Hi all,
hoping someone can help me here. A few weeks ago, my key got stuck in the ignition. (Wont do final rotate in order to release the key). After having a look around, it appeared the solenoid at the back of the housing was very hot, but manually pressing it in would release the key. I therefore replaced the housing including the solenoid and this fixed it until now.
The replaced solenoid is again getting very warm and the key wont come out of the ignition!!! I am now out of ideas. If anyone has had a similar problem or knows what it may be, that would be a great help. It sounds like an electrical fault of some sort.
Polo Gti 1.4tsi (180bhp) Key stuck in the ignition
justinpearce7
- Drives: Vw Polo Gti 1.4tsi (180Bhp)
Re: Polo Gti 1.4tsi (180bhp) Key stuck in the ignition
What do you mean by 'key housing'? The part of the ignition lock that bolts on to the steering column?
justinpearce7
Correct - not the barrell itself
- Platinum Member
is it dsg or manual
6R gti is always DSG. Manual doesn't have the solenoid.
- Platinum Member
Could it be some issue with the gear lever not registering P position?
I am having the same issue currently. Did u solved it? Can i know how?
Same car, polo gti 6r. When measured, the connector to the solenoid is shorted thus it keeps supplying 12v to activate the solenoid. Right now i disconnected the connector as temporary solution
