Hello !
Im Pawel from Poland. After 12.5 years, it's time to change the VW Polo 6R (viewtopic.php?t=71015&sid=7e6bd68ccf138 ... 47402e30bc) to the Audi A1
Audi A1 GB (82A) - 1.0 TFSI S-tronic S-line
Engine:DKRF
Gearbox:TSV
Colors - LX7G Chronos Gray Metallic + Black
Photos from myAudi app
Mods? Retrofits? YES!
Audi like VW Polo will also has modifications
1. washer fluid level sensor
2. headlight washers
3. Steering wheel - 82A 419 091 AH LCW or from Audi Q3 83A419091AP
4. Side assist (blind spot)
5. Roof liner - 82G867505F L12
6. Coding HBA
Audi A1 GB (82A) Chronos Gray by Favi :)
Re: Audi A1 GB (82A) Chronos Gray by Favi :)
Hi Pawel, welcome to this section of the forum.
Congratulations on your new acquisition!! the current A1 is very beautiful, we hope you will enlighten us with many/some images of your new and beautiful car.
Remember to do a first Autoscan and a complete readout of all adaptation channels from all control units without mods.
(whole vehicle, CSV file & Raw Hex viewtopic.php?p=572894#p572894)
Our Golf has the same DKRF engine, and for now I can only tell you that we are very happy with its performance, it is very pleasant to drive, it surprises and puts a smile on your face if power is required, it claims 115 HP but I think it is a little more, which is more than enough for daily use with a little fun.
First mods
7M0919376+7M0919382+1J0973202
2 pins:
- 1 ground
- 1 BCM (I'm not sure, but it will probably be T46b/28)
6R0955681
2 pins :
- 1 ground
- 1 BCM (I'm not sure, but it will probably be T46b/46)
2 pins:
- 1 ground
6R0955681
2 pins :
- 1 ground
Yep those pins are indeed correct for any MQB car. Will you also do the heated washer nozzles?
Hello,
The A1 is an excellent car. I'm glad for you.
I hope you enjoy it and of course I already read that you have designed the first retrofits. Good luck with these and have fun.
I forgot about it
I found :
82A955987A
82A955988A
and 2x 8e0973202
correct?
wiring scheme?
Edit
I Found from T-roc scheme:
T2cb/1 and T2cc/1 -> T46b/9
Correct?
EDIT
I have factory installed heated washer nozzles
