What is this for? Polo 6N. Air filter pipe.
craigedmonds
Drives: VW Polo III Hatchback (6N1) 1.4 16V 100
Post by craigedmonds »
Today I was changing the air filter and I noticed that the previous mechanic had bodged the outpipe coming from the air filter cover.
However, that pipe goes into a box of some kind. I noticed some carbon build up in that box when I removed the pipe.
Can anyone tell me what that box is for?
Below is the bodged pipe and under that is a picture of the inlet for the pipe which leads to some kind of box in the back of the engine.
alexperkins
Site Admin
Re: What is this for? Polo 6N. Air filter pipe.
Post by alexperkins »
Thats the crankcase breather. The bit in the hose with the plug is the heater for the crankcase breather
slowpoloauto
Drives: 6n2
Post by slowpoloauto »
and mine is getting blown off, that's the issue I have.
alexperkins
Site Admin
If it’s being blown off, you’ve got excessive positive crankcase pressure. Possibly need a new oil separator on the back of the block
slowpoloauto
Drives: 6n2
I take it that's the expensive plastic thing??
https://www.volkswagen-classic-parts.co ... 99014&ct=2
alexperkins
Site Admin
Depends on your engine code. There’s a few versions
Do you know what yours is? (And what year)
slowpoloauto
Drives: 6n2
It's AUA 2001 which matches info on the page for the pipe at least.
I found the plastic thing on ebay.
alexperkins
Site Admin
That should be the one. Usually available in a variety of places. Bear in mind anything used will almost certainly be going soft, or will have hardened up due to age and heat so new is ideally the best way
If however your hose is ok, you’ll need the oil seperator itself which is an inexpensive part - febi still make them
slowpoloauto
Drives: 6n2
The pipe is going soft. I'll probably bite the bullet on this and get it done.
JUUL
Drives: 6N 1995
Post by JUUL »
By the looks of it your hose/pipe has had its best years, probably for the same reasons Alex mentioned previously. As far as I can see, it has already been repaired twice. If I were you, I'd replace both. See illustration below for your specific engine code. You will need partnumbers 19 and 28a.
19 oil separator: oem partnumber 036 103 464 G
28a vent hose: oem partnumber 036 103 474 L
