Remote central locking
Hi, could someone please advise, boot unlocks via remote but doors have stopped working. Checked fuse when removed and boot button pressed can still hear a click under dash but not when pressing door lock or unlock. Any ideas? Thank you. Lily.
Re: Remote central locking
so when you press the unlock button, only the boot unlocks? or nothing happens? do the doors unlock when you press the unlock button in the drivers door?
Hi, thank you for reply. When I press the door buttons nothing happens key led flashing. When I press the boot remote button boot unlocks. Have to use the key in door lock to undo doors but passenger door stays locked. Thank you. Lily.
Okay, does the car illuminate the hazards when you press the unlock button? Do you happen to have a spare key to check if it does the same?
No nothing happens and only one key. Thank you. Only the boot unlocks when pressed.
- Platinum Member
what if you double press the buttons. Press one, and press it again quickly
