Re: iichels Polo 6R 1.6TDI DSG --> OEM++ R-Line conversion
I imagined that.
Can you meet or contact govindsharma or patil? do they live near you?
- Drives: 6R Polo GT 1.6 TDI
I can contact them but I don't live near them.
What do you think will be more efficient, buying a new BCM 7E0, buying the VAS and installing the ODIS programs, or traveling where they live?
Buying BCM seems easy . Other things are time consuming and lots of work. From where can I get bcm
- til3tsio
- Drives: Seat Toledo KG
From this I understand that updating 7h0 to 7e0 is possible.
Very interesting, thanks for the info.
090E file though isn't publicly available, it would be nice if you could share it or give some information on how to acquire it.
I talked to Mr. Govind Sharma sir and he shared the firmware update file as well. The firmware update name is 7H0937090D_0726.sgo
He said to confirm with ciclo sir whether the firmware will work or not.
I don't know if anyone has flashed a BCM MAX 7H0 with 7E0 software, would you be willing to do it?
What is your current BCM?
That file is compatible with this BCM...Vinayak185 wrote: ↑Wed Jan 10, 2024 11:53 am I talked to Mr. Govind Sharma sir and he shared the firmware update file as well. The firmware update name is 7H0937090D_0726.sgo
... the image you sent me a while ago of your BCM.
- til3tsio
Then I misunderstood your posts , apologies.ciclo wrote: ↑Wed Jan 10, 2024 12:12 pmI don't know if anyone has flashed a BCM MAX 7H0 with 7E0 software, would you be willing to do it?
I used to have 7H0...D 725 and I successfully updated it in 726, but I don't have this anymore to check the installation list that Vinayak185 is looking for.
Now I have 7E0...B and it would be interesting to update it with the 090E file that you have.
Check your installation list. Does it show 36 module?
Ciclo sir, govind Sharma sir misunderstood and gave wrong file. He is searching 7E0 file.
I do not own the file...til3tsio wrote: ↑Wed Jan 10, 2024 12:41 pmThen I misunderstood your posts , apologies.
Ok.Vinayak185 wrote: ↑Wed Jan 10, 2024 1:07 pm Ciclo sir, govind Sharma sir misunderstood and gave wrong file. He is searching 7E0 file.
Please suggest me which firmware would work with 7H0 BCM?
I'd try the 7E0 090E, the latest one. But I'd also make sure to have your original 7H0 FW available, in case you need to revert.
