Airbag warning light.Where exactly is this module located?
saphollo
Drives: polo 9N3 1.4 16v
Post by saphollo »
Hello All,
Problem airbag warning light on the dashboard.
I scanned with VCDS and error
1 fault fonds:
65535 module defect
00-10 intermittent
impossible clear default with VCDS.
My question, Where exactly is this module located? ? I'm looking but I can't find it.
POLO 9N3
year : 2004
motor code BBZ 75 KW
Maarten
Re: Airbag warning light.Where exactly is this module located?
Post by Maarten »
Crash module is located beneath the center console.
But your fault is intermittent, should be able to clear it
saphollo
Post by saphollo »
Thanks for the quick response Martin.
I try several times to delete default with Vcds impossible,default comes right back.
Maarten
Post by Maarten »
Did you have an accident?
Or spontanious fault?
saphollo
Post by saphollo »
No accident.
Suddenly this light appeared.
