Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
Re: Favi's Polo 6R 1.2TSI Red Flash "strawberry" :)
New bumper but... 1 error on IC - bulbs error
turned off the option: front fog instaled and cornering via indicator (09 ELECTRIC VCSD)
0 faults, but error on Instrument Cluster ;/
What bulbs are you using for the front fog lights?
Are your front fog lights connected to the BCM? (9b,10b -11b).
I don't have front fog light (WRC bumper don't have place for it) - so now i decoded front fog lights and cornering
I'm working on a housing prototype for fog lights (3D model printer).
I did it when i made HBA.Are your front fog lights connected to the BCM? (9b,10b -11b).
Before replace bumper - FOG LED bulmps work perfectly - no errors.
maybe you need to disable the function in byte21 bit3.
Post an auto scan....
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 44 55 5F 77
VIN: WVWZZZ6RZBY
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 D HW: 03F 906 070 D
Component: SIMOS10.20H02 9851
Revision: -------- Serial number:
Coding: 001900D6202400080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM12TFS02103F906070D 003015
ROD: EV_ECM12TFS02103F906070BQ_003.rod
VCID: 23455A8B2AD5F19E36-8076
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3217500B7842814E484DA00401300
Shop #: WSC 27514 001 1048576
VCID: 071D2E1BB22D3DBE4A-8052
Component: LENKW.SENSOR H06 0070
Serial number: 15031304651874
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C7679-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326BAFCF6D2F6816CD-8066
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 071161174
Coding: 2CB02BBF48E1240093380E007CCB1FD0C0C0670F604939E0210000030820
Shop #: WSC 02737 022 157175
VCID: 68DF0DA79B73D2C6A3-803C
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 170117 04 42 0106
Coding: 0728DD
Subsystem 2 - Part No SW: 6R0 959 801 BD HW: 6R0 959 801 BD Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8610
Serial number: KU0KU010091300015333
Coding: 0200A3
Subsystem 3 - Part No SW: 6R0 959 802 BF HW: 6R0 959 802 BF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8610
Serial number: KU0KU006091300015370
Coding: 1000AB
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 5G0 959 442 L HW: 5G0 959 442 L
Component: E221__MFL-DC1 H11 0103
Serial number: 29160003417360027086
Coding: A40000
Subsystem 7 - Part No SW: 6R0 959 811 G HW: 6R0 959 811 G
Component: J388__TSG_HL 007 1611
Serial number: KU0KU015031100013211
Coding: 08BC32
Subsystem 8 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 007 1611
Serial number: KU0KU014031100013620
Coding: 08BC32
1 Fault Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 236
Mileage: 302747 km
Time Indication: 0
Date: 2018.02.06
Time: 00:21:32
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 L HW: 7N0 919 475
Component: PARKHILFE 8K H06 0106
Revision: -------- Serial number: 28231501401002
Coding: 308002
Shop #: WSC 07456 790 50316
VCID: 3B7582EBB265A95E1E-806E
Component: VW10Airbag022 H09 0020
Revision: -------- Serial number: 003GX00J3B65
Coding: 003232
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00D695-801E
Serial number: 3575HRB40570G68U9HCH
Serial number: 3585HRB40550G68U7HIK
Serial number: 3515RRB405T0510IA8VI
Serial number: 3525RRB405T0510IMOL.
Part No SW: 6R0 920 870 B HW: 6R0 920 870 B
Component: KOMBI H05 0609
Coding: 140E01
VCID: 3467A9D79F3B6626DF-8060
1 Fault Found:
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 9
Mileage: 302038 km
Date: 2023.09.09
Time: 19:55:31
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002200
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C
Component: FLA H09 0003
Revision: AA001001
Coding: 0404000000000000000000
Shop #: WSC 35110 790 50316
VCID: 2D51BCB37C1137EE90-8078
1 Fault Found:
13241857 - Databus
U1123 00 [008] - Received Error Message
Fault Priority: 6
Fault Frequency: 1
Reset counter: 21
Mileage: 302747 km
Date: 2023.09.16
Time: 00:10:41
Communication status of data bus 1-Brake control module: No communication
Communication status of data bus 1-Diagnostic interface for data bus: Communications link
Communication status of data bus 1-Engine Control Module (ECM): No communication
Communication status of data bus 1-Vehicle Electrical System Control Module: Communications link
Communication status of data bus 1-Steering column electronics control module: Communications link
Component: IMMO H05 0609
VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation
Cannot be reached
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6DA6BBEA1D45FEA2-807A
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: --------------
Coding: 0D4A000001000000
Shop #: WSC 12345 123 12345
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A7B87EFBD5F905605-806E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 F HW: 5C0 035 680 F
Component: MU-S-N-ER H41 0468
Serial number: VWZAZ2U0639822
Coding: 02720001FF0000001111000100080A001F0100D400200100CF
Shop #: WSC 00567 048 00001
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 244759972FDBF6A64F-8070
Data medium:
Subsystem 1 - Part No SW: 5NA 919 866 DF HW: -----------
Component: ECE AS 23/24 --- 2010
1 Fault Found:
0001 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Fault Priority: 6
Fault Frequency: 8
Reset counter: 219
Mileage: 280448 km
Date: 2023.03.25
Time: 13:03:45
Voltage terminal 30: 13.8 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 04:26)--------------------------
Address 03: DTCs cleared
Gateway Installation List: 7E0 909 901
When you do not have front fog lights installed,
- Byte12_Bit6,
- Byte21_Bits3,7,
must be disabled.
- Byte12_Bit6,
- Byte21_Bits3,7,
must be disabled.
disabled - no error on dashboardciclo wrote: Sat Sep 16, 2023 9:40 pm When you do not have front fog lights installed,
- Byte12_Bit6,
- Byte21_Bits3,7,
must be disabled.
so next retrofit? - Lane Change Assist (Side assist)
How do you plan to install the LCA warning lights on the exterior mirrors?
Scan mirror cover by lidar scanner, design a lamp holder in 3ds max or other 3d program -> print it on a 3D printer.
WD Transporter (2015 -->):
https://drive.google.com/file/d/0B2nv91 ... zd1OBVc1WQ
Request download if necessary.
Today I bought a new car
VW Polo 6R -> Audi A1 30 TFSI S-tronic (S-line)
VW will be for sale.
If anyone is interested in a side assist system (wirings, mirror housings, leds etc. - without radars) - it will also be for sale.
- ag69
- Drives: 1.2TSi 77Kw 7DSG
Congratulations on new car.
Someone is going to get lucky with so loaded 6R.
Will miss the updates though.
