ABS Module coding (long code)
Re: ABS Module coding (long code)
Did you change ecu, cluster?
no, I did not change anything
You did change abs block?
yes I changed it
Part number probably not correct
Hi, I have a 2012 one in at the moment and the abs ECU code in is showing all zeros.
I have a snap on reader and launch, but how do I find out the code? I need to enter
Thanks in advance
Thanks in advance
ABS unit hasn’t been touched still the original on the vehicle it’s 1.2 2012 Vin number WVWZZZ6RZCU049622
It’s the right number, 6RO 907 379
I checked
I checked
200200ER007100BB042B00E400D300000000 try this
Doesn’t work
What can I do ?
try this one: 200200ER017100BB042B00E480D300000000
It say :
Your encoding contains invalid characters.
Only hexadecimal characters (0-9 and A-F) are allowed.
Correction: 200200EC017100BB042B00E480D300000000
Error 31 again
