If you feel comfortable here and it is your wish, you can also join us in the section for owners with new Alien ships. viewforum.php?f=58
You can 'create' a new thread to build and share a logbook where other users/aliens can perhaps provide you with some help for your new interstellar travels/journeys.
Hi, I'm Pawel and I'm the new owner of this car. i will try not to let this project die,
first I have to replace the door lock, no door open signal, I also have to fix BCM errors related to high beams.
The car's electrics started to fail, I found time to start sort out the mess of wires and make proper connections. Some wires were connected in 4 places
