WANTED!--> 6R IND + 7E0 BCM MAX + Folding Mirrors from Switch (not Automatics).
To test a BCM Adaptation Channel and perhaps convert the folding mirrors just From the switch To Automatics with remote control/ign switch... without needing to change the WRMs.
Autoscan is required.
Shadow109
Drives: Vw t5.1 2013
Re: WANTED!--> 6R IND + 7E0 BCM MAX + Folding Mirrors from Switch (not Automatics).
Post by Shadow109 »
T6 would also be good ?
Yes, under the same conditions as those I request.
WRMs must be built for mirror folding from the switch, that is, with lower SW that is not able to manage them automatically.
I was just looking for '6R IND' because there are several forum members in these conditions.
adityagttsi
Drives: Polo GT 1.2 TSI
Post by adityagttsi »
Hello ciclo,
I will send scan of my car tomorrow. Matches your requirements. 7E0 937 090D and wrms with lower SW. Folding mirrors from the switch.
Note: Channel 84 is activated for auto folding mirrors which apparently doesn’t work in certain conditions.
Well, Channel 84 is the channel to check/test. I got the information from MrCollayder.💎 🤗 :arrow: https://www.drive2.ru/l/660460418082277734/
I did tests on my 6R, but as you all know I changed the WRMs with high SW for auto folding mirrors a long time ago, so for me it's not useful.
In my case the automatic folding function is lost when activating Channel 84 from 0 to 1. (I had some hope of achieving something more...😁)
Please could you be more specific about the conditions it works and under which conditions it doesn't work?
Maybe something else needs to be done.
Anyway, please post the Autoscan so we can do comparisons on the reference numbers/codings at any other time. Thanks!!
It would be nice to get something positive from these tests.
Shadow109
Post by Shadow109 »
I tried and my t6 the mirrors also folds also from the key, so I guess it doesn’t count
It doesn't count, but many thanks anyway!!!👍
...and you also have Kessy installed.😄
Since they are functions implemented in the BCM 7E0 (T6) I think/it is likely that they were implemented precisely for vehicles with Kessy, both channel 84 (folding mirrors) and channel 76 (SAFE driver's door lock), and thus do not depend on WRMs and SAFE locks. It's just a guess. 🤔
In my case, with factory SAFE locks, if I activate channel 76, 0->1, it does the double closing/opening 'twice' (click click + click click again... 😂) and faults are reported in the scan.
By the way, you have please to tell me how you installed RVC-High in your T5.1 regarding the management of communication with DM PQ (5F). Is it capable of managing parking assistance? I mean the steering wheel menu where it shows you the place to park (blocks) with the assistance lines.
The physical installation, calibration and coding is clear to me. If you prefer, we are in contact by email...
RVC High MQB 5Q0980556B on PQ -> https://www.t6forum.com/threads/reversi ... ost-665964 :arrow: https://www.drive2.ru/l/676189481673425763/
Is it possible to get that adapter to transform/adapt communications?
adityagttsi
Monday,13,January,2025,19:01:15:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.11.0.0 HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
Dealer/Shop Name: GermandnatoAdi
VIN: MEXJ19604LT057986 License Plate: UKPOLOS
Mileage: 64340km-39979mi Repair Order:
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 44 5F 65
VIN: MEXJ19604LT0XXXX Mileage: 64340km-39979miles
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 KC HW: 03F 907 309 AJ
Component: SIMOS10.22AH10 6270
Revision: --H10--- Serial number: CVN: 9408DB59
Coding: 00250056232400080000
Shop #: WSC 01234 785 00200
ASAM Dataset: EV_ECM12TFS02103F906070KC 004006
VCID: 6D87C9A91D1200B2F45-8038
VINID: 755A1A04918011C9001472481803BBEAEB
Readiness: 0110 0100
Part No SW: 0AM 300 043 C HW: 0AM 927 769 F
Component: GSG DQ200G2_PQ 050 2601
Revision: 00005008 Serial number: CU501906266575
Coding: 0000020
Shop #: WSC 01357 011 00200
VCID: 2B0307B1EF06CE82AA1-807E
Part No SW: 6R0 907 379 CB HW: 6R0 907 379 AS
Serial number: --------------
Coding: 62DD2463422803C7461D24714257C0800908
VCID: 0059801D3A80FDDA2F3-8054
Serial number: 07071913470686
Coding: 01
Shop #: WSC 00000 000 00000
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FEE540748B2A5DF-802A
Part No SW: 6R0 907 044 Q HW: 6R0 907 044 Q
Component: Climatronic H12 0615
Revision: V0000000
VCID: 41DF4519718A34D260D-8014
Part No SW: 7E0 937 090 D HW: 7E0 937 090 D
Component: BCM PQ25 Max4 H82 0762
Revision: B9082001 Serial number: 8601 320180219
Coding: 3AB82BF848A30000133806307CEB9E9002C0640F608D31412304000B0000
Shop #: WSC 12345 123 61029
VCID: 2C0104ADE608C9BAA3B-8078
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 270722 05 52 0106
Coding: 066800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13202848190716085938
Coding: 350000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849190711213513
Coding: 040000
Component: DWA-Sensor 00 001 0103
Subsystem 5 - Part No: 1K8 951 171 A
Subsystem 6 - Part No SW: 31G 959 442 HW: 31G 959 442
Serial number: 0401812433500024CX3J
Coding: 250000
Subsystem 7 - Part No SW: 6R0 959 811 S HW: 6R0 959 811 S
Component: J388__TSG_HL 022 1552
Serial number: 13102728190711175909
Subsystem 8 - Part No SW: 6R0 959 812 S HW: 6R0 959 812 S
Component: J389__TSG_HR 022 1552
Serial number: 13102729190711052611
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 19531723201065 Dataset Number: 160039v____ 0010
Coding: 0001155011
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: 372B2BC12FCE7A62DE9-8062
1 Fault Found:
12718592 - Databus
U1121 00 [00001001] - Missing Message
[Steuerger t f r Lenks ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 Q HW: 6C0 959 655 Q
Component: Airbag VW12 001 0503
Revision: -------- Serial number: 003FZAAYABLK Dataset Number: V03935303ZE 0001
Coding: 880000000000000054000000008000000065
Shop #: WSC 01383 785 00200
ASAM Dataset: EV_AirbaVW12TS6VW25X 001001
ROD: EV_AirbaVW12TS6VW25X_VW25.rod
VCID: 41DF4519710A34D260D-8014
Part No SW: 6RD 920 870 A HW: 6RD 920 870 A
Component: KOMBI H05 0805
Coding: 140800
Shop #: WSC 00046 123 12345
VCID: 47CB5B015F2E0AE2AE9-8012
Part No SW: 7E0 909 901 HW: 7E0 937 090 D
Component: GW-K-CAN TP20 H82 0762
Revision: B9082001
Coding: 002307
VCID: 6889B8BD3270259A873-803C
Component: IMMO H05 0805
VCID: 6A8DC2B52CFC178A917-803E
Address 44: Steering Assist (J500) Labels:| 1Sx-909-144-44.clb
Part No SW: 1S2 909 144 P HW: 1S2 909 144 P
Component: EPS_ECU H61 1702
Dataset Number: V03935277QZ 0001
Coding: 0001000000000000
Shop #: WSC 12345 123 12345
ROD: EV_SteerAssisNSK_014_VW12.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5K7 035 200 L HW: 5K7 035 200 D
Component: MU-S--ER H22 0480
Serial number: VWZAZ2R8032189 Dataset Number: 5K7CV1v__A_ 0001
Coding: 0262000EFF00000011110001001828001F0103D60020010006
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 2D0709A9DD92C0B2B45-8078
4 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Fault Priority: 4
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Voltage terminal 30: 11.8 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: ERROR
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
U1101 00 [00001001] - Active
[Anti-theft protection - component protection active (0xEA6300)]
Fault Priority: 4
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Voltage terminal 30: 12.0 V
0001 - Antenna 1 for Radio
B1119 13 [00001001] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Voltage terminal 30: 11.9 V
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 0 dB V
0003 - Antenna 2 for radio
B111A 13 [00001001] - Open Circuit
Fault Priority: 6
Fault Frequency: 1
Reset counter: 185
Mileage: 64342 km
Date: 2025.01.13
Time: 18:58:52
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 0 dB V
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H06 0011
Serial number: 30000000451195 Dataset Number: rdkseditor 0016
ROD: EV_RDKBERU30_005.rod
End----------(Elapsed Time: 01:37, VBatt start/end: 12.2V/12.2V)-----------
adityagttsi
Hello ciclo,
ciclo wrote: Sat Jan 11, 2025 8:34 pm Well, Channel 84 is the channel to check/test. I got the information from MrCollayder.💎 🤗 :arrow: https://www.drive2.ru/l/660460418082277734/
Condition - While locking the car keep pressing the lock button and mirrors would fold. For unfolding unlock the car and start the ignition. Mirror switch has to be always be in R position(for RHD vehicles)
Condition where it does not work - If use the remote two times 1st for locking the car and 2nd(long press for comfort function) than mirrors would fold but the unfolding does not work.
If the mirror switch is not in R position the unfolding does not work.
plus many more instances.
The only thing that does not work properly is the unfolding operation on ignition. Its very random. Folding operation works properly each and every time.
Hope this helps you solve this problem.
Hi adityagttsi, thank you very much for posting the autoscan.👌
Well, I guess there is no problem leaving the switch in the R position (for RHD) instead of position 0 if that is how the automatic folding and unfolding works, this does not affect other functions since the 6R does not have the possibility of mirror adjustment motors with memory for the tilt function with reverse gear.
Hmm... have you tried to coding channel 84 (0>1) and your WRMs at the same time in this way?
Coding: 350000 ---> 350001 or 350002 or 350003.
Coding: 040000 ---> 040001 or 040002 or 040003.
Remember that every time you code the WRMs the window comfort function must be reset.
I guess nothing will happen, but nothing is lost by trying.
(the mysterious coding of WRMs according to year and place of manufacture)
adityagttsi
Hello, ciclo
None of the codes are accepted by the wrms. Request out of range error.
I sincerely appreciate your effort in doing these tests, I am truly sorry that it was a waste of your time.🙏
These methods of doing things are not the best, but we work with what we have available... if we get a positive result then it is easier for everyone else.
The thread remains open in case new ideas arise.
