Polo 2022 - when auto is switched for wipers it makes a noise
Cheese101
Drives: R line
Post by Cheese101 »
https://player.vimeo.com/video/1003727941?h=41705efe43
When I have my wipers set to auto and they wipe I hear this click noise. Is this normal? I have sat in other cars and I don’t hear any noises with auto wipers.
Dark_cze
Drives: AW GTI with MT
Re: Polo 2022 - when auto is switched for wipers it makes a noise
Post by Dark_cze »
Yes it is normal, there is relay switching power to wiper motor. :) I am pretty sure it should do it on every speed not just auto. :)
Maarten
Post by Maarten »
Only on interval should you hear the clicking.
And only when they operatie :lol:
On continious wiping the relais is on so no clicking.
Dark_cze
Post by Dark_cze »
Maarten wrote: Wed Aug 28, 2024 8:54 pm Only on interval should you hear the clicking.
Well on continues wiping it should click once you switch them on and once you turn them off :D
Maarten
Post by Maarten »
That's true :lol:
Ian T
Drives: 2024 GTi
Post by Ian T »
Cheese101 wrote: Wed Aug 28, 2024 6:43 pm https://player.vimeo.com/video/1003727941?h=41705efe43
Mine does the same.... only noticed it the other day after nearly two months of ownership :D
Polo 2610
Drives: Polo gti
Post by Polo 2610 »
The windshield wipers on the VW Polo GTI are very noisy, any solution?
Maarten
Post by Maarten »
Buy a good brand i.e. Bosch or Valeo, replace yearly
Polo 2610 wrote: Thu Oct 03, 2024 10:15 am The windshield wipers on the VW Polo GTI are very noisy, any solution?
Presumably you mean the actual wiper blades on the screen while they’re wiping are noisy, rather than the noise being caused by another part of the wiper system (e.g. worn bearing in the wiper motor or noisy wiper linkage).
Assuming you are referring to the wiper blades, then as @Maarten has suggested, replacing the blades would be the solution. I fitted Bosch Aerotwin wiper blades to my GTI+ and they were very good; quiet and smooth in operation.
Harrihealey02
Drives: 2018 SEL
Post by Harrihealey02 »
I've owned two Polos, and both had incredibly loud window wipers from the start. After enduring the constant juddering for three months, I switched to Valeo Silenco wipers, which are blissfully silent—exactly as they should be. I’ve never experienced new wipers that juddered so much. They were fitted with Bosch Aerotwin wipers, but I think the rubber compound was too brittle, causing them to jump on the windscreen. The Valeo Silencos, true to their name, are completely silent!
