Giannis20vt's Polo 6c 1.0MPI
giannis20vt
Re: Giannis20vt's Polo 6c 1.0MPI
Post by giannis20vt »
ciclo wrote: Sun Dec 08, 2024 8:11 am It is inevitable under the appropriate temperature and humidity conditions.
The ventilation capacity of the headlights is limited.
I already fixed it.
I removed the light fixture, dried it, and reinstalled it.
Probably a rubber cap, it wasn't very well placed and water got in from there.
I'll keep a close eye on it.
giannis20vt
When i retrofit the RLS sensor, i bought a light switch (from Ali) made for Golf.
It fits perfectly and works fine, but..... it has white lighting.
I knew this when I bought it, it was just a really good price. I tried changing the white LEDs to red ones, but the lighting was very weak, even though I expected the opposite (because red LEDs need lower voltage.)
I'm thinking of painting the white LEDs red with special paint from a model shop.
Any other ideas?
just buy a second hand Polo light switch?
giannis20vt
iichel wrote: Fri Jan 10, 2025 4:11 pm just buy a second hand Polo light switch?
This is definitely a safe choice.
I like to experiment and create, as with most DIYs. However, IF I can't do the red color change myself, then I will probably choose to buy a used regular switch.
giannis20vt
#Gear lever leather
The leather on the gear lever had been worn out for a while. In fact, it had been like this since I bought the car.
I decided to buy one of these from Aliexpress
I found this for 7 euros.
The change happened today within about an hour.
Removing the lever.
On the left is the new one from China, on the right is the old one.
Removing the button
Placing the new leather
I could have placed it like this, but I preferred to use the original base, I liked the color of the nickel better.
So I removed the bases and adapted the old base with the new leather.
Place in place, tighten the clamp and you're done.
giannis20vt wrote: Fri Jan 10, 2025 11:02 am When i retrofit the RLS sensor, i bought a light switch (from Ali) made for Golf.
https://i.postimg.cc/137M4L19/light-swi ... m-Golf.jpg
Any other ideas?
Don't experiment here... No means No. :lol:
5G0941431AF ... AUTO, F&R fogs, red backlights, etc.
It is available on Ali and Autodoc at prices for all budgets.
https://www.aliexpress.com/item/3305100 ... ry_from%3A
POLO 6C (10-pin red connector).
giannis20vt
Yep,
this is also an alternative. Right now the switch I have is working fine, so I'm in no hurry to replace it.
CNK
Drives: 6R
Post by CNK »
Any other ideas?
what is part number of light switch with led backlight which is similar to 6RD941431A? :idea:
giannis20vt wrote: Sun Jan 12, 2025 6:29 pm Yep,
I read the posts you deleted.🤷‍♂️
The remotes/keys must be matched via ONline connection on both units, both IC and BCM. If I'm not mistaken, on the 6C both are part of the IMMO.
Did you use the guided function?
It is not a good idea to install both at the same time, but step by step, IMHO it is better to do the installation separately to avoid conflicts with VW servers and to be clear about what is happening in case of problems.
Apart from the codings, the adaptations of the units must also be transferred from the old units, and even then it is possible that you have some faults due to the new software of the new units. The reported faults are solved by coding and adaptation according to the vehicle equipment.... the usual thing that an experienced user like you already knows.
giannis20vt
ciclo wrote: Mon Jan 13, 2025 8:46 pm
Hello Fernando, this post is obviously for another thread. It would be good to move it to the correct thread so that the right person can read it.
OK! Whatever you see fit.
giannis20vt
ciclo wrote: Tue Jan 14, 2025 7:17 am OK! Whatever you see fit.
I don't know which thread, but I haven't had any problems with my car keys in a long time. So I thought this post is for another thread.
I guess I just received a very old notification in my email... what the... what a mess. Damn internet...😂
giannis20vt
ciclo wrote: Tue Jan 14, 2025 7:30 am I guess I just received a very old notification in my email... what the... what a mess. Damn internet...😂
📶🛜📡📡📶🛜 𝐁𝐑𝐎𝐊𝐄𝐍 🤦‍♂️😞
giannis20vt
Hello,
I bought a pair of these lights 3 months ago that replace the rear bumper reflectors. From the well-known Chinese store.
https://www.aliexpress.com/item/1005006 ... 180275C9tP
They piqued my curiosity when I saw them on the internet and bought them. I haven't decided yet whether I want to put them on or not. My concern is that the red reflective elements are also a safety feature and I wouldn't want to cancel them. On the other hand, these lights look very nice and can be connected in 3 ways. Either as a running light, or as a brake light, or as a dynamic turn signal, or of course in any combination of these three.
What is your opinion ?
