VIN: WVWZZZ6RZBY176906 License Plate:
Mileage: 215110km-133663mi Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 25 2E 44 56
VIN: WVWZZZ6RZBY176906 Mileage: 215110km-133663miles
02-Auto Trans -- Status: Malfunction 0010
2E-Media Player 3 -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 1110
Address 01: Engine (------CAVE) Labels:. 03C-907-309-V1.clb
Part No SW: 03C 906 027 AR HW: 03C 906 027 AR
Component: 1.4l R4/4V TS H14 7924
Revision: L2H14--- Serial number: CVN: 7CC79B02
Coding: 00250012000400000000
Shop #: WSC 01286 386 08256
ASAM Dataset: EV_ECM14TSI01103C906027AR 001009
ROD: EV_ECM14TSI01103C906027AR.rod
VCID: 71E960C3A0A9131B34-8024
VINID: 9E69EAAAA1A2A92A411C624018D584E1B3
6 Faults Found:
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
U1025 00 [047] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 215110 km
Date: 2025.07.05
Time: 12:42:26
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 51 C
Intake air temperature: 27 C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.944 V
CAN status - engine control module-Bits 0-7: 0
CAN TimeOut meter - transmission-Bits 0-7: 0
Generator performance: 0 W
CAN TimeOut meter - gateway-Bits 0-7: 0
4660 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [047] - -
Fault Priority: 6
Fault Frequency: 7
Mileage: 215110 km
Date: 2025.07.05
Time: 13:58:36
Coolant temperature: 26 C
Intake air temperature: 21 C
Voltage terminal 30: 11.803 V
4675 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Mileage: 215110 km
Date: 2025.07.05
Time: 12:48:05
Engine RPM: 1107.00 /min
Normed load value: 34.1 %
Vehicle speed: 1 km/h
Coolant temperature: 23 C
Intake air temperature: 20 C
Voltage terminal 30: 13.805 V
Unlearning counter according OBD: 39
Cruise Control System (CCS): status-Bits 0-7: 0
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
Cruise control switch-off: reversible-Bits 0-7: 255
Cruise control switch-off: irreversible-Bits 0-7: 255
Acceleration: 0.354 m/s
4050 - Leak in Air Intake System
P2279 00 [236] - -
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 2
Mileage: 215110 km
Date: 2025.07.05
Time: 11:12:54
Engine RPM: 700.50 /min
Normed load value: 22.7 %
Coolant temperature: 30 C
Intake air temperature: 18 C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 13.735 V
Short term adapt. throttle valve for mass air flow sensor: 1.03632
Leakage air: 8.1 kg/h
Long term adaptation of throttle valve for mass air flow sensor: 1.00330
Long-term fuel trim bank 1 at idle: -0.89 %
Oxygen control: adaptation value at partial load: bank 1: 0.97141
Idle speed specified value: 700 /min
Misfire totalizer: 0
11505 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 00 [096] - Implausible Signal
Fault Priority: 2
Fault Frequency: 1
Mileage: 215110 km
Date: 2025.07.05
Time: 13:57:04
Engine RPM: 188.50 /min
Normed load value: 64.3 %
Coolant temperature: 24 C
Voltage terminal 30: 10.342 V
Height correction: 0.99561
Charge press. ctrl.: spec. value: 0.0 %
Accelerator pedal: sensor voltage 1: 767.8 mV
Accelerator pedal: sensor voltage 2: 394.2 mV
Charge air pressure: actual value: 1005.00 hPa
Charge air pressure: specified value: 1037.19 hPa
Intake manifold pressure upstream 2nd compressor: raw value: 1010.94 hPa
9024 - Manifold / Barometric Pressure Sensor (G71) / (F96)
Fault Priority: 2
Fault Frequency: 3
Mileage: 215110 km
Date: 2025.07.05
Time: 11:25:49
Coolant temperature: 34 C
Voltage terminal 30: 11.709 V
Height correction: 1.01068
Accelerator pedal: sensor voltage 1: 777.6 mV
Accelerator pedal: sensor voltage 2: 397.8 mV
Charge air pressure: actual value: 1014.14 hPa
Charge air pressure: specified value: 272.73 hPa
Intake manifold pressure upstream 2nd compressor: raw value: 1020.55 hPa
Readiness: 0010 0100
Part No SW: 0AM 300 050 K HW: 0AM 927 769 D
Component: GSG DSG AG7 431 9032
Revision: 00043014 Serial number: CU501512177234
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 3169A0C3AB29531B74-513C
1 Fault Found:
006279 - Wheel-Speed Signal from ABS Control Module
P1887 - 000 - Implausible Signal - Intermittent
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 9
Mileage: 215110 km
Time Indication: 0
Date: 2019.11.26
Time: 12:48:06
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Revision: --------
Coding: 000000000000000000000000000000000000
Shop #: WSC 04941 000 00000
VCID: 071D2E1BB22D3DAB8A-8052
3 Faults Found:
01042 - Control Module; Not Coded
000 - -
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 6
Reset counter: 193
Mileage: 215111 km
Time Indication: 0
Date: 2019.11.26
Time: 11:33:30
Hex Value: 0x0007
Hex Value: 0x0002
Hex Value: 0x3213
Hex Value: 0x1493
Hex Value: 0x007F
Hex Value: 0x7F7F
Hex Value: 0x7F00
03306 - Coding Not Valid
000 - - - Intermittent
Fault Priority: 0
Fault Frequency: 4
Reset counter: 233
Mileage: 215111 km
Time Indication: 0
Date: 2019.11.26
Time: 10:20:56
Hex Value: 0x0002
Hex Value: 0x0002
Hex Value: 0x30E7
Hex Value: 0x2596
Hex Value: 0x00FF
Hex Value: 0x7F80
Hex Value: 0x7EF8
00493 - ESP-Sensor Unit (G419)
005 - No or Incorrect Basic Setting / Adaptation
Fault Status: 01100101
Fault Priority: 0
Fault Frequency: 27
Reset counter: 193
Mileage: 215110 km
Time Indication: 0
Date: 2019.11.26
Time: 11:39:38
Hex Value: 0x4003
Hex Value: 0x0002
Hex Value: 0x32E1
Hex Value: 0x207D
Hex Value: 0x00FF
Hex Value: 0x7F80
Hex Value: 0x7E00
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AB.clb
Part No SW: 6R0 820 045 G HW: 6R0 820 045 G
Component: Man AC 02 0101
Revision: 0002S 02
VCID: 326BAFCF6D2F68030D-8066
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 215098 km
Time Indication: 0
Date: 2015.09.12
Time: 16:12:06
ABS CODING LOST
scriptedperformance
- Drives: 6r gti
ABS CODING LOST
Hi, I have a Polo GTI 2011 that has lost ABS Coding after replacing pump and the old unit has been lost... Can anyone help with long coding for VCDS? I can't access the car on ODIS.
Re: ABS CODING LOST
what do you mean by 'I can't access the car on odis'?
Re: ABS CODING LOST
this is why i dont make abs codings anymore for free..Joined:05 Jul 2025 10:01
Last active:05 Jul 2025 10:20
Re: ABS CODING LOST
It's totally understandable.
Offering the option to purchase tech support is also a gift... in a few years, or even now, people will be asking for tech support, and it won't be possible because there won't be anyone with the knowledge and skills to do it anymore.
Via smartphone, the AI will tell them to go to a garage to have the repair done, at a cost of 500 to 1000 euros/pounds at best...
...I'm talking 500 euros non-refundable just for making an appointment for taking the car to the garage so a novice with a smartphone can start "fixing" it.
- Platinum Member
Re: ABS CODING LOST
their loss,
this community has much more valuable information to offer that abs coding
