There are some options that could work,
I am afraid that my ABS would limit them though.
Retrofit of the electric power steering from polo AW into polo 6R =)
- Shadow109
- Drives: Vw t5.1 2013
Re: Retrofit of the electric power steering from polo AW into polo 6R =)
Well done, I already got this unit but I am afraid its alot more complicated to install it on a transporter
I also encountered the same problem during the calibration process of the 2QD 909 144 steering rack.til3tsio wrote: Mon Sep 09, 2024 7:31 pm
from now on you have to do everything in VW EOL mode using 28183 login code.
go to flasher and select dsdl2 option and flash system parameters
after off/on ignition repeat the procedure with steering maps
After off/on ignition again go in adaptations and change
Plausibility check to Disabled
Characteristic curve of steering assistance to Dynamic
Driving profile switchover to Direct: controlled over threshold value
This method also applies to the calibration of the 2QD steering rack.
Thanks so much!
Address 44: Steering Assist (J500) Labels:. 2Qx-909-144-V3.clb
Part No SW: 2QD 909 144 F HW: 2QD 909 144 A
Component: EPS_ECU 420 4220
Serial number: 000009.12.21000 Dataset Number: V03935307HU 0001
Coding: 00000000010000000000020101000100000001000002
ASAM Dataset: EV_SteerAssisNSKGEN3MQB 003008
ROD: EV_SteerAssisNSKGEN3MQB_VW25.rod
VCID: 489505E2F3B3F2DB48-801C
No ASAM data for: "EV_SteerAssisNSKGEN3MQB" (VW25)
