Is the 12v battery covered under VWs 3 year warranty?
grazuncle2
Drives: Polo 1.0 TSI SE 2019
Re: Is the 12v battery covered under VWs 3 year warranty?
Post by grazuncle2 »
something like this?
https://www.ebay.co.uk/itm/125851329540 ... R6qBmZO4Yg
this looks slicker than mine but mine has temperature too.. can't find the original seller ...yet.
Johntheo1
Drives: 2018 MK10 AW1
Post by Johntheo1 »
Installed the DVM monitor a week ago and did 2 ~ 60 mile day time round trips since, the voltage goes to 14.8V for around 30 secs or so after each start and then returns to a rock steady 13.2V once under way, it goes to exactly 14.8V on each and every overrun once the revs are ~ > 1200RPM, will keep an eye on it to see does the ambient temperature has any effect on the charging levels.
grazuncle2
My DVM in the 12 socket never displays the same reading as directly off the battery (I have a calibrated meter and similarly tested the DVM and I know the slight undervalue reported voltage from it (0.5 volt under)
I think the car's computer does some fancy rationing when charging the battery or car at rest... Even my ObDEleven app always reports higher values at rest but only to tenth of a volt accuracy.. which means a 12.4v reading could actually be 12.41 or closer to 12.49v .. 12.49 would just one tenth of a volt off from displaying 12.5v.
I'm going to give the OCD a rest now and just drive the thing... as long as it goes high after starting the car I'll be happy. :D
Your 12V sockets are probably powered by a relay or some other switch construction. That means the voltage directly at the battery will be different than at the 12V outlet.
And depending on make, model and quality, the reading might be different anwyay in the 12V socket measurement tool.
grazuncle2
Yes I know that is the case as I have measured battery vs socket with a calibrated meter and the socket is always lower voltage than the battery.
I have not tested the differences when running yet and may do another comparison; I'm not in a hurry to test that LOL
Johntheo1
Post by Johntheo1 »
Johntheo1 wrote: Tue Aug 01, 2023 9:19 pm Another set of readings, car now 4 years & 7 months old. (4.583 yrs)
VAG reckon that useful battery life is ~ 50 X battery capacity, in my case 50*59 = 2950AH so depending on which value below is used, my battery life is either 2950/2187*4.583, 6.18 years or 2950/2342.2*4.583, 5.8 years, watch this space.
20:27:49 Mileage 22652KMS, 14076 MILES READINGS TAKEN August 2023
IDE01834 Battery voltage 12.175 V
IDE01836 Battery current -4.356 A
IDE01837 Temperature of battery sensor 18 °C
IDE01839 Battery charge level 73 %
IDE01841 Battery internal resistance 7.0 mOhm
IDE01842 Usable battery charge 27 Ah
IDE01843 Battery voltage at rest 12.4 V
IDE01948 Battery internal resistance not normed 5.4 mOhm
IDE07681-MAS06086 Battery total charging throughput-Total re-charge 2187.0 Ah
IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 2342.2 Ah
(battery capacity 59AH)
Strange one today, noticed that the DVM was showing full charging at 14.7V for approx 1 hour today with continuous town driving, normally this only happens for 30 sec or so after starting and on overrun. Readings below show nothing amiss, the battery charge level showes 80% which one might expect after high voltage charging for a hour or so, its normally 73% to 75%.
After taking the readings below and starting the engine, it charged at 14.9V (VCDS) with charging current of ~ 17/19A for around 44 secs after starting up and then fell as normal back to normal.
18:02:58 28/10/2023
IDE01834 Battery voltage 14.937 V
IDE01836 Battery current 19.059 A
18:03:42 28/10/2023
IDE01834 Battery voltage 13.487 V
IDE01836 Battery current 4.470 A
A auto scan showed one fault.
30428 - ECM Power Relay Load Circuit
P068A 00 [040] - Opens Too Early
Address 19: CAN Gateway (2Q0 909 901 )
18:01:30 28/10/2023 25249kms 15689 miles. Engine OFF
IDE01834 Battery voltage 12.344 V
IDE01836 Battery current -4.385 A
IDE01837 Temperature of battery sensor 20 °C
IDE01839 Battery charge level 80 %
IDE01841 Battery internal resistance 7.2 mOhm
IDE01842 Usable battery charge 33 Ah
IDE01843 Battery voltage at rest 12.5 V
IDE01948 Battery internal resistance not normed 5.8 mOhm
IDE07681-MAS06086 Battery total charging throughput-Total re-charge 2371.8 Ah
IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 2529.7 Ah
grazuncle2
Wow that was high for quite some time!
The scan was useful to do.
And get an actual fault discovered. The problem for me would be who to take the vehicle too as I have little confidence with local VW franchise. I had been talking to a friend who found a specialist locally who services his Mercedes and anything else
My local indy is good for servicing and repairs, etc but openly told me that is his limit.. an honest man.. who would belive it.
Let us know how you get on please.
Johntheo1
Post by Johntheo1 »
The full fault code is below, I'd say it was flagged ~ 5 weeks ago but the constant high voltage charging only occured for that 1 hour period a few days ago, the car was parked up for 8 days until last Thursday and had been parked for the same period shortly before that, I allways test the Stop/Start after any prolonged parking period and it operated perfectly after driving the statutory 0.5km or so to enable it, will keep a eye on it.
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 24953 km
Date: 2000.00.00
Time: 00:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 255 km/h
Coolant temperature: 37 °C
Intake air temperature: 29 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.580 V
Unlearning counter according OBD: 24
Engine torque: 0.0 Nm
Fuel level: 0.00 l
Oxygen sensor B1: sensor 1: specified value: 1.0000
Readiness: 0000 0000
Johntheo1
Post by Johntheo1 »
Took a few more readings this evening after start up, car parked, only electrical load were the DRLs
The charging pattern is certainly changing with more time now running at ~ 14.7V and charging current falling to ~ 5A after ~ 5 minutesso maybe I will just monitor it.
It may eventually settle at a constant 14.4V like the constant charging on all my old VWs everlasting batteries but I wouldn't hold my breath.
19:31:57 Stopped
IDE01834 Battery voltage 12.107 V
IDE01836 Battery current -4.418 A (DRLs)
19:32:10 Running
IDE01834 Battery voltage 13.387 V
IDE01836 Battery current 26.208 A
19:32:13 Running
IDE01834 Battery voltage 14.322 V
IDE01836 Battery current 20.651 A
19:32:21 Running
IDE01834 Battery voltage 14.747 V
IDE01836 Battery current 17.088 A
19:32:40 Running
IDE01834 Battery voltage 14.761 V
IDE01836 Battery current 12.570 A
19:32:52 Running
IDE01834 Battery voltage 14.764 V
IDE01836 Battery current 11.405 A
19:33:01 Running
IDE01834 Battery voltage 14.765 V
IDE01836 Battery current 10.748 A
19:33:42 Running
IDE01834 Battery voltage 14.768 V
IDE01836 Battery current 9.526 A
19:33:42 Running
IDE01836 Battery current 9.397 A
19:34:32 Running
IDE01834 Battery voltage 14.771 V
IDE01836 Battery current 8.573 A
19:35:33 Running
IDE01834 Battery voltage 14.775 V
IDE01836 Battery current 7.605 A
19:36:13 Running
IDE01836 Battery current 7.035 A
19:36:43 Running
IDE01834 Battery voltage 14.783 V
IDE01836 Battery current 6.508 A
19:37:20 Running
IDE01834 Battery voltage 14.784 V
IDE01836 Battery current 5.969 A
19:38:01 Running
IDE01836 Battery current 5.060 A
Engine then switched off and immediately back on, voltage fell to ~ 13.39V and remained there. (see below)
19:39:13 Running
IDE01834 Battery voltage 13.491 V
IDE01836 Battery current 2.546 A
19:39:44 Running
IDE01834 Battery voltage 13.488 V
IDE01836 Battery current 2.030 A
grazuncle2
wow that seems very high
what is it like after the surface voltage used ?
main beam for 5 minutes?
Johntheo1
Post by Johntheo1 »
grazuncle2 wrote: Fri Nov 03, 2023 8:13 am wow that seems very high
Monitored it this AM with my DVM so maybe add 0.1/0.2V to my readings, I had the headlights on + the HRS on speed2 so a reasonable load, I just stopped the car and the stop/start shut down the engine.
+30 secs after shutdown 11.8V, +1min,11.4V, +2min,11.3V, +3min,11.2V, +3.5min 11.2V, (4 min after shutdown) engine restarted and remained at 13.2V for 3 mins, at which time I switched off.
I think this charging frequency is possibly normal enough, if I didnt have this DVM plugged in all the time then all signs are that batteryis doing what its supposed to do. Anyone with a DVM plugged in permanently might observe their charging pattern, and of course it also displayes the interior temperature, how many cars display this?.
grazuncle2
I think mine is not dissimilar as in what seems to me to charging strangely (to me at least)
I notice sometimes that with the engine running the voltage on the DVM is 12v after going to 14.1 from start up or anywhere in between.. LOL
Johntheo1
Post by Johntheo1 »
Set of readings after one hour daylight run.
Polo. Jan 2019, 18,585 miles. Battery (Type EFB 59AH) 5.5 years old.
22:37:22 14/07/2024
IDE01834 Battery voltage 12.351 V
IDE01836 Battery current -4.747 A
IDE01837 Temperature of battery sensor 24 °C
IDE01839 Battery charge level 85 %
IDE01841 Battery internal resistance 7.6 mOhm
IDE01842 Usable battery charge 31 Ah
IDE01843 Battery voltage at rest 12.6 V
IDE01948 Battery internal resistance not normed 5.2 mOhm
IDE07681-MAS06086 Battery total charging throughput-Total re-charge 2753.3 Ah
IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 2929.2 Ah
Johntheo1
Post by Johntheo1 »
Polo Jan 2019
22,020 miles, .Battery (Type EFB 59AH) 6.4 years old, original.
Readings just after starting engine
IDE01829 Generator exciter current 1.750 A
IDE01834 Battery voltage 14.959 V
IDE01836 Battery current 16.511 A
IDE01839 Battery charge level 72 %
IDE01841 Battery internal resistance 8.2 mOhm
IDE01842 Usable battery charge 24 Ah
IDE01948 Battery internal resistance not normed 7.8 mOhm
IDE07681-MAS06086 Battery total charging throughput-Total re-charge 3268.6 Ah
IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 3460.7 Ah
Johntheo1
Post by Johntheo1 »
For the first time in over 62 years of driving I put my battery on long term charge for 2 x 12 periods, the smart charger is a 5A, Ultimate Speed ULGD 5.0 C1, it charged at a continuous ~ 13.1V after briefly hitting 14.4V for a few minutes and should have been charging at ~ 0.7/0.8A which is "verified" by the charge level increasing from 66%(24AH) to 74%(32AH) in the first 12 hrs charge period, this charge level stayed the same for the next 12 hr charge period which suggests to me that this my new now max charging level, the Alternator is fine because at idling, with the fan speed on its max of 4, the HRS ON and the headlights on, it still slightly charges at ~ 0.2A, the battery at idling at 13.3V and charges at slightly over 1.0A at idling or driving normally with no auxiliaries on. It doesn't run continuously at 14.8V even with the now 74% charge level which suggests that the battery is, as expected, deterioriting, after 6.5 years, so we'll see what happens.
From what I am seeing, the Stop/Start will operate (on this car ) until the battery is on its last legs, at 65% charge level it stopped and started 6 times in less than a mile and after a hour or so the stop/start again worked perfectly after its customery 500/600 meters.
Read the scans from the end one up.
11:12:41 30/8 engine idling
IDE01834 Battery voltage 13.325 V
IDE01836 Battery current 0.153 A Fan Speed 4, HRS ON, Headlights ON.
IDE01839 Battery charge level 74 %
11:11:40 30/8 engine idling
IDE01834 Battery voltage 13.500 V
IDE01836 Batterycurren 1.223A
11:13:32 30/8
IDE01834 Battery voltage 13.509 V
IDE01836 Battery current 1.086 A
23:34:13 28/8 After another 12 hr Smart Charging, 24 hr in all
IDE01834 Battery voltage 12.311 V
IDE01836 Battery current -4.305 A
IDE01842 Usable battery charge 32 Ah
23:34:13 After 12 hr Smart Charging
07:48:16 Before(12 hhr Smart Charging)
IDE01836 Battery current -4.414 A
IDE01839 Battery charge level 65 %
IDE01843 Battery voltage at rest 12.3 V
