I respect your reason/logic for removing the battery before checking the 4 ABS input channels impedance, so to keep you happy then do that.JeyLn wrote: Mon Jun 09, 2025 9:00 pmThe front left was 4k,166 ohms and the rear left 0.748 ohms.
One question, shouldn't the resistance readings be done with battery off ?
I remember I read somewhere it should be done like that otherwise it will damage the car electronics?
The low resistance of that rear left sensor, to me, means that it is faulty, the ABS controller will have been designed to expect similar sensor impedance from all 4 sensors.
I seem to have checked a single 2015 6C ABS sensor when it was new, and recorded a value of 4.???M ohms - while my 2011 Audi S4 ABS sensors are 497>576 ohms. Maybe I should check the spare new Polo sensor again!
Edit:- These ABS controller are more robust than you might think, they need to survive their input channels having a short across them, and even that short also going to the body earth.
After you have replaced this faulty sensor, you might find that an ABS related fault still exists "elsewhere", don't worry too much about that, take the car for a short drive, then if necessary clear all remaining faults and they should now stay away.
