Polo 6R 1.2 GT Tsi RHD
Re: Polo 6R 1.2 GT Tsi RHD
Hi, to activate GRA-high you need to read your CBZB ECU and send the file to whoever is going to activate it.
You can send the file reading to patil, me or whoever you prefer, we will return the ECU file with the active GRA-high to you.
To find out if the direct TPMS is present on that BCM check the Installation List on the GW (19). Address 65 should be present and codable.
I don't know for sure, but I think there shouldn't be any problem. What is the manufacturing date of that BCM?
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Post by sshakthi123 »
I’ll send you the ECU file separately.
Date of manufacturing of the BCM is 05.07.2019
And part number 7E0937089D and H84
Ok, send the ECU file to my email whenever you want.
Pretty sure that on that 2019 'H84' BCM you can activate the direct TPMS.
sshakthi123
Sure, I will have to reachout a person to read the file. I will share it with you asap.
It is great to know 089 bcm supports TPMS. Thanks for the support.
ECU file returned with GRA_High enable.
CCS OFF/ON to activate it or check that it works.
When stopped the mileage is displayed, as soon as you move the symbol is displayed on the MFD instead of the total mileage.
sshakthi123
Ciclo,
Thanks for all the help activating GRA high.
It is working as expected :mrgreen:
Great! 8) Enjoy it, it's a good driving aid. (magislavik things🧙‍♂️)
Regarding your email queries about the BCM Max adaptation, here are two links to installation tutorials:
- https://drive.google.com/file/d/1k3dhAA ... sp=sharing
- https://drive.google.com/file/d/0B2nv91 ... qdpZaURD-g
Note: If necessary, request permission to download the PDF, as soon as possible it will be shared with anyone who requests it.
It is convenient that you have the VW wiring diagrams for your vehicle to understand the previous tutorials.
Regarding your specific questions, in the pairs of wires of the same color, yellow or black it doesn't matter which, one is for +30 power supply of 'one side' of the BCM, and the other to feed the low beam when required. The other pair is the same.
Look at the size of the terminals and the position they occupy in each BCM connector.
There are 'thousands' of people wanting to do the BCM Max adaptation in PQ25, so I do not provide anyone with technical support for the BCM Max adaptation by email, please ask your questions here or search for information on the network/forums, there is a huge amount of information available.
I hope you understand. Thank you very much.🙏
I subscribe to your thread. :wink:
sshakthi123
Thanks Ciclo.
I was able to crack the pin numbers of both the pairs (yellow and black) and all set.
I have prepared the wirings on my own and will be installing anytime soon.
While I am able to make the BCM max adaptation wiring, I would need your help on auto lights wiring.
Is it possible to make auto light wiring for me? as it is very difficult to source the couplers terminals locally.
Thanks much for the understanding and support!
Sorry, I stopped making wiring harnesses for others a long time ago. I'm sincerely sorry. 🙏
Mainly due to health issues and disheartening demotivation on the part of third parties in the exchange of goods in the unfortunate place where I was accidentally born.
(Inefficient transport companies, abusive taxes, etc.)
Retali
Post by Retali »
ciclo wrote: Thu Oct 17, 2024 3:32 am Sorry, I stopped making wiring harnesses for others a long time ago. I'm sincerely sorry. 🙏
Are you talking about Spain ?
sshakthi123
Not an issue, thanks for all the support.
One quick query on the BCM max adaptation wiring.
For BCM max CAN lines has to be routed from BCM to IC -> T73B54 and T73B57
I already connected PDC CAN lines with IC lines - terminal 28, 29
Still should I isolate the original CAN lines? or should I tap?
Connect the new CAN lines (wires) for the instrument cluster (IC<->BCM).
You must isolate any free contact terminals from the 'old' powertrain CAN lines/Inst Cluster, these lines are completely 'live' for other very important systems.
CAN powertrain wires are fine with PDC.
sshakthi123
Ok fine. I’ll do accordingly. Thanks!
sshakthi123
Upgrading to BCM Max without auto lights.
Attaching the original relay box / headlight switch wiring for future reference.
sshakthi123
Something is coming up,
Friday,01,November,2024,22:37:39:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT
Mileage: 66520km-41333mi   Repair Order: BCM-Max
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F
VIN: MEXL15600GT052162   Mileage: 66520km-41333miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501505175568
   Coding: 0000024
   Shop #: WSC 30641 005 1048576
   VCID: 3A7B84EA755F9F9416-806E
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 62DD2463422803C24615246F4253C0800909
   VCID: 000F36029B03054418-8054
   Serial number: 10051504650266
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 089 D    HW: 7E0 937 089 D
   Component: BCM PQ25 MMI4 H84 0772
   Revision: BB084001    Serial number: 2602 180190154
   Coding: 3AB02BFF48A10000213806C07CEB9E90B0C041FF608C0000200400030000
   Shop #: WSC 00046 123 12345
   VCID: 3467AAD2973B69E4CC-8060
   Component: RLHS 200618 0  50  0107
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU031031440906027
   Coding: 1400B3
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU013011440132978
   Coding: 0400B3
   Subsystem 4 - Part No SW: 5TA 959 442     HW: 5TA 959 442
   Serial number: 1131818514601282AJ1B
   Coding: 250000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Serial number: 13202580150909024344
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581150901174201
   Coding: 020000
2 Faults Found:
00975 - Heated Rear Window (Z1)
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 66523 km
                    Time Indication: 0
                    Date: 2024.11.01
                    Time: 00:18:07
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 66523 km
                    Time Indication: 0
                    Date: 2024.11.01
                    Time: 00:17:34
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391606504499
   Coding: 0001151011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 377D9DDE8E4D82FCE9-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [008]
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 66523 km
                    Date: 2024.11.01
                    Time: 00:17:33
   Revision: --------    Serial number: 003GW0115JH8
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140801
   Shop #: WSC 00078 790 12345
   VCID: 479DED1EFEADF27C99-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 089 D
   Revision: BB084001
   Coding: 002307
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H05 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
   Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
   Component: MU-S--ER      H20 0240
   Serial number: VWZAZ2R8806143
   Coding: 02630100BE0000001111000101182A001F0100D60020010003
   Shop #: WSC 00066 790 00056
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2541479624E1006C4B-8070
1 Fault Found:
          U1101 00 [009] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 130
                    Mileage: 66523 km
                    Date: 2024.11.01
                    Time: 00:17:33
                    Voltage terminal 30: 12.1 V
End-------------------------(Elapsed Time: 02:51)--------------------------
