Need help on MFSW
sejuani
Drives: POLO 6R
Need help on MFSW
Post by sejuani »
Hello everyone,
My POLO was originally equipped with an MFSW and a stalk, both without CCS.
In 2023, I upgraded to a stalk with CCS and experienced the convenience that CCS brings.
However, this year, I discovered an MFSW with CCS, and I quickly installed the 6C0 959 442 F MFSW.
Currently, the issue I'm facing is that CCS isn't functioning (though all other buttons and backlighting are normal).
Below is a video of the VCDS test (where the CCS switch anomaly can be observed):
[youtube]https://youtube.com/shorts/oPpENAlKyyE?feature=share[/youtube]
Before installation, I searched posts on DRVIVE2.
https://www.drive2.ru/l/619133624284901918/
https://www.drive2.ru/l/635088637515536476/
https://www.drive2.ru/l/535610322992497322
Some people said the CCS on the MFSW 6C0 959 442 F works, while others said it doesn't. The reason appears to be that the ECU(I have a CLSA engine) cannot receive GRA messages through LIN.
The solutions I've found so far are:
- Modifying ECU coding.
- Installing a Cruise Control Emulator.
- Reverting to the old CCS-equipped stalk.
Since the first two options are too challenging, I plan to use the third method.
I want to ask everyone: Is it possible to use the stalk’s CCS on/off functionality, while controlling SET, RES, +, - through the MFSW?
Although my answer should be negative, because I received an error message from E45.
Chassis Type: 60-VW25 (7E0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 3C 44 56 65
VIN: WVWZZZ60ZHT132658   Mileage: 168730km-104843miles
Address 01: Engine
Cannot be reached
Address 02: Auto Trans        Labels: 09G-927-750.clb
   Part No SW: 09G 927 750 LK    HW: 09G 927 750 LK
   Component: AQ 250 6F           2601
   Revision: 00H98000    Serial number:
   Coding: 0000328
   Shop #: WSC 00000 000 08192
   VCID: 050BCCD64F212F679F-5178
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.lbl
   Part No SW: 6R0 907 379 CB    HW: 6R0 907 379 AS
   Serial number: --------------
   Coding: 61DD2463422603C2861A246E4259C0400809
   Shop #: WSC 00049 770 08192
   VCID: 0005DDC29B030A4FAC-8054
   Serial number: 02081613470700
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF9A33AE1F77C6BB2-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 418318C6D889C3938F-8014
   Part No SW: 7E0 937 090 D    HW: 7E0 937 090 D
   Component: BCM PQ25 Max4 H82 0762
   Revision: B9082001    Serial number: 9502 361220028
   Coding: 3AB02FB828F36E00B33806C07DEB9E90F0CC62F0608F21C02204003F0840
   Shop #: WSC 00046 123 12345
   VCID: 2C5D59724F0B3EFB4C-8078
   Component: RLHS 091221 0  50  0107
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 801 EC    HW: 6R0 959 801 EC  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  023 2551
   Serial number: 13102851160307203215
   Coding: 640000
   Subsystem 3 - Part No SW: 6R0 959 802 EG    HW: 6R0 959 802 EG  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  023 2551
   Serial number: 13102850160217193348
   Coding: 640000
   Subsystem 4 - Part No: 6RU 951 171
   Component: Sensor, DWA 0  005 0502
   Subsystem 6 - Part No: 6RU 951 171
   Subsystem 7 - Part No SW: 6C0 959 442 F    HW: 6C0 959 442 F
   Serial number: 1831904095200607CE3J
   Coding: 280000
   Subsystem 8 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  022 1552
   Serial number: 13202728170223141457
   Subsystem 9 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  022 1552
   Serial number: 13102729170223103338
3 Faults Found:
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 168738 km
                    Time Indication: 0
                    Date: 2019.08.30.
                    Time: 20:42:54
03432 - Activation of Right Parking Light
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 168738 km
                    Time Indication: 0
                    Date: 2019.08.30.
                    Time: 20:42:54
01134 - Alarm Horn (H12)
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 85
                    Mileage: 168738 km
                    Time Indication: 0
                    Date: 2019.08.30.
                    Time: 20:28:35
   Part No SW: 7E0 919 475 AA    HW: 56D 919 475
   Component: PARKHILFE 8K  H02 0212
   Revision: --------    Serial number: 35841522901332
   Coding: 30A101
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71E38806A0A913133F-8024
   Component: VW10AirbagU0J H10 0020
   Revision: --------    Serial number: 003GW019WCZB Dataset Number: 00000000000 0001
   Coding: 00304A
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 499300E6E8B90BD357-801C
   Part No SW: 5C6 920 874 D    HW: 6JA 920 940 C
   Component: KOMBI         H05 0818
   Coding: 180C01
   Shop #: WSC 73430 031 00209
   VCID: 30654D026B235A1B70-8064
1 Fault Found:
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [00001000] - -
                    Fault Priority: 6
                    Fault Frequency: 85
                    Reset counter: 125
                    Mileage: 168448 km
                    Date: 2025.04.06.
                    Time: 21:22:30
   Part No SW: 7E0 909 901     HW: 7E0 937 090 D
   Component: GW-K-CAN TP20 H82 0762
   Revision: B9082001
   Coding: 002004
   VCID: 68D5E5629B73D2DB68-803C
   Component: IMMO          H05 0818
   Serial number:
   VCID: 6AD19F6A8D7FE0CB7E-803E
Address 3C: Lane Change (J1086)       Labels:| 5Q0-907-686.clb
   Component: HRE_Master    H12 0081
   Serial number: 0484698770 Dataset Number: V03935276UZ 0001
   Coding: 03011101
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D7B6436AC71A773EB-8068
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 5Q0 907 685 C    HW: 5Q0 907 685 C
   Component: HRE_Slave  H12 0081
   Serial number: 0471514014
   Coding: 030111
   Part No SW: 1S1 909 144 P    HW: 1S1 909 144 P
   Component: EPS_ECU       H51 1702
   Dataset Number: V03935277QZ 0001
   Coding: 0001000101000000
   Shop #: WSC 33930 004 1048576
   ROD: EV_SteerAssisNSK_014_VW12.rod
   VCID: 40851DC2DB83CA9B80-8014
   Component: MIB2-S-R-CN   036 0358
   Revision: -----001    Serial number: VWZ6Z2Q7089808
   Coding: 1E000440040000
   Shop #: WSC 00081 790 00126
   VCID: 46890BDAF1A7E4ABBA-8012
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 79
                    Mileage: 168447 km
                    Time Indication: 0
                    Date: 2019.08.28.
                    Time: 21:01:19
   Serial number: 40000000042334 Dataset Number: rdkseditor  0016
   ROD: EV_RDKBERU30_005.rod
   VCID: 3777761E8E4D8D2331-8062
End-------------------------(Elapsed Time: 03:42)--------------------------
------------------------------5 Faults Found-------------------------------
Re: Need help on MFSW
i don't believe that will be possible
MrCollayder
Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Post by MrCollayder »
Only E6 engines support CCS via mfsw
sejuani
Drives: POLO 6R
Post by sejuani »
Thanks for the answer.
Today, I tried various methods and confirmed that CLSA cannot support MFSW with CCS.
I am even unable to independently disable the CCS of MFSW by canceling byte 17 bit 2 and byte 29 bit 6.
Considering that my MFSW was engraved using a grinding machine (and cannot be restored).
The current solution is to switch LIN from T73b/36 back to T73b/17, so I can keep my new MFSW.
sejuani wrote: Wed Apr 09, 2025 3:13 pm Thanks for the answer.
Can you post a few pics if possible?
sejuani
Drives: POLO 6R
Post by sejuani »
amer6R wrote: Thu Apr 10, 2025 8:31 am Hi,
Sure, but I don't know if you want pictures about wiring or drilling.
sejuani
Drives: POLO 6R
Post by sejuani »
Now I know that the CLSA (EU5) ECU can't interpret the digital signals from the CCS on the MFSW (6C0 959 442 F).
As far as I know, the only workaround in my case is to use the Cruise Control Emulator developed by Slavik (MaDwArLoCk).
A few days ago, I tried to retrofit shift paddles (6C0 951 527) on my MFSW, but they didn't work either.
At first, I found the long coding for the transmission: Byte 1 Bit 5 — "Activation of steering wheel Tiptronic paddles (or high RPM?)."
References:
https://www.drive2.ru/l/510735521681507035/
https://www.drive2.ru/l/512637401919651996/
However, the shift paddles still didn’t respond after editing the long coding.
I then asked for help on a forum in Taiwan, and someone told me that the TCU (09G 927 750 LK) can't interpret signals from the shift paddles.
Is this true?
To retrofit the 6C0 951 527 shift paddles, it's necessary to solder a 33R0 (1206) SMD resistor and a connector (for the "+" and "–" paddle signals) using a soldering iron.
I heard that the resistor only affects the downshift paddle backlight, so I decided not to install it.
Also, since I didn't have the proper connector, I soldered wires directly to the contact points instead.
Currently, I suspect the issue could be one of the following:
1. The TCU doesn't actually support shift paddles.
2. The wiring might not have been properly connected during soldering.
Sunday,27,July,2025,20:02:21:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.0.3 (x64)
Data version: 20250301 DS365.0
www.Ross-Tech.com
Dealer/Shop Name: sejuani
Workshop Code: 444 03743 000001
VIN: WVWZZZ60ZHT132658   License Plate:
Scan: 01 02 03 04 08 09 10 15 17 19 25 3C 44 5F 65 77
VIN: WVWZZZ60ZHT132658   Mileage: 178800km-111101miles
Address 01: Engine(J623-CLSA)
   Part No SW: 03C 906 014 FR    HW: 03C 906 014
   Component: CLSA-MM7GV-G  H02 8635
   Revision:--H02---    Serial number:
   Coding: 001A0014022400000000
   Shop #: WSC 12345 123 08192
   VCID: 72E1870AAEAF28DFAA-5178
Address 02: Auto Trans       Labels:. User\09G-927-750.clb
   Revision:00H98000    Serial number:
   Coding: 0000328
   VCID: 050BCCD64F212F679F-515A
Address 03: ABS Brakes (J104)       Labels:. User\6R0-907-37x-ESP90.lbl
   Coding: 61DD2463422603C2861A246E4259C040080F
   Shop #: WSC 03743 444 00001
   ROD: EV_Brake1ESP90iBOSCH_003_VW23.rod
   VCID: 0005DDC29B030A9BC0-8054
   Coding: 01
   Revision: V0000000
   Coding: 3AB82FB828F36E00B33806C07DEB9E91F0C862F0608F21C03204003F0800
   Coding: 0728DD
   Coding: 640000
   Coding: 640000
   Coding: 280000
1 Fault Found:
            000 - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 178805 km
                    Time Indication: 0
                    Date: 2019.12.18.
                    Time: 19:57:07
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39391524704772 Dataset Number: 7N0039v____
   Coding: 0031155011
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
1 Fault Found:
12718592 - Databus
          U1121 00 [00001001] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 178805 km
                    Date: 2025.07.27.
                    Time: 19:57:01
   Coding: 00304A
   Coding: 180C01
   Revision: B9082001
   Coding: 002206
   Serial number:
Address 3C: Lane Change (J1086)       Labels:| User\5Q0-907-686.clb
   Coding: 03031102
   Coding: 030311
   Coding: 0001010100010000
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 5K7 035 200 M    HW: 5K7 035 200 H
   Component: MU-S--ROA     H31 0478
   Serial number: VWZAZ2S5361886 Dataset Number: V03935249AS 0001
   Coding: 026200003C0000001111000100003A001F0000D0000001008A
   ROD: N/A
   VCID: 2E59537A71174CEB62-807A
No ASAM data for: "EV_MUStd4CTSAT" (VW25)
2 Faults Found:
1543 - ROD - Unknown Error Code
          - 00 [00001001]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 178805 km
                    Date: 2025.07.27.
                    Time: 19:57:01
15360256 - ROD - Unknown Error Code
          - 00 [00001001]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 178805 km
                    Date: 2025.07.27.
                    Time: 19:57:01
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:46)--------------------------
------------------------------4 Faults Found-------------------------------
Try coding your MFSW from 280000 to 290000
sejuani
Drives: POLO 6R
Post by sejuani »
iichel wrote: Tue Jul 29, 2025 12:17 pm Try coding your MFSW from 280000 to 290000
Thanks for the help, but unfortunately it didn’t work.
can you read the measured values of the shifting paddles, in the bcm? you should be able to do this with vcds
sejuani
Drives: POLO 6R
Post by sejuani »
I couldn’t find the option about shift paddles under 'Advanced Measuring Values' in the BCM, so I checked 02 - Auto Trans. for 'Tiptronic' and 'Multi-Function'.
There’s no response in the parameters when I press the shift paddles.
However, when shifting between +, –, D, and S, the parameters display correctly
the "-" on the left paddle should also be illuminated
sejuani
Drives: POLO 6R
Post by sejuani »
iichel wrote: Thu Jul 31, 2025 6:16 am the "-" on the left paddle should also be illuminated
Finally, I soldered the resistor and the '-' symbol on the left paddle lit up.
But when I pressed the paddle, nothing happened.
sejuani
Drives: POLO 6R
Post by sejuani »
Does the AQ 250 transmission allow the communication of DSG paddles? It it a combination that should work?
