Coding ESP9.0i E03 0003
I have a 2014 Polo 6R with ESP9.0i and I lost the coding for the ABS control unit.
The problem is that we swapped the engine with an older 1.9 TDI pump injection engine from 2004.
Is it possible to code the ABS ?
Is there an engineer who can help me?
Thank you
Thank you
Re: Coding ESP9.0i E03 0003
i suppose we could try
How to proceed?
What do we need?
What do we need?
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 2E 37 44 56 61
VIN: WVWZZZ6RZEY155142 Mileage: 156180km-97045miles
01-Engine -- Status: Cannot be reached 1100
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine Labels: 038-906-019-AVF.lbl
Part No: 038 906 019 KE
Component: 1,9l R4 EDC 0000SG 4898
Coding: 00002
Shop #: WSC 05314
VCID: 64C71997F45BB6AF4B-4B18
VINID: 9E69EAAAA1A2A95A4114504408A32D0CB3
1 Fault Found:
18080 - Coolant Fan Control 1
P1672 - 35-10 - Open or Short to Ground - Intermittent
Readiness: 0 0 1 1 1
Part No SW: 6R0 907 379 AS HW: 6R0 907 379 AS
Component: ESP9.0i front H03 0003
Serial number: --------------
Coding: 000000000000000000000000000000000000
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_Brake1ESP90iBOSCH 003020
VCID: 0F2D063BD65D65F746-805A
3 Faults Found:
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156043 km
Date: 2024.05.10
Time: 17:13:39
0887 - Control Module
C104A F0 [024] - Incorrect VIN
Intermittent - Confirmed - Not Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 98046 km
Date: 2023.08.23
Time: 00:00:02
0883 - Control module not coded
U1013 00 [024] - -
Fault Priority: 2
Fault Frequency: 36
Reset counter: 53
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Serial number: 25111304652561
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EF34BFFE1F77C7FBD-802A
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 N HW: 6R0 820 045 N
Component: Man AC H02 0202
Revision: 0003SH02
VCID: 397998E3B0599B47C8-806C
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 B HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0712
Revision: B9074001 Serial number: 0571 319132126
Coding: 21B02BA028A10000213801303AE80ED90F20610F6E824008000000000000
Shop #: WSC 00046 123 12345
VCID: 2D51BCB3741137E754-8078
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU014021440450567
Coding: 0000A0
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU003.02.1011413
Coding: 48BC30
Subsystem 3 - Part No SW: 3C8 959 537 B HW: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4 0021
Serial number: 10000000000000101270
Coding: E20000
Subsystem 4 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8611
Serial number: KU0KU009041550990738
Coding: 0400A0
Subsystem 5 - Part No SW: 6R0 959 812 G HW: 6R0 959 812 G
Component: J389__TSG_HR 008 1611
Serial number: KU0KU021091100010739
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
Part No SW: 6R0 919 475 C HW: 7E0 919 475
Component: PARKHILFE 4K H11 0013
Revision: -------- Serial number: 47361331901865
Coding: 108001
Shop #: WSC 00046 000 00000
ROD: EV_VW250ParkiAssis2.rod
VCID: 3E738BFFA177BC7FFD-806A
Component: VW10Airbag01M H10 0020
Revision: -------- Serial number: 003GX01YHT8C
Coding: 00314D
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4A9BD72FEDBF00DF51-801E
Serial number: 3575HRB401850KMKBH2D
Serial number: 3585HRB401850KMKBOK$
Serial number: 3515RRB400I50Q3SH95M
Serial number: 3525RRB400K50Q3S51AA
Part No SW: 6R0 920 861 M HW: 6R0 920 861 M
Component: KOMBI H02 0406
Serial number: 00000018928735
Coding: 140A00
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01723
ROD: EV_DashBoardUDSJCIPQ25_A01.rod
VCID: 3F8DF6FBA67DB577F6-806A
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0712
Revision: B9074001
Coding: 002300
VCID: 70EF65C7A3A31A0F3F-8024
Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H02 0025
Serial number:
ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
ROD: EV_ImmobUDSJCIPQ25.rod
VCID: 6ADB77AF8D7FE0DF71-803E
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Component: SG EXT.PLAYER H19 0770
Revision: A1001003 Serial number: 7665499409
Coding: 020100
VCID: 2B55B2AB4A0539D74A-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 F HW: 3C8 035 279 F
Component: RNS315-EU H76 0410
Serial number: VWZAZ2N0641265
Coding: 04000411020001000000130C
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E53BBBF71174CFF6D-807A
Data carrier:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V5 0055
Part No: 6R0 423 156 C
Component: LenkhilfeTRW V278
Coding: 11230
Shop #: WSC 00788
VCID: 306FA5C7F7235A0F7F-8064
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H74 0712
Coding: 030B1A5A
Shop #: WSC 73430 790 00155
VCID: 6BD572AB8A85F9D70A-803E
Coding: 00002
Shop #: WSC 05314
1 Fault Found:
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156043 km
Date: 2024.05.10
Time: 17:13:39
Fault Priority: 2
Fault Frequency: 1
Reset counter: 9
Mileage: 98046 km
Date: 2023.08.23
Time: 00:00:02
U1013 00 [024] - -
Fault Priority: 2
Fault Frequency: 36
Reset counter: 53
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 01
Revision: 0003SH02
Coding: 0000A0
Coding: 48BC30
Coding: E20000
Coding: 0400A0
Coding: 08BC32
Coding: 108001
Coding: 00314D
Coding: 140A00
Revision: B9074001
Coding: 002300
Serial number:
Coding: 020100
Data carrier:
Coding: 11230
Shop #: WSC 00788
Coding: 030B1A5A
can you please post the advanced id of the immobiliser (module 25) and engine (module 01)?
Attached is the advanced ID of the immobilizer. The one from the engine is locked
- IMG_20240530_131708.jpg (3.1 MiB) Viewed 3635 times
that's a shame. did you take notice of your factory abs coding? can you tell some more about what you did to the cluster and ecu to make it all work?
Before and after the swap, the ABS was still coded but I couldn't save the coding. The coding was lost when I tried another cluster. The ECU of the new engine is in immo off and it worked without error.
Note: I still have the original engine's ECU in my possession but not the engine anymore."
you'll probably need to connect the old ecu when you attempt abs coding and when it's successful, put in the new ecu
Can you help me with the possible codings because I have already tried several?
My old engine code is CFWA
i can try. i'll need a scan with the old ecu and matching cluster in place please. we'll try to code that first. then we try the new ecu.
As soon as I get home, I will connect the ECU and send the scan here
This is the scan of the old ecu
VIN: WVWZZZ6RZEY155142 License Plate: 87
Mileage: 156180km-97045mi Repair Order:
01-Engine -- Status: Malfunction 1010
Address 01: Engine (J000-CFWA) Labels:. 03P-906-021-CFW.clb
Part No SW: 03P 906 021 AJ HW: 03P 907 425 A
Component: R3 1.2l TDI H10 9980
Revision: 11002003 Serial number: CVN: E9B50FEA
Coding: 00114014000500080000
Shop #: WSC 80093 222 69422
ASAM Dataset: EV_ECM12TDI03103P906021AJ 001011
ROD: EV_ECM12TDI03103P906021AJ.rod
VCID: 70EF65C7ABA31A0F3F-8024
10 Faults Found:
15960 - Valve for Fuel Metering (N290)
P0090 00 [167] - Open Circuit
MIL ON - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Mileage: 143413 km
Date: 2000.00.00
Time: 00:00:00
Readiness: 0 0 0 0 1
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156043 km
Date: 2024.05.10
Time: 17:13:39
0934 - Please Check Fault Codes in Engine Control Module
U101F 00 [137] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 00:00:12
C104A F0 [137] - Incorrect VIN
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 98046 km
Date: 2023.08.23
Time: 00:00:02
U1013 00 [137] - -
Fault Priority: 2
Fault Frequency: 38
Reset counter: 13
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 01
Revision: 0003SH02
Coding: 0000A0
Coding: 48BC30
Component: E221__MFL-TAP H4ÿ 0021
Coding: E20000
Coding: 0400A0
Coding: 08BC32
4 Faults Found:
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:60
01516 - Terminal 30; Left
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 4
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:55
00927 - Terminal 30 (Right)
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 4
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:55
01229 - A/C Humidity Sensor (G260)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:59
Coding: 108001
Coding: 00314D
3 Faults Found:
9437723 - Igniter for Passenger's Airbag
B1002 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:44
9438747 - Igniter for Seat Belt Tensioner; Driver's Side
B1006 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:44
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:44
Coding: 140A00
1 Fault Found:
1416448 - Oil Level Thermal Sensor
B1041 29 [137] - Signal Implausible
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 00:03:04
Revision: B9074001
Coding: 002300
2 Faults Found:
01314 - Engine Control Module
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 53
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:16:32
03406 - Control Module for Battery Monitoring
Fault Priority: 2
Fault Frequency: 2
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 16:18:41
Serial number:
Coding: 020100
Data carrier:
3 Faults Found:
1048595 - Rear Left Bass Speaker
B1065 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 12:34:55
1048596 - Rear Right Bass Speaker
B1067 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 12:34:55
1048632 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:40
Coding: 11230
Shop #: WSC 00788
Coding: 030B1A5A
2 Faults Found:
00458 - Control Module for Battery Monitoring (J367)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:18:17
02252 - Generator
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:18:17
10 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 143413 km
Date: 2000.00.00
Time: 00:00:00
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156043 km
Date: 2024.05.10
Time: 17:13:39
U101F 00 [137] - -
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 00:00:12
Fault Priority: 2
Fault Frequency: 1
Reset counter: 224
Mileage: 98046 km
Date: 2023.08.23
Time: 00:00:02
U1013 00 [137] - -
Fault Priority: 2
Fault Frequency: 38
Reset counter: 13
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Coding: 01
Revision: 0003SH02
Coding: 0000A0
Coding: 48BC30
Coding: E20000
Coding: 0400A0
Coding: 08BC32
4 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:60
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 4
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:55
011 - Open Circuit
Fault Priority: 3
Fault Frequency: 4
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:55
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:15:59
Coding: 108001
Coding: 00314D
3 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:44
Fault Priority: 2
Fault Frequency: 1
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:44
Fault Priority: 2
Fault Frequency: 1
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:44
Coding: 140A00
1 Fault Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 00:03:04
Revision: B9074001
Coding: 002300
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 53
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:16:32
Fault Priority: 2
Fault Frequency: 2
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 16:18:41
Serial number:
Coding: 020100
Data carrier:
3 Faults Found:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 12:34:55
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.30
Time: 12:34:55
Fault Priority: 5
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Date: 2024.05.29
Time: 16:43:40
Coding: 11230
Shop #: WSC 00788
Coding: 030B1A5A
2 Faults Found:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:18:17
02252 - Generator
Fault Priority: 2
Fault Frequency: 1
Reset counter: 13
Mileage: 156188 km
Time Indication: 0
Date: 2018.10.20
Time: 14:18:17
And the advanced ID of the engine
Address 01: Engine
Control Module Part Number: 03P 906 021 AJ
Component and/or Version: R3 1.2l TDI H10 9980
Software Coding: 00114014000500080000
Work Shop Code: WSC 80093
Advanced Identification/FAZIT
Serial number:
Identification: DH1-00S
Revision: 11002003
Date: 30.10.13
Manufacturer number: UPS6
Test stand number: 0149
Flash Status
Programming Attempts(application): 0/3/3
Successful Attempts(application): 0/3/3
Programming Status: 00000000
Flash Date: ----.--.--
Software
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Misc.
Hardware number: 03P 907 425 A
Workshop System Name: J000
Equipment/PR Code: 4AF2158000000000
Dataset Number: 4F0909444AA
Dataset Version: D001
End of Line Equipment Level: 2D2D2D2D2D2D2D2D2D
ASAM Dataset Revision: 001011
Car Info
Chassis Number: WVWZZZ6RZEY155142
Engine code: CFWA
VCDS Info:
Labels: 03P-906-021-CFW.clb
Readiness: No script available
Address 01: Engine
Serial number:
Revision: 11002003
Date: 30.10.13
Flash Status
Software
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Unknown: 46.46.46
Misc.
Car Info
Engine code: CFWA
VCDS Info:
Cool, try this ABS coding: 21DD2485412800C58415246D825300421905
