Polo 6R 1.2 GT Tsi RHD
sshakthi123
Drives: Vento 1.5 TDI MT and Polo 6R 1.2 Tsi Dsg
Re: Polo 6R 1.2 GT Tsi RHD
Post by sshakthi123 »
I’m overwhelmed with the gifts 8) Thank you so much Ciclo!
I have done the installation today. Everything works fine except auto lights. Are there any coding changes to be done?
The day is looking up by the minute, we just finished the electrical installation of my wiring looms for Auto lights - BCM Max successfully for another user and now we are going to do the same for you.
Yes, a new BCM coding is required, please send me a recent/fresh Autoscan to my email. Thanks!
sshakthi123
Here is the latest scan,
Sunday,08,December,2024,17:12:49:00006
VCDS Version: 18.2.0.3
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT-AUTO-LIGHT
Mileage: 67830km-42147mi   Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F 65
VIN: MEXL15600GT052162   Mileage: 67830km-42147miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 KC    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 6270
   Revision: --H10---    Serial number:
   Coding: 00250056232400080000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
   VCID: 6DD17FB6BC91F82CC3-8038
Readiness: 0110 0101
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 065 N    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6561
   Revision: 00043014    Serial number: CU501505175568
   Coding: 0000024
   Shop #: WSC 30641 005 1048576
   VCID: 3A7B84EA755F9F9416-806E
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Component: ESP9.0i front H03 0003
   Serial number: --------------
   Coding: 62DD2463422803C24615246F4253C0800909
   VCID: 000F36029B03054418-8054
   Serial number: 10051504650266
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF348FAE1F773B46A-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 4189F306D889CC4C57-8014
   Part No SW: 7E0 937 089 D    HW: 7E0 937 089 D
   Component: BCM PQ25 MMI4 H84 0772
   Revision: BB084001    Serial number: 2602 180190154
   Coding: 3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D0210400030020
   Shop #: WSC 00046 123 12345
   VCID: 3467AAD2973B69E4CC-8060
   Component: RLHS 200618 0  50  0107
   Coding: 0714DD
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU031031440906027
   Coding: 1400B3
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU013011440132978
   Coding: 0400B3
   Subsystem 4 - Part No SW: 5TA 959 442     HW: 5TA 959 442
   Serial number: 1131818514601282AJ1B
   Coding: 250000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Component: -------------  006 5550
   Serial number: 13202580150909024344
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581150901174201
   Coding: 020000
2 Faults Found:
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:06:58
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:06:58
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391606504499
   Coding: 0001151011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: N/A
   VCID: 377D9DDE8E4D82FCE9-8062
No ASAM data for: "EV_EPHVA18VW364GP00" (VW25)
   Revision: --------    Serial number: 003GW0115JH8
   Coding: 003036
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4999EB26E8B9040C8F-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H05 0805
   Coding: 140801
   Shop #: WSC 00078 790 12345
   VCID: 479DED1EFEADF27C99-8012
   Part No SW: 7E0 909 901     HW: 7E0 937 089 D
   Revision: BB084001
   Coding: 002307
   VCID: 68DF0EA29B73DD04B0-803C
   Component: IMMO          H05 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74AA8D7FEF14A6-803E
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000000000000
   ROD: EV_SteerAssisNSK_014.rod
   VCID: 4189F306D089CC4C57-8014
   Part No SW: 5K7 035 200 D    HW: 5K7 035 200 D
   Component: MU-S--ER      H20 0240
   Serial number: VWZAZ2R8806143
   Coding: 02630100BE0000001111000101182A001F0100D60020010003
   Shop #: WSC 00066 790 00056
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2541479624E1006C4B-8070
1 Fault Found:
          U1101 00 [009] - Active
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Date: 2024.12.08
                    Time: 17:06:56
                    Voltage terminal 30: 13.1 V
   Serial number: 40000000256160
   ROD: EV_RDKBERU30_005.rod
End-------------------------(Elapsed Time: 02:58)--------------------------
New BCM coding (provisional):
Waiting for the results.
I haven't touched on the diagnosis of the lamps and their activation via PWM because I assume you have installed LED headlights and coded them accordingly.
I even think you are already an expert in these matters.
As I have already mentioned, we will be waiting for the results to study them and correct whatever is necessary. :wink:
Please, don't be in a hurry, now I'm going out with friends to see how Piastri or Norris win in F1, although I would also like a good surprise.
I won't be back until late afternoon (my afternoon), or even later, my friends are tireless.🤭
sshakthi123
Here is the latest,
results:;
1. high beam not working but pass light working
2. auto lights are not working
yes I have upgraded to led lights with the last codings by you.
Sunday,08,December,2024,18:02:10:00006
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT-AUTO-LIGHT-2
   Coding: 0000024
   Coding: 01
   Revision: V0000000
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
4 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus - Intermittent
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 15
                    Reset counter: 210
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:58:57
00979 - Lamp for Low Beam; Right (M31)
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 170
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:58:39
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:58:55
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:58:55
   Coding: 0001151011
   ROD: N/A
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Date: 2024.12.08
                    Time: 17:58:25
   Coding: 003036
   Coding: 140801
   Revision: BB084001
   Coding: 002307
   Serial number:
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Date: 2024.12.08
                    Time: 17:58:25
                    Voltage terminal 30: 12.3 V
End-------------------------(Elapsed Time: 03:01)--------------------------
3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D1210400030020
sshakthi123
new results;
1. high beam - works
2. auto lights - not working
www.Ross-Tech.com
   Coding: 0000024
   Coding: 01
   Revision: V0000000
   Coding: 3AB02BFF48A10000213806207CEB9E9090C0606F60CD19D1210400030020
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
2 Faults Found:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:06:58
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Time Indication: 0
                    Date: 2024.12.08
                    Time: 17:06:58
   Coding: 0001151011
   ROD: N/A
   Coding: 003036
   Coding: 140801
   Revision: BB084001
   Coding: 002307
   Serial number:
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Date: 2024.12.08
                    Time: 17:06:56
Sunday,08,December,2024,18:30:28:00006
www.Ross-Tech.com
   Coding: 0000024
   Coding: 01
   Revision: V0000000
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
   Coding: 0001151011
   ROD: N/A
1 Fault Found:
          - 00 [008]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Date: 2024.12.08
                    Time: 17:58:25
   Coding: 003036
   Coding: 140801
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 210
                    Mileage: 67831 km
                    Date: 2024.12.08
                    Time: 18:05:08
   Revision: BB084001
   Coding: 002307
   Serial number:
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67831 km
                    Date: 2024.12.08
                    Time: 17:58:25
End-------------------------(Elapsed Time: 03:11)--------------------------
3AB02BFF48A10000213806207CEB9E9090C0606F60CD39D1210400030020
sshakthi123
At a glance auto lights worked. I couldn’t check all the functions as I were rushing to leave somewhere on my sedan.
So I had to park 15/20 days at least to check again.
Thanks for the very quick support.
Finally both my cars equipped almost equal :mrgreen: (I waited so long for BCM max). Now only BSD and helix sub woofer are pending in my GT
Sunday,08,December,2024,20:11:53:00006
www.Ross-Tech.com
VIN: MEXL15600GT052162   License Plate: GT-AUTO-HL
Mileage: 67850km-42160mi   Repair Order:
VIN: MEXL15600GT052162   Mileage: 67850km-42160miles
   Coding: 0000024
   Coding: 01
   Revision: V0000000
   Coding: 3AB02BFF48A10000213806207CEB9E9090C0606F60CD39D1210400030020
   Coding: 0714DD
   Coding: 1400B3
   Coding: 0400B3
   Coding: 250000
   Coding: 020000
   Coding: 020000
   Coding: 0001151011
   ROD: N/A
1 Fault Found:
          - 00 [009]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67854 km
                    Date: 2024.12.08
                    Time: 20:08:42
   Coding: 003036
   Coding: 140801
   Revision: BB084001
   Coding: 002307
   Serial number:
1 Fault Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 170
                    Mileage: 67854 km
                    Date: 2024.12.08
                    Time: 20:08:42
                    Voltage terminal 30: 12.2 V
sshakthi123
ciclo wrote: Sun Dec 08, 2024 12:17 pm Please, don't be in a hurry, now I'm going out with friends to see how Piastri or Norris win in F1, although I would also like a good surprise.
Have fun :!: :wink:
Great! Thank you very much for the reports and for making my work easier! 😎
Without a doubt you have done a great job with the installation of the wiring, and in addition to enjoying the results you can feel very proud of it.👌
If any type of incident arises at any time, due to new checks or with daily use, you already know that we will solve it through the forum or by email.
Highly recommended BSD 😍, and whatever else arises...😊
sshakthi123 wrote: Sun Dec 08, 2024 4:46 pm
Have fun :!: :wink:
A beautiful and emotional end to the season, even in the last race you can see the DNA of the champions regardless of the place they fight for.💖
🏎 ... f1 forever ... 🏎
Exciting projects for next season.
sshakthi123
ciclo wrote: Sun Dec 08, 2024 7:01 pm Great! Thank you very much for the reports and for making my work easier! 😎
Sure thing, it is a first time I prepared the BCM max adaption wiring myself and I really felt great about it.
And this complete wiring installation I had done myself.
But the thing is I had to pause sometime to enjoy the results :x
ciclo wrote: Sun Dec 08, 2024 7:01 pm Highly recommended BSD 😍, and whatever else arises...😊
Awaiting for the right moment to dig through this but definitely in the way you had in your 6R. The BSD blinkers in the mirrors I really liked it and will wanted to update my Vento BSD lights as well. Please help sharing the required part numbers (links) where I can source them. Also wanted to wire for heated mirrors.
One more thing is about HBA. Can you point me the articles and the wirings. I will study them and come to an understanding.
ciclo wrote: Sun Dec 08, 2024 7:01 pm A beautiful and emotional end to the season, even in the last race you can see the DNA of the champions regardless of the place they fight for.💖
Unfortunately we do not or have very limited options to see the races here. But I definitely give a try in future when my work and personal times allow it.
Thank you master!
The Ali store for BSD mirrors no longer has the item for sale.🤷‍♂️ ... fortunately I bought enough BSD mirrors as spare parts for the supposedly long life of my 6R.🧙‍♂️🤭
They are on sale again, this is Ali's shop.
https://www.aliexpress.com/store/588370 ... eP9DeP9Dky
HBA is explained in my 6R thread.
Danedmunds
Drives: 2015
Post by Danedmunds »
Can anyone help with long coding on abs???
WVWZZZ6RZFY275793 My chassis number
