BCM Upgrade and not able to match the key
Hiroki
Drives: 6r Polo 1.2 TSI 2011
Re: BCM Upgrade and not able to match the key
Post by Hiroki »
Continue ……
If it's a RHD 😁:
New Engine coding:
002500F6202500080000
New GW coding:
002300
Thanks for the pictures of the Auto light switch. It's the correct one.👌
The images you just posted are enough, it is not necessary to install the old BCM.
I will do a new revision of your BCM coding, please wait for a while for a new BCM coding in next post.
Hiroki
Post by Hiroki »
ciclo wrote: Mon Nov 04, 2024 6:42 pm How are you feeding the 'a' inputs of fuses 39 and 59? +30 power is required.
Have you permanently/4ever removed the J331 relay?
'Example' for J331 relay (page 7):https://drive.google.com/file/d/0B2nv91 ... QkQNBJAwgQ
Auto lights.
Are you sure you have installed the wires in the relay adapters correctly?
Any special reason for a 6R LHD to be in Jamaica?
Communications here are very bad due to the catastrophic rainy season that we had, I even think that sometimes the posts sent are not loaded.
I apologize.🙏
a input for fuse39 & 59 is from the main line (not sure the correct terminology or not, it’s directly from the battery fuse 30)
J331 is removed and the bridge is installed. Right now it’s with temporary 10AWG wire connecting 3 & 5 of the relay.
I followed this picture.
And now yesssss it clicked me of the relay pin arrangement in the two new ones. I’m gonna check it when I can go outside. I’m beating my head right now. If it is the case, it’s my stupid mistake. Thanks for your kind help
Hiroki
Post by Hiroki »
ciclo wrote: Wed Nov 06, 2024 5:17 am If it's a RHD 😁:
New Engine coding:
New GW coding:
002300
Thank you sir!!!
Hiroki
Post by Hiroki »
ciclo wrote: Wed Nov 06, 2024 5:23 am The images you just posted are enough, it is not necessary to install the old BCM.
New BCM coding: (also provisional)
3CB82FBF28FB2400B33806B07CEB96D15FC0612F608C20D1200000020000
This new coding is to see what is the problem with the alarm, and everything else...
Good luck with your checks, don't worry, even the gods make mistakes and the planet keeps spinning just as well every day...🤭
The forum is not working properly for me, I get kicked every time I try to edit a new post and I have to log back in every time...
Sometimes the forum doesn't kick me and I can edit a new post without problems...
Hiroki
Post by Hiroki »
Sorry for the delay. My work is eating me alive. Will try to play with the car over the weekend and will let you know sir! Thank you so much!
If you allow me a little advice, do things with complete peace of mind, they should be pleasant moments, don't worry at all about the time it takes.
We will try to be here to see your progress. Thank you.👍
Hiroki
Post by Hiroki »
Thank you master!!!!!
That’s why master will always be master! :D
Yes indeed I’m stupid enough to wire the relay wrong.
I changed the wiring. And apply the coding that you provided.
So here is the output now.
Both front and rear fog lights working with pulling the switch.
When park light is on, DRL off
DRL on when the park light is off and handbrake is off
Corning light working.
However,
The alarm horn is still not working (no sounding)
The right rear light is doing funny thing, when I on turn signal to right, both the right park light and brake light blink alternatively. Not the turn signal light.
I’m getting the adaptation map and new scan. The forum kept kicking me out when I post something so I had to keep re-writing it again and again.
Thank you so much master, thanks for you kind help coz I truly understand it’s consuming your personal time while helping me.
Hiroki
Post by Hiroki »
Friday,08,November,2024,12:01:59:38219
VCDS Version: 24.7.1.0 (x64) HEX-V2 CB: 0.4656.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WVWZZZ6RZBU037606 License Plate:
Mileage: 194790km-121036mi Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56
VIN: WVWZZZ6RZBU037606 Mileage: 194790km-121036miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 BQ HW: 03F 906 070 D
Component: SIMOS10.20H02 9849
Revision: -------- Serial number: CVN: 949FC520
Coding: 002500F6202400080000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM12TFS02103F906070BQ 003010
ROD: EV_ECM12TFS02103F906070BQ_003.rod
VCID: 72BDCB884426752A59F-8026
VINID: 9E69EAAAA1A2A929400C718018574E6D87
Readiness: 0110 0101
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 23022BE3417000B9C42BD4E282D700801200
Shop #: WSC 31414 790 31414
VCID: 06558758586E798A657-8052
Address 08: Auto HVAC (ÿÿÿÿÿ) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 3537309475482212BCD-8060
Part No SW: 7E0 937 190 B HW: 7E0 937 190
Component: BCM PQ25 Max3 H81 0744
Revision: B8081001 Serial number: 0970 117220019
Coding: 3CB82FBF28FB2400B33806B07CEB96D15FC0612F608C20D1200000020000
Shop #: WSC 18752 008 00032
VCID: 2B0316ECA30C64E2DA9-807E
Component: RLHS 300518 0 50 0107
Coding: 008F77
Subsystem 2 - Part No SW: 6R0 959 802 S HW: 6R0 959 802 S Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 006 0903
Serial number: KU0-KU025.08.1012517
Coding: 18BC34
Subsystem 3 - Part No SW: 6R0 959 801 AA HW: 6R0 959 801 AA Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 006 0902
Serial number: KU0-KU024.08.1017757
Coding: 08BC34
Component: DWA-Sensor 00 001 0103
Component: LIN BACKUP HO H05 1501
Subsystem 7 - Part No SW: 1K8 959 442 HW: 1K8 959 442
Component: E221__MFL-MD9 H04 0103
Serial number: 27190003121620060022
Coding: A40000
Subsystem 8 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F
Component: J388__TSG_HL 006 0902
Serial number: KU0-KU001.09.1011977
Coding: 08BC32
Subsystem 9 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F
Component: J389__TSG_HR 006 0902
Serial number: KU0-KU016.08.1014939
Coding: 08BC32
Address 10: Park/Steer Assist (J446) Labels:* None
Part No SW: 6RD 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0007
Revision: -------- Serial number: 57921435200072
Coding: 308103
ASAM Dataset: EV_EPHVA18VW250GPCS 001004
VCID: 50F96100EA6A673A8FB-8004
Part No SW: 6R0 959 655 L HW: 6R0 959 655 L
Component: VW10Airbag00R H09 0020
Revision: -------- Serial number: 003GY001DNMQ Dataset Number: v00305166R0 0001
Coding: 003052
ROD: EV_AirbaVW10BPAVW250.rod
VCID: 4BC3766C034C44E2FA9-801E
Serial number: 3572SRB40000C64551E5
Serial number: 3582SRB40000C4185A98
Serial number: 3515RRB405B6VQ8C3GB/
Serial number: 3525RRB40636UBV85G8-
5 Faults Found:
9437723 - Igniter for Passenger's Airbag
B1002 1B [10001001] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:22
9440027 - Driver's side; side-airbag igniter
B100B 1B [10001001] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:22
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [10001001] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:20
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [10001001] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:20
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [10001001] - Open or Short to Ground
Fault Priority: 2
Fault Frequency: 1
Mileage: 194791 km
Date: 2024.11.08.
Time: 20:17:20
Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
Component: KOMBI H04 0304
Coding: 240A00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 372B3A9C6FC4D002AE1-8062
Part No SW: 7E0 909 901 HW: 7E0 937 190
Component: GW-K-CAN TP20 H81 0744
Revision: B8081001
Coding: 002300
VCID: 6889A9E0727A8FFAF7B-803C
Component: IMMO H04 0304
Serial number:
VCID: 6A8DD3E86CF6BDEAE1F-803E
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11230
Shop #: WSC 31414
VCID: 2F3B02FC9E5418C2F61-807A
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5614
Revision: -------- Serial number: VWZZZ4H6239179
Coding: 1F000440040001
VCID: 46D5475818AEB98A257-8012
End----------(Elapsed Time: 01:45, VBatt start/end: 13.1V/13.4V)-----------
Hiroki
Post by Hiroki »
adaptation map
;SW:7E0-937-190-B HW:7E0-937-190 --- Cent. Elect.
;Component:BCM PQ25 Max3 H81 0744, Coding:3CB82FBF28FB2400B33806B07CEB96D15FC0612F608C20D1200000020000
;Friday,08,November,2024,11:42:53:38219
;VCDS Version: Release 24.7.1 (x64) Data version: 20240919 DS356.3
;VCID: 2B0316ECA30C64E2DA9-807E
Channel,,Field 1,Field 2,Field 3,Field 4,
01,0,N/A,N/A,N/A,N/A,
02,,ERROR:,Channel 02,Not,Available,
03,1,N/A,N/A,N/A,N/A,
04,1,N/A,N/A,N/A,N/A,
05,0,N/A,N/A,N/A,N/A,
06,0,N/A,N/A,N/A,N/A,
07,1,N/A,N/A,N/A,N/A,
08,1,N/A,N/A,N/A,N/A,
09,1,N/A,N/A,N/A,N/A,
10,1,N/A,N/A,N/A,N/A,
11,1,N/A,N/A,N/A,N/A,
12,1,N/A,N/A,N/A,N/A,
13,1,N/A,N/A,N/A,N/A,
14,0,N/A,N/A,N/A,N/A,
15,0,N/A,N/A,N/A,N/A,
16,,ERROR:,Channel 16,Not,Available,
17,,ERROR:,Channel 17,Not,Available,
18,,ERROR:,Channel 18,Not,Available,
19,,ERROR:,Channel 19,Not,Available,
20,1,N/A,N/A,N/A,N/A,
21,,ERROR:,Channel 21,Not,Available,
22,1,N/A,N/A,N/A,N/A,
23,1,N/A,N/A,N/A,N/A,
24,0,N/A,N/A,N/A,N/A,
25,0,N/A,N/A,N/A,N/A,
26,,ERROR:,Channel 26,Not,Available,
27,0,N/A,N/A,N/A,N/A,
28,0,N/A,N/A,N/A,N/A,
29,1,N/A,N/A,N/A,N/A,
30,2,N/A,N/A,N/A,N/A,
31,0,N/A,N/A,N/A,N/A,
32,40,N/A,N/A,N/A,N/A,
33,80,N/A,N/A,N/A,N/A,
34,30,N/A,N/A,N/A,N/A,
35,2,N/A,N/A,N/A,N/A,
36,2,N/A,N/A,N/A,N/A,
37,80,N/A,N/A,N/A,N/A,
38,21,N/A,N/A,N/A,N/A,
39,20,N/A,N/A,N/A,N/A,
40,14,N/A,N/A,N/A,N/A,
41,20,N/A,N/A,N/A,N/A,
42,5,N/A,N/A,N/A,N/A,
43,3,N/A,N/A,N/A,N/A,
44,5,N/A,N/A,N/A,N/A,
45,100,N/A,N/A,N/A,N/A,
46,1,N/A,N/A,N/A,N/A,
47,15,N/A,N/A,N/A,N/A,
48,15,N/A,N/A,N/A,N/A,
49,,ERROR:,Channel 49,Not,Available,
50,0,N/A,N/A,N/A,N/A,
51,0,N/A,N/A,N/A,N/A,
52,0,N/A,N/A,N/A,N/A,
53,1,N/A,N/A,N/A,N/A,
54,1,N/A,N/A,N/A,N/A,
55,1,N/A,N/A,N/A,N/A,
56,0,N/A,N/A,N/A,N/A,
57,0,N/A,N/A,N/A,N/A,
58,1,N/A,N/A,N/A,N/A,
59,1,N/A,N/A,N/A,N/A,
60,200,N/A,N/A,N/A,N/A,
61,200,N/A,N/A,N/A,N/A,
62,5,N/A,N/A,N/A,N/A,
63,21,N/A,N/A,N/A,N/A,
64,0,N/A,N/A,N/A,N/A,
65,0,N/A,N/A,N/A,N/A,
66,3,N/A,N/A,N/A,N/A,
67,8,N/A,N/A,N/A,N/A,
68,0,N/A,N/A,N/A,N/A,
69,0,N/A,N/A,N/A,N/A,
70,20,N/A,N/A,N/A,N/A,
71,0,N/A,N/A,N/A,N/A,
72,0,N/A,N/A,N/A,N/A,
73,0,N/A,N/A,N/A,N/A,
74,0,N/A,N/A,N/A,N/A,
75,0,N/A,N/A,N/A,N/A,
76,0,N/A,N/A,N/A,N/A,
77,0,N/A,N/A,N/A,N/A,
78,0,N/A,N/A,N/A,N/A,
79,255,N/A,N/A,N/A,N/A,
80,0,N/A,N/A,N/A,N/A,
81,0,N/A,N/A,N/A,N/A,
82,0,N/A,N/A,N/A,N/A,
83,0,N/A,N/A,N/A,N/A,
84,0,N/A,N/A,N/A,N/A,
85,0,N/A,N/A,N/A,N/A,
86,0,N/A,N/A,N/A,N/A,
87,0,N/A,N/A,N/A,N/A,
88,0,N/A,N/A,N/A,N/A,
89,0,N/A,N/A,N/A,N/A,
90,0,N/A,N/A,N/A,N/A,
91,0,N/A,N/A,N/A,N/A,
92,0,N/A,N/A,N/A,N/A,
93,0,N/A,N/A,N/A,N/A,
94,0,N/A,N/A,N/A,N/A,
95,0,N/A,N/A,N/A,N/A,
96,0,N/A,N/A,N/A,N/A,
97,0,N/A,N/A,N/A,N/A,
98,,ERROR:,Channel 98,Not,Available,
99,0,N/A,N/A,N/A,N/A,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
You have to change the BCM adaptation channels 53 and 54 from 1 to 0.
I think I already mentioned this in a previous post.
Hiroki
Post by Hiroki »
Hi sir,
Thanks for pointing it out. I will change it and will update you. I figured out for the funny issue with right rear lamp. My puppy bite off my wires. I just finished re-wiring everything. Thank you so much for your patience and kind help.
Hi.
Ok, so the only thing left to solve is the alarm issue, right?
For the 6Rs there were two types of electronic alarms-sirens used, Bosch and Cobra. Your current Bosch is the most recent, so I assume it should work fine.
I have the Cobra from the factory and never had any issues when retrofitting all possible BCM models.
I don't know what the problem could be, although it has come up here on the forum on a few occasions due to BCM updates, or alarm retrofitting. You'll have to find out for yourself. You may need to change bit 0 and/or 1 in byte6 of the BCM or modify the value of the adaptation channel 62 of the BCM.
The adaptation range of channel 62 is 0-15, 5 is the default, ...try other values.
Channel 62.
Value [0-15] default 5, adjustment of the voltage monitoring range.
