Skoda Octavia MK4 2023, 2.0TDi DSG Ambition
patil
Re: Skoda Octavia MK4 2023, 2.0TDi DSG Ambition
Post by patil »
There is a trick which you can try. There is no guarantee that it will work, but no harm in trying.
Find a MK4 octy VIN where 2Q0 H BSD radars are installed from factory.
Find fuses for cluster and ECU in fuse box and remove them temporarily.
Run ODIS-S with online connection, enter new VIN manually, start diagnosis and go to control modules list, select 3C, right click, select guided functions.. in GF list select " replace control module".. follow the steps and see if it goes through successfully. Removing CP, parametrisation, coding will all happen sequentially if you are lucky!
Good luck and let us know what happens.
patil wrote: Mon Feb 10, 2025 5:03 pm Find a MK4 octy VIN where 2Q0 H BSD radars are installed from factory.
Difficult task, maybe some SK OctiviO that is at an SK dealership for customer testing or something like that.🤷‍♂️
giannis20vt
Post by giannis20vt »
patil wrote: Mon Feb 10, 2025 5:03 pm There is a trick which you can try. There is no guarantee that it will work, but no harm in trying.
Thank you for the idea. It seems to be particularly difficult to implement. I need to find a matching car, an owner who wants to enter into such a process, and all this for a car that I will have for another 2.5 years (remember that I have it on lease).
CP was finally removed with your friend's official VAS?
Another thing you can try is to forget about these H radars and try to install ones that don't need to remove CP.
However you will have to unlock the SFD of the modules involved.
Giannis, when possible, can you please post a VCDS Autoscan with the current status of your Octavia with the H radars installed? Thanks.
giannis20vt
ciclo wrote: Wed Feb 12, 2025 7:43 am CP was finally removed with your friend's official VAS?
I haven't found the time yet to go back to his workshop. I work quite far from his office and the hours don't match. I will.
So, here's the log
Thursday,13,February,2025,21:15:04:16365
VCDS Version: 24.7.1.0 (x64)  HEX-V2 CB: 0.4658.4
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: TMBAJ8NX7PY??????   License Plate: EASERS
Chassis Type: NX-SK38 (5WB)
Scan: 01 02 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 52 5F 6C 75
          A5
VIN: TMBAJ8NX7PY150639
05-Acc/Start Auth. -- Status: OK 0000
23-Brake Booster -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Cannot be reached 0100
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-DTTC)       Labels: None
   Part No SW: 05L 906 022 HM    HW: 05L 907 309 AA
   Component: R4 2.0l TDI   H80 2095
   Revision: ECH80---    Dataset Number: V03935396BD 0001 CVN: 7D11648C914A6D20914A6D2043FB2DAA
   Coding: 012508320324050930080000000000000000000000000000
   Shop #: WSC 31000 790 00540
   ASAM Dataset: EV_ECM20TDI01105L906022HM 008001
   ROD: EV_ECM20TDI01105L906022HM.rod
   VCID: 79AFEDF9595AAC12185-802C
   VINID: 91D4916887A81E0A4114018324CC91AE7D
Readiness: 0 0 0 1 1
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0GC 906 555 P    HW: 0GC 300 047 K
   Component: GSG DQ381     H06 4161
   CVN: BC808938
   Coding: 0014
   ASAM Dataset: EV_TCMDQ381062 001001
   ROD: EV_TCMDQ381062_VW38.rod
   VCID: 48C9583D5230059AD7B-801C
   Subsystem 1 - Part No SW: 5WA 713 033 BS    HW: 610 5
   Component: ZSB_SB_AUTO    H08 1034
   Serial number: 20230209000086112352
   Subsystem 2 - Part No SW: 5E4 713 203     HW: 5E4 713 203
   Component: ZSB_SB_mono    H02 0025
   Serial number: 23 130 0001 L 1 U2B8
   Subsystem 3 - Part No SW: 0GC 927 373 M    HW: 0GC 927 373 M
   Component: SMOP DQ381     H04 0001
   Serial number: C7458810700005315074
Address 03: ABS Brakes (J104)       Labels: 5WA-614-517-V1.clb
   Part No SW: 5WA 614 517 CF    HW: 5WA 614 517 N
   Component: ESC           H13 0135
   Serial number: 61323000004767  Dataset Number: V03935390HX 0001 CVN: 83FF7D8B
   Coding: 34072CA42225446C527D50030ACC61866DB658F55AC8670821BCA231018FF100002814
   ASAM Dataset: EV_Brake1ESCEPBMQB37W 013058
   ROD: EV_Brake1ESCEPBMQB37W_013_AU38.rod
   VCID: 0E45AE2570D49BAADD7-805A SFD
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 P    HW: 5WA 959 436 P
   Component: Kessy IOBOX   100 0725
   Serial number: --------------- Dataset Number: V03935347FV 0001
   ASAM Dataset: EV_Kessy37w 004024
   ROD: EV_Kessy37w_004_VW38.rod
   VCID: 619FA599D1CA54D2305-8034
Address 08: Auto HVAC (J979)       Labels:* Redir Fail!
   Part No SW: 5WA 907 727 AC    HW: 5WA 907 727 AC
   Component: Climatronic   H02 0440
   Serial number: --------------- Dataset Number: V03935358W  0001
   Coding: 101010010211120000000000101011110000112100100000000000000000
   ASAM Dataset: EV_ACClimaBHBVW38X 005069
   ROD: EV_ACClimaBHBVW38X_VW38.rod
   VCID: 117FB55961EA8452C05-8044
   Air quality sensor:
   Subsystem 1 - Part No SW: 5Q0 907 659 D    HW: 5Q0 907 659 D
   Component: G238 _AQS      H02 0003
   Serial number: 00000000010000160072
   Interior temperature sensor:
   Subsystem 2 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002020523154344508
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5WA 937 086 AT    HW: 5WA 937 086 AT
   Component: BCM37w_M132 0180
   Serial number: BXJ53F240423951 Dataset Number: V03935373LG 0001
   ASAM Dataset: EV_BCM37w 007001
   ROD: EV_BCM37w_007_AU38.rod
   VCID: 2313EF918B5606C2629-8076 SFD
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5E4 955 119 A    HW: 5E4 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: J400FRWISCH    067 0084
   Serial number: 907453F0302308900376
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 81A 955 555 B    HW: 81A 955 555
   Component: G397_RLFSS     H06 0004
   Serial number: 21546257X81A955555B0
   Light switch:
   Subsystem 3 - Part No SW: 5E4 941 501 A    HW: 5E4 941 501
   Component: E1-LTM         H30 0550
   Serial number: 00000000000000001879
   Control head for driving and comfort functions:
   Subsystem 4 - Part No SW: 5E3 925 200 E    HW: 5E3 925 200
   Component: DiETa          H05 0004
   Serial number: 01557WDA000GS
   Roof electronics control module:
   Subsystem 5 - Part No SW: 5E3 959 569 A    HW: 5E3 959 569 A
   Component: DACHKONSOLE    101 0104
   Serial number: 000000092413WE501884
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 FN    HW: 5Q1 953 549 D
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000005052308490700
   left tail lamp 1:
   Subsystem 7 - Part No SW: 5E3 945 207 A    HW: 5E3 945 207 A
   Component: SHL_li1        005 1214
   Serial number: ABMRO129042300050947
   left tail lamp 2:
   Subsystem 8 - Part No SW: 5E6 945 307 A    HW: 5E6 945 307 A
   Component: SHL_li2        005 1214
   Serial number: ABMRO108052300041666
   Right rear tail lamp 1:
   Subsystem 9 - Part No SW: 5E3 945 208 A    HW: 5E3 945 208 A
   Component: SHL_re1        005 1214
   Serial number: ABMRO124042300054328
   Right rear tail lamp 2:
   Subsystem 10 - Part No SW: 5E6 945 308 A    HW: 5E6 945 308 A
   Component: SHL_re2        005 1214
   Serial number: ABMRO104052300040741
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5R3 919 283     HW: 5R3 919 283
   Component: PDC 04 Kanal  H05 1550
   Serial number: 000A29256323136 Dataset Number: V03935382CU 0001
   Coding: 0000010011
   ASAM Dataset: EV_EPHVA14VW3800000 001009
   ROD: EV_EPHVA14VW3800000_VW38.rod
   VCID: 7AADF2F55C5CA70A11F-802E
Address 13: Auto Dist. Reg (J428)       Labels:* None
   Part No SW: 5WA 907 572 C    HW: 5WA 907 572 A
   Component: ACC BOSCH MQB H40 0461
   Dataset Number: V03935385FB 0001
   Coding: 08030075407740451247400000C000C5AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARBOSCHVW380 004021
   ROD: EV_FRONTRADARBOSCHVW380_004_VW38.rod
   VCID: 4EC56E25B054DBAA9D7-801A
Address 15: Airbags (J234)       Labels:* 5WA-959-655.clb
   Part No SW: 5WA 959 655 L    HW: 5WA 959 655 L
   Component: AirbagVW40    010 0636
   Serial number: 000000003C0J2R9 Dataset Number: V03935381LU 0001
   Coding: 98CC008000C0C000000000000000000050540000205400004000F68000130065
   ASAM Dataset: EV_AirbaVW40SMEVW38X 001032
   ROD: EV_AirbaVW40SMEVW38X.rod
   VCID: 6099A09DDAC05DDA3FB-8034 SFD
   Subsystem 1 - Part No SW: -----------    HW: 480 051 005 23
   Component: SideSensor_Dr  000 0149
   Serial number: 351000082C257499A696
   Subsystem 2 - Part No SW: -----------    HW: 480 051 005 23
   Component: SideSensor_Pr  000 0149
   Serial number: 352000094C6D2210235Q
   Subsystem 3 - Part No SW: -----------    HW: 480 040 405 23
   Component: SideSensor_Df  001 0887
   Serial number: 357000085247588C2C35
   Subsystem 4 - Part No SW: -----------    HW: 480 040 405 23
   Component: SideSensor_Pf  001 0887
   Serial number: 35800008524F50586D78
   Subsystem 5 - Part No SW: -----------    HW: 480 051 302 23
   Component: FrontSensor_D  000 014A
   Serial number: 355000073268FC926715
Address 17: Instruments (J285)       Labels:* None-SRI2
   Part No SW: 5E3 920 741 B    HW: 5E3 920 741 B
   Component: KOMBI         300 6423
   Serial number:                 Dataset Number: V03935381RM 0001
   Coding: 04A5004063840008018062032000080800301400
   ASAM Dataset: EV_DashBoardVISMQB37W 002021
   ROD: EV_DashBoardVISMQB37W_002_VW38.rod
   VCID: 2615F685F864F3EA057-8072 SFD
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 5WB 907 530 H    HW: 5WB 907 530 H
   Component: GW2020 High   842 8310
   Serial number: BXJ53F100523958 Dataset Number: V03935378UZ 0001
   Coding: 0000808D0700000000000000012303324101500902000300030100000001000100000000000000000000000000000000
   GVL: 3D000000020840CC80008002C800004004004000000000000000000000000044
   ASAM Dataset: EV_GatewMQB2020 006012
   ROD: EV_GatewMQB2020_006_VW38.rod
   VCID: 4EC56E25B054DBAA9D7-801A SFD
   Generator:
   Subsystem 2 - Part No SW: 5WA 915 181 C    HW: 5WA 915 181 C
   Component: J367-BDMHella  H11 9080
   Serial number: 0633282006
   Multifunction steering wheel control module:
   Subsystem 3 - Part No SW: 5E3 919 719 J    HW: 5E3 919 719 J
   Component: E221__MFL-PR6  H02 0110
   Serial number: PR6-0440062117230661
1 Fault Found
2097230 - Lane change assistant control module
          U1045 00 [00101111] - No communication
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 54902 km
                    Date: 2025.02.13
                    Time: 21:01:57
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 5WA 909 059 AB    HW: 3Q0 909 059 C
   Component: EBKV          H09 0372
   Serial number: BPA085120523013 Dataset Number: V03935366JF 0001
   Coding: 1002C500230000CE39E79C73000049922449922400
   ASAM Dataset: EV_BrakeBoostG2BoschVW37W 016028
   ROD: EV_BrakeBoostG2BoschVW37W_016_VW38.rod
   VCID: 1079B05D6AE08D5ACFB-8044 SFD
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 2Q0 905 861 B    HW: 2Q0 905 861 B
   Component: ELV-MQBB      H10 0040
   Serial number: 23000082187013 Dataset Number: V03935308NF 0001
   Coding: 8800000000000000
   Shop #: WSC 31000 790 00604
   ASAM Dataset: EV_ELVMarqMQBA0 002004
   ROD: EV_ELVMarqMQBA0_VW38.rod
   VCID: 323D1AD5C4AC9F4A99F-8066
Address 3C: Lane Change (J1086)       Labels:* Redir Fail!
   Part No SW: 2Q0 907 686 H    HW: 2Q0 907 686 H
   Component: HRE_Master    H26 0320
   Serial number: 00000647987427
   Coding: 00000000
   ASAM Dataset: EV_HREHellaGen3MstrUNECE 001001
   ROD: EV_HREHellaGen3MstrUNECE_VW27.rod
   VCID: 3FDB43E107FE4222661-806A
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 H    HW: 2Q0 907 685 H
   Component: HRE_Slave      H26 0320
   Serial number: 00000648365408
3 Faults Found
1310721 - invalid data record
          B2005 00 [00101111] - -
          [Dataset is invalid]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 54902 km
                    Date: 2025.02.13
                    Time: 21:01:55
1572868 - Control module not coded
          U1013 00 [00101111] - -
          [System - coding is missing]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 54902 km
                    Date: 2025.02.13
                    Time: 21:01:55
15361024 - Component Protection
          U1101 00 [00101111] - Active
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 54902 km
                    Date: 2025.02.13
                    Time: 21:01:55
Address 42: Door Elect, Driver (J386)       Labels:* None
   Part No SW: 5Q4 959 393 P    HW: 5Q4 959 393 P
   Component: TSG FS        009 0911
   Serial number: 0000488817310  Dataset Number: V03935407GA 0001
   Coding: 001401208000020000001120
   Shop #: WSC 12345 123 61029
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 50F9705DAA60CD5A8FB-8004
   Subsystem 1 - Part No SW: 5Q0 959 407 D    HW: 5Q0 959 163 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  007 0011
   Serial number: 00000000000070373864
   Coding: 110200
Address 44: Steering Assist (J500)       Labels:| 5WA-907-14X-V1.clb
   Part No SW: 5R3 907 146 A    HW: 5R3 907 146
   Component: BASGEN1MQB37  261 2040
   Serial number: 00002125 Dataset Number: V03935343JU 0001
   Coding: 0000000000000001000002010100010000000101010101
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 363526C528C4836AB57-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392 P    HW: 5Q4 959 392 P
   Component: TSG BFS       009 0911
   Serial number: 0000488834053  Dataset Number: V03935407GD 0001
   Coding: 001401208400020000001120
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 4FFB7321B75ED2A2961-801A
   Subsystem 1 - Part No SW: 5Q0 959 408 D    HW: 5Q0 959 164 C  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  007 0011
   Serial number: 00000000000070454960
   Coding: 090200
Address 5F: Information Electr. (J794)       Labels:| 3G5-035-MIB-HGH3.clb
   Part No SW: 5E3 035 816 N    HW: 5E3 035 816 A
   Component: MU-O-ND-EU    H61 1985
   Serial number: WG8LGM080523000 Dataset Number: V03935373AK 0001
   Coding: 33810000008000000000000000000000000000000000000000
   ASAM Dataset: EV_MUOIMQB37w 001002
   ROD: EV_MUOIMQB37w_001_SK38.rod
   VCID: 323D1AD5C4AC9F4A99F-8066 SFD
Address 6C: Back-up Cam. (J772)       Labels:| 5WA-980-556.clb
   Part No SW: 5WA 980 556 D    HW: 5WA 980 556 B
   Component: RV eCompact   H30 0344
   Serial number: FCLK20060523010 Dataset Number: V03935343SU 0001
   Coding: 03033200843000
   ASAM Dataset: EV_CamSysRVCCompaFicos 010024
   ROD: EV_CamSysRVCCompaFicos_010_VW38.rod
   VCID: 52FD7A55A46CBF4AB9F-8006
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 284 F    HW: 5WA 035 284 C
   Component: OCU3HMQB37W   H14 0144
   Serial number: 0000000304VIVRD Dataset Number: V03935390FC 0001
   Coding: 033810109069A0809005460061052607
   ASAM Dataset: EV_OCU3HMQB37W 002012
   ROD: EV_OCU3HMQB37W_002_VW38.rod
   VCID: 49CF5D39493AFC92C85-801C SFD
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 5WA 980 653 D    HW: 5WA 980 653
   Component: MQB MFK 3.0   H09 3403
   Serial number: EA8808904231010 Dataset Number: V03935403KE 0001
   Coding: 0002088811484040409F00001020002001018000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 005055
   ROD: EV_MFK3ValeoMQB_005_SK38.rod
End----------(Elapsed Time: 01:04, VBatt start/end: 12.1V/12.1V)-----------
Thank you very much Giannis.👌
Even the component protection was not removed, which should be a simple thing once you connected to the VW servers.
This is a big 'Enigma'...
Very bad luck for the unwary buyers of VW group 2024-> vehicles.
giannis20vt
# BSD installation
Update
Yesterday I went to my friend's garage again and we tried to match the radars (removing the component protection)
We tried to do what we could, we tried all the possible processes that the program had, but we couldn't unlock the radars.
I don't know what's wrong, we've been trying for almost an hour.
So it seems that the project will come to an ignominious end.
I don't know if with used radars something better could be done, but I don't have much hope and I don't have the courage to keep removing the bumper.
Thanks for reporting Giannis.
As I mentioned, you can try it with other non-H radars, such as the 2QD-->2Q0 B that I plan to install in my 6R. Don't be discouraged, the bumper can be removed and put on in 0,5 minutes.
BTW, those new H radars can be thrown away, you don't need to take them to a recycling point, they are manufactured in such a way that they easily degrade on their own in some African country.
giannis20vt
ciclo wrote: Thu Feb 27, 2025 3:50 am Thanks for reporting Giannis.
:roll: :)
I will be back
:shock: :o
giannis20vt wrote: Thu Feb 27, 2025 6:50 pm
:shock: :o
I think it would be best to give them away, they can also serve as entertainment for some Hacker.
giannis20vt
ciclo wrote: Thu Feb 27, 2025 9:43 pm
:shock: :o
OK Fernando, please let me know if you know anyone. I will arrange to send them these radars.
Hackers are unknown people. 🤷‍♂️😄
giannis20vt
#BSD retrofit
I read on another forum that in order to have any chance of success, the radars must have an index of G or older, since only such ones have been installed in this particular car so far.
Ι will search for used radars with index D, E or G. If I find cheap ones, I'll buy them to try it out.
No SFD2 diagnostic protection/invention.
giannis20vt
From ETKA,
There are 2 pages, one named "Control Unit for Lane Change Assist", the other named "Control Unit for Blind Spot Detection"
I wonder why this separation exists.
