Led fog lights
J+silva
Drives: polo conf.
Led fog lights
Post by J+silva »
I would like to know if anyone has changed the fog lamps to LEDs or opted to install whiter lamps. What do you advise?
ad_182_uk
Re: Led fog lights
Post by ad_182_uk »
You can fit LED’s but likely need coding changed to avoid errors.
PO10ASH
Drives: POLO GTI+
Re: Led fog lights
Post by PO10ASH »
Swapped to LED and then coded them to LED so the warnings don't pop-up.
J+silva
Drives: polo conf.
Re: Led fog lights
Post by J+silva »
Thanks for the answers, I'll order the LEDs. Is there a procedure here on the forum to code for LEDs?
ad_182_uk
Re: Led fog lights
Post by ad_182_uk »
Someone with an idea how to use VCDS will be required.
J+silva
Drives: polo conf.
Re: Led fog lights
Post by J+silva »
Just a up date I changed the fog lights to leds cod it with obd and its 100% functional.
