzdy (-----) Labely: User\2H0-907-379.clb
Řídící jednotka SW: 2H0 907 379 J HW: 2H0 907 379 D
Díl: ESP MK25A XT H44 0109
Revize: 00H44001
Kódování: C07324B69199039B24A789AC6F5690
Dílna #: WSC 07456 790 49164
VCID: 377D9EDB864D8D3EE3-8062
Adresa 08: Klima/topení (J255) Labely:| SVO\7E5-907-040.clb
Řídící jednotka SW: 2H0 907 040 D HW: 2H0 907 040 D
Díl: ClimatronicT5 H11 0304
Revize: 00001003
Kódování: 0000000002
Dílna #: WSC 07456 790 50316
VCID: 224B5F8F35CFF89624-8076
1 nalezena chyba:
9481988 - Snímac kvality vzduchu
B10AF 04 [008] - Vnitrni chyba systemu
Sporadická - Potvrzeno - Testováno od smazání paměti
info o závadě:
Stav závad: 00000001
Priorita závad: 3
Frekvence závad: 18
Počítadlo resetů: 25
Kilometry: 145287 km
Datum: 2023.09.06
Čas: 17:28:24
Adresa 09: Centrální elektrika (J519) Labely:. SVO\6R0-937-08x-09.clb
Řídící jednotka SW: 6R7 937 087 K HW: 6R7 937 087 K
Díl: PQ25 BCM H27 0532
Revize: -1------ Seriové číslo: 1009009900
Kódování: 3C0002380C010000003008102C4B84D40080410E60000000300000000000
Dílna #: WSC 51297 005 1048576
VCID: 4C97D137EFCB1EE6BE-8018
Subsystém 1 - Řídící jednotka SW: 6R0 959 801 M HW: 6R0 959 801 M Labely: SVO\6R0-959-801.CLB
Díl: J386__TSG_FT 002 3321
Seriové číslo: --------------------
Kódování: 100000
Subsystém 2 - Řídící jednotka SW: 6R0 959 802 P HW: 6R0 959 802 P Labely: SVO\6R0-959-802.CLB
Díl: J387__TSG_BT 002 3321
Kódování: 100000
Subsystém 3 - Řídící jednotka SW: 6R0 959 811 D HW: 6R0 959 811 D
Díl: J388__TSG_HL 002 3321
Kódování: 100000
Subsystém 4 - Řídící jednotka SW: 6R0 959 812 D HW: 6R0 959 812 D
Díl: J389__TSG_HR 002 3321
Kódování: 100000
Adresa 15: Airbagy (J234) Labely:| SVO\5K0-959-655.clb
Řídící jednotka SW: 2H0 959 655 B HW: 2H0 959 655 B
Díl: VW10Airbag00B H06 0013
Revize: -------- Seriové číslo: 003HN006UJP.
Kódování: 000000000000000000000000000000003042
Dílna #: WSC 07446 790 50316
VCID: 3365AACB9A35611EDF-8066
Snímač nárazu bočního airbagu: strana řidiče:
Seriové číslo: 3495RRB40610TGJKB0T6
Snímač nárazu bočního airbagu: strana spolujezdce:
Seriové číslo: 3505RRB40610TGJKCGH3
Snímač nárazu čelního airbagu: strana řidiče:
Seriové číslo: 3555YRB40650P4N040VK
Snímač nárazu čelního airbagu: strana spolujezdce:
Seriové číslo: 3565YRB405R0UT987H4G
Adresa 17: Přístrojová deska (J285) Labely:| SVO\5K0-920-xxx-17.clb-SRI1
Řídící jednotka SW: 2H0 920 863 B HW: 2H0 920 863 B
Díl: KOMBI H02 0505
Kódování: 150800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 285F4DA753F312C67A-807C
Adresa 19: CAN Gateway (J533) Labely:. SVO\6N0-909-901-6R.clb
Řídící jednotka SW: 6N0 909 901 HW: 6R7 937 087 K
Díl: GW-K-CAN TP20 H27 0532
Revize: -1------
Kódování: 742200
Dílna #: WSC 07462 790 50316
VCID: 70EF65C7A3A31A06E2-8024
Adresa 22: Pohon všech kol Labely: nevybrány
Řídící jednotka SW: 2H0 927 755 B HW: 2H0 927 755 B
Díl: SG offroad VTG 0153
Revize: 00H06000 Seriové číslo: T1IYC36211RNKZ
Kódování: 0000013
Dílna #: WSC 131071 1023 2097151
VCID: 2F6DA6BBBE1D45FEBB-807A
Adresa 25: Imobilizér (J334) Labely:| SVO\5K0-920-xxx-25.clb
Řídící jednotka SW: 5K0 953 234 HW: 5K0 953 234
Díl: IMMO H02 0505
Seriové číslo:
Kódování: 000000
Dílna #: WSC 00000 000 00000
VCID: 6ADB77AF8D7FE0D6AC-803E
Adresa 32: Uzávěr diferenciálu (J647) Labely:* SVO\2H0-927-771.clb
Řídící jednotka SW: 2H0 927 771 A HW: 2H0 927 771
Díl: Quersperre H04 0017
Revize: 11001001 Seriové číslo: 4DG 21.07.11 00
Kódování: 000001
ASAM Dataset: EV_QuersUDSAAMVN817 A01606
ROD: EV_QuersUDSAAMVN817.rod
VCID: 2C57B1B7470B3EE69E-8078
Adresa 56: Rádio (J503) Labely:. SVO\5M0-035-1xx-56.clb
Řídící jednotka SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Díl: RCD310 EU H03 5004
Revize: -----04S Seriové číslo: VWZ4Z2M1135004
Kódování: 00000400020016
VCID: 72EB6FCFADAF281614-8026
Adresa 69: Funkce přívěsu (J345) Labely:. SVO\1K0-907-383-V2.clb
Řídící jednotka SW: 1K0 907 383 F HW: 1K0 907 383 F
Díl: Anhaenger H09 0100
Revize: 3A001001 Seriové číslo: 00008030114049
Kódování: 0100000100000000
VCID: 306FA5C763235A06A2-8064
Konec------------------------(Uplynulý čas: 02:07)-------------------------
Adresa 08: chyby smazány
