Engine wont Rev past 2000 RPM
Post FORUM SPECIFIC questions here: Such as, "HELP, I can't keep logged in for more than one session" etc... Not general help questions such as "my car won't start". You get the idea?
racingredchief
Drives: 2009 VW Polo 1.2
Post by racingredchief »
Hi All , Newbie here
I have a VW Polo 1.2 2009 .
When I start up the engine it will rev as normal past 2000 RPM no problem so long as I keep the revs High
If I drop the revs to tick over or at least lower than 2000 the car seems to go into some sort of Limp Mode and wont go past 2000RPM
Just changed the Crank Position Sensor as that was easiest and no change.
Only other thing I can think of is the Engine Mounts are shot and engine does wobble lots.
Thanks in Advance
Adrian
racingredchief
Re: Engine wont Rev past 2000 RPM
here is what happens in a 2 minute brief YT video
https://youtu.be/9YFB9FIK6GI
Maarten
Post by Maarten »
Engine shakes a lot.
Did you do a scan?
Sounds like 1 cilinder is not performing well
racingredchief
Thanks Maarten ,
It does seem like the revs are a bit uneven and possible misfiring, could be as simple as a spark plug , what do you think ?
didn't do a scan
Maarten
Post by Maarten »
Did you check the plugs?
When were they changed last time?
racingredchief
just changed the plugs today , they certainly needed changing but the problem is still there
coil packs.jpg (1.84 MiB) Viewed 22791 times
polo plugs.jpg (2.35 MiB) Viewed 22791 times
Maarten
Post by Maarten »
Those have a lot of oil on them.
That's not normal
racingredchief
Car had a compression problem, possible cracked head etc .
We have scrapped in the end
Thanks for all your help and input
Video of the compression test attached
https://youtu.be/GxjEwB59oDA
racingredchief
Maarten
Post by Maarten »
racingredchief wrote: Tue Jan 09, 2024 8:59 pm Car had a compression problem, possible cracked head etc .
Thanks for the update.
Too bad you couldn't save the engine.
Better luck with your next car :)
