VW 2005 polo immobiliser light flashing
Stevey
Drives: VW
Post by Stevey »
Hi I have a 2005 VW polo starts then immediately shuts down after a few seconds, immobiliser light is flashing on dashboard, have tried keeping key in ignition for up to 30 mins, connecting positive & negative terminals together, tried charging battery.
No fault codes seen on diagnostics reader.
Anyone else come across a similar issue?
Maarten
Drives: AW R-line Facelift MY2022 Vibrant Violet
Re: VW 2005 immobiliser light flashing
Post by Maarten »
Have you tried sparekey?
Flashing immobiliser light means no correct handshake.
No correct handshake, no running engine.
Engine dies within a second
Stevey
Drives: VW
Re: VW 2005 polo immobiliser light flashing
Post by Stevey »
Hi
I have tried both keys still getting same problem yes engine starts then dies.
Maarten
Post by Maarten »
Try holding one key closer to the keyhole, whilst starting with the other.
Maybe the coil doesn't pick up the immo transponder data
Stevey
Drives: VW
Post by Stevey »
Will try that thanks for the suggestion
Yezdi_90
Drives: Polo 6r trendline
Post by Yezdi_90 »
did it worked ?
