Hi I have vw polo blue gt 150ps 64 plate.
I keep getting engine light come on telling me the o2 sensor post cat is stuck/lean and or low voltage.
Error codes P2270, P0137, P0141.
Does anyone know the part number for post cat o2/lambda sensor as dealer is charging £218. If anyone has any advice on what to do, I've changed the o2 sensor once already so not sure if I need a genuine dealer part. All wiring has been tested too and is fine.
Vw polo blue gt o2 sensor post cat issues
Toymachine1
- Drives: Polo 6R Comfortline 2010
Re: Vw polo blue gt o2 sensor post cat issues
I have had both lambda sensors changed on my 1.2TSI CBZB Polo. Only way to fix properly was to install genuine sensors.
- Le_Combattant
For 0² sensor: go for genuine ONLY.Blu eyz wrote: Thu Sep 21, 2023 4:37 pm Hi I have vw polo blue gt 150ps 64 plate.
Otherwise, it's the best way to have trouble
Thanks for the responses, I disconnected both o2 sensors and ran the car then reconnected them and so far no error codes. If one pops up I will just buy genuine part
