ABS Module coding (long code)
Re: ABS Module coding (long code)
I changed my ecu and cluster and after that it was at zeros my long coding could someone help me code? ESP 9.0i polo gti 6c manual
mariusgone
- Drives: A3 8P :))... same thing, mostly
Hello mate!sillerha wrote: Mon Jan 09, 2023 9:47 am So far I have:
11,02,24,DB,41,__,00,__,88,__,24,__,82,__,00,15,__,00
Byte 0 - 11 (Ibiza hatch)
Byte 1 - 02 (Ibiza)
Byte 2 - 24 (256mm discs front / 200mm drums rear)
Byte 3 - DB (Ibiza)
Byte 4 - 41 (Manual)
Byte 5 - ? HEX 6D + VIN digit 13 (Digit 13 = 2)
Byte 6 - 00
Byte 7 - ? HEX B2 + VIN digit 14 (Digit 14 = 5)
Byte 8 - 88 (Inverse of Byte 0)
Byte 9 - ? HEX 25 + VIN digit 15 (Digit 15 = 7)
Byte 10 - 24 (Inverse of Byte 2)
Byte 11 - ? HEX E2 + VIN digit 16 (Digit 16 =
Byte 12 - 82 (Inverse of Byte 4)
Byte 13 - ? HEX D1 + VIN digit 17 (Digit 17 = 2)
Byte 14 - 00 (Inverse of Byte 6)
Byte 15 - 40 (BXW engine)
Byte 16 - ? (Not sure how to convert the bit value)
Byte 17 - 00
Just curious to know if what I have done is correct?
Is there any chance you can help me with something similar?... willing to pay if succesful
