Modified Airbox
diablohowes
Modified Airbox
Post by diablohowes »
Hey,
Just wondering can i remove everything inside the green line?
And what kind of effect will this have on the engine and general running?
*edit For some reason the picture won't show, but this is the link to the photo.
http://www.imagestation.com/picture/sra ... 91ef34.jpg
bstardchild
Moderator
Post by bstardchild »
linky not work :cry:
GroovyCarrot
Sponsor
Post by GroovyCarrot »
You can, and it would run alright, but you'd be losing both your cold air flow from behind the grille and your warm air flow for winter driving. If you want to do something to improve the cold air intake, I'd advise you unclip the intake after the hot/cold splitter, that way everything will still be fully functional. Won't make a massive difference if you don't want to do that though :)
bstardchild
Moderator
Forbidden
You don't have permission to access /picture/sraid143/p9f8c42dc1417f832a9d73b98ff0469ad/f691ef34.jpg on this server.
Apache/1.3.29 Server at www.imagestation.com Port 80
So why do I get refused when Carrot can....... *Leaps of to check internet settings and comes back even more confused
GroovyCarrot
Sponsor
There you go :)
bstardchild
Moderator
Thanks M8
That helps a lot - still dunno why I can't use the original link.......
Gareth_GT_Hatch
Post by Gareth_GT_Hatch »
In answer to yor original question; yes you can remove all that. Even though it does provide a ramair effect into the engine, it is very restrictive. You should also remove the air temperature switch in the throttlebody elbow as all this does is control the warm air feed - which you are taking off! :P This will improve airflow in that area.
